Page 1 of 2
Sharp LQ092B5DW01 (960x160pixel TFT module) meets RPi3
Posted: Thu Nov 24, 2016 7:58 pm
by aBUGSworstnightmare
Hey there,
here's another special aspect ratio display connected to the RPi:
Sharp LQ092B5DW01.jpg (12.67 KiB) Viewed 8955 times
https://youtu.be/isqD8UGTBB0
Will post config settings later here (although part of the story is in this thread viewtopic.php?p=1010869#p1010869 )
Re: Sharp LQ092B5DW01 (960x160pixel TFT module) meets RPi3
Posted: Fri Nov 25, 2016 8:20 am
by Project XXX
Nice to see that you find the right timing settings, looking forward to recieve the PCB and play with it.
Posted: Fri Nov 25, 2016 4:24 pm
So, here's the timing used for the demo video:
# For use with Sharp LQ092B5DW01 module only
# rev. 16/11/2016
# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
# Some settings may impact device functionality. See link above for details
# enable 24-bit DPI interface
dtoverlay=dpi24
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
disable_overscan=1
# Overscan Information
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=0
#overscan_right=0
#overscan_top=0
#overscan_bottom=0
# uncomment to force a console size. By default it will be display's size minus
# overscan.
# Portrait or Landscape Setting - only uncomment one block at a time
# Portrait-1 ( normal )
display_rotate=0
framebuffer_width=960
framebuffer_height=160
# Landscape-2 ( upside down )
#display_rotate=2
#framebuffer_width=960
#framebuffer_height=160
#Portrait-1 ( right side up )
#display_rotate=1
#framebuffer_width=160
#framebuffer_height=960
# Portrait-2 ( left side up )
#display_rotate=3
#hdmi_force_hotplug=1
# Enable DPI
enable_dpi_lcd=1
# Make DPI default output
display_default_lcd=1
# custom HDMI mode
# https://www.raspberrypi.org/forums/viewtopic.php?p=613926#p613926
# https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=24679
dpi_group=2
dpi_mode=87
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=900
gpu_mem=194
# Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=off
#dtparam=i2s=on
dtparam=spi=off
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
dtparam=audio=on
# DPI output format definitions
# https://www.raspberrypi.org/forums/viewtopic.php?p=628061#p628061
# DPI structure: https://www.raspberrypi.org/forums/viewtopic.php?p=617719#p617719
# output_format:
#   1: DPI_OUTPUT_FORMAT_9BIT_666
#   2: DPI_OUTPUT_FORMAT_16BIT_565_CFG1
#   3: DPI_OUTPUT_FORMAT_16BIT_565_CFG2
#   4: DPI_OUTPUT_FORMAT_16BIT_565_CFG3
#   5: DPI_OUTPUT_FORMAT_18BIT_666_CFG1
#   6: DPI_OUTPUT_FORMAT_18BIT_666_CFG2
#   7: DPI_OUTPUT_FORMAT_24BIT_888
# rgb_order:
#   1: DPI_RGB_ORDER_RGB
#   2: DPI_RGB_ORDER_BGR
#   3: DPI_RGB_ORDER_GRB
#   4: DPI_RGB_ORDER_BRG
# output_enable_mode:
#   0: DPI_OUTPUT_ENABLE_MODE_DATA_VALID
#   1: DPI_OUTPUT_ENABLE_MODE_COMBINED_SYNCS
# invert_pixel_clock:
#   0: RGB Data changes on rising edge and is stable at falling edge
#   1: RGB Data changes on falling edge and is stable at rising edge
# hsync polarity:
#   0: default for HDMI mode
#   1: inverted
# vsync polarity:
#   1: inverted
# output_enable_polarity:
#   1: inverted
# hsync phase:
#   0: rising edge
#   1: falling edge
# vsync phase:
#   0: rising edge
#   1: falling edge
# output_enable phase:
#   0: rising edge
#   1: falling edge
# output_enable_mode/vphase/output_enable_phase = 1
dpi_output_format=262421
# HDMI timing definitions
#https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=24679
# hdmi_timings= <h_active_pixels>
#		  LCD module horizontal resolution
#               <h_sync_polarity>
# 		  0: active low
#		  1: active high
#               <h_front_porch>
#		<h_sync_pulse>
#		<h_back_porch>
#		<v_active_lines>
#		  LCD module vertical resolution
#		<v_sync_polarity>
# 		  0: active low
#		  1: active high
#		<v_front_porch>
#		<v_sync_pulse>
#		<v_back_porch>
#		<v_sync_offset_a>
#		<v_sync_offset_b>
#		<pixel_rep>
#		<frame_rate>
#		  screen refrech rate (50/60Hz supported only!)#
#		<interlaced>
#		<pixel_freq>
#		  calculates as: <h_active_pixels> * <v_active_lines> * <frame_rate>
#		<aspect_ratio>
#		  HDMI_ASPECT_4_3 = 1
#		  HDMI_ASPECT_14_9 = 2
#		  HDMI_ASPECT_16_9 = 3
#		  HDMI_ASPECT_5_4 = 4
#		  HDMI_ASPECT_16_10 = 5
#		  HDMI_ASPECT_15_9 = 6
#		  HDMI_ASPECT_21_9 = 7
#		  HDMI_ASPECT_64_27 = 8
#hdmi_timing for LQ092B5DW01 configuration notes
#h_active_pixels = 960
#h_sync_polarity = 1
#h_front_porch = 2
#h_sync_pulse = 6
#h_back_porch = 244
#v_active_lines = 160
#v_sync_polarity = 1
#v_front_porch = 0
#v_sync_pulse = 10
#v_back_porch = 40
#v_sync_offset_a = 0
#v_sync_offset_b = 0
#pixel_rep = 0
#frame_rate = 60
#interlaces = 0
#pixel_freq = 32004000
#aspect_ratio = 8
hdmi_timings=960 1 2 6 244 160 1 0 10 40 0 0 0 60 0 32004000 8
Strange thing is that I need to operate the display at roughly double the max dot clock.
Forum user 'ait' shared below hdmi_timings
hdmi_timings=960 1 2 8 242 160 1 0 10 40 0 0 0 60 0 15900000 8
but since I don't know it's settings for dpi_output_format the display my displays are not working with this timing (15.9MHz dot clock is in spec btw).
So, in case some other users have such a display would be great if they can share their timing details :!:
Wifi enabled backlight driver for LQ092B5DW01
Posted: Wed Jan 04, 2017 12:41 pm
the LQ092B5DW01 TFT module has no integrated backlight driver. The backlight of the module is as below:
- 3 LED string white backlight @ typ. 18.5V
- 1 LED string red backlight @ typ. 12V
- contacts available on a 0.5mm pitch FPC connector
So, this module has three 'challanges': requires some tiny connector and two different voltages.
That's why I had the idea to make my own LED driver for this board with features like:
- only one supply voltage (12V) and using a cheap step-up DC/DC module (XL6009E1 http://www.banggood.com/XL6009-Step-Up- ... mds=search) to generate the 18.5 - 19V
- usable for other modules as well
- two independent LED driver for different voltages --> decided to use two On-Semi CAT4104 because they allow up to 25 V operation on LED pins, 4 channles with 175mA sink current each
- easy to control via PWM
Well ... PWM is an issue when using DPI interface, so I've added a ESP8266 wifi module! I'm running a simple web server on it which allows to adjust the brightness of each of the backlights.
Wifi-enabled backlight driver for LQ092B5DW01
Wifi-enabled backlight driver for LQ092B5DW01 - top side with DC/DC and ESP8266 module (ESP12)
Wifi-enabled backlight driver for LQ092B5DW01 - bottom side with CAT4104 LED drivers
Red TFT module backlight
Posted: Thu Jan 05, 2017 1:31 pm
Here is what the module looks like when red backlight is used:
LQ092B5DW01 - red backlight set to 100%, white backlight off
LQ092B5DW01 - red backlight set to 100%, white backlight det to 10%
Posted: Thu Jan 05, 2017 2:54 pm
by james-at-lo-tech
Did you achieve concurrent output to this and the HDMI output via framebuffer device mapping somehow?
Posted: Thu Jan 05, 2017 2:57 pm
by ait
Aha, i never tried the red backlight.
Afaik the display was part of the BMW 7 Dashboard.
The red backlight was for the "Night Mode".
Posted: Thu Jan 05, 2017 4:13 pm
Afaik was the display part of the BMW 7 Dashboard.
:idea: :!:
james-at-lo-tech wrote:Did you achieve concurrent output to this and the HDMI output via framebuffer device mapping somehow?
Also people claim that this should be possible - with some dedicated software like omxplayer i.e. (in general: software which supports output re-direction), I could never get any output on the HDMI interface when using DPI interface.
Due to the fact that the display connected to DPI interface is my main screen - means nothing is connected to HDMI - I never investigated this matter.
Posted: Thu Jan 05, 2017 5:08 pm
by james-at-lo-tech
Omxplayer works fine with DPI interface, but we need a framebuffer driver to create /Dev/fb1 for the non-primary display for it to be usable by lightdm.
Posted: Thu Jan 05, 2017 5:54 pm
james-at-lo-tech wrote:Omxplayer works fine with DPI interface, but we need a framebuffer driver to create /Dev/fb1 for the non-primary display for it to be usable by lightdm.
I know that omxplayer works fine with DPI (as you can see from the video in the first post of this thread), but I never managed to get a second omxplayer instance playing to HDMI at the same time
If you know how to achieve this, let me know the commands and I will test.
Posted: Thu Jan 05, 2017 7:39 pm
by rpdom
aBUGSworstnightmare wrote:I know that omxplayer works fine with DPI (as you can see from the video in the first post of this thread), but I never managed to get a second omxplayer instance playing to HDMI at the same time
I believe using omxplayer --display=5 will use the HDMI or Composite outputs, and --display=4 will use the DPI output. I've had simultaneous playback of different videos on HDMI and DPI via Gert's VGA board.
Posted: Thu Jan 05, 2017 7:48 pm
by james-at-lo-tech
In my testing,
  • To play on DPI device when desktop is on HDMI device: omxplayer --display 4 test.mp4
  • To play on HDMI device when desktop is on DPI device: omxplayer --display 5 test.mp4
Posted: Fri Jan 13, 2017 7:40 am
by NOOBS_2016
aBUGSworstnightmare wrote: So, in case some other users have such a display would be great if they can share their timing details :!:
hey,
i am working with the LQ092B5DW01-display too.
I have built my own PCB and connected it to the display. After booting the GUI appears, but the picture is flickering. I took your settings, but I think they are not working perfectly for my display.
Which parameters would you change to stop flicker?
Posted: Fri Jan 13, 2017 5:36 pm
hey,
how should I know what you call 'flicker'?
Post your config.txt, let us know which RPi you're using (zero, 3, ..) and I can test it and see flickering.
In case of Zero I recommend increasing GPU clock, above settings work on my Zero and Rpi 3.
And, which of the timings that I've posted are you using? Only the one with 32MHz is working
Posted: Sat Jan 14, 2017 1:53 pm
by NOOBS_2016
I use this settings in my "config.txt" and use a RPi 3. On monday i will post my complete "config.txt" and can share a dropbox-link with a video of my display.
Posted: Sat Jan 14, 2017 2:04 pm
by ait
my settings in config.txt where ("where" because i do not use the display at the moment):
dtoverlay=dpi24
enable_dpi_lcd=1
dpi_group=2
dpi_mode=87 # Hdmi CVT
i used it with pizero and raspbian lite
Posted: Mon Jan 16, 2017 7:29 am
by NOOBS_2016
the video:
https://www.dropbox.com/sh/h2g54xbu9zxg ... 1iDba?dl=0
my config.txt:
# http://raspberry.org/documentation/configuration/config-txt.md
# Some settings may impact device functinality. See link above for details
# Uncomment if you get no picture on HDMI for a default "safe" mode
#hmid_safe=1
# Uncomment if hdmi display is not detected and composite is being output
# Uncomment to force a HDMI mode rather than DVI. This can make audio work in DMT (computer monitor) modes
#hdmi_drive=2
# Uncomment to increase signal to HDMI, if you have interference, blanking or no display
#config_hdmi_boost=4
# Uncomment for composite PAL
#sdtv_mode=2
# Uncomment to overclock the arm. 700MHz is the default.
#arm_freq=800
# settings for sharp-display #
dtparam=i2c_arm=off
dtparam=spi=off
# GPIO set to ALT2-function for DPI
dtoverlay=dpi24
# Uncomment this if your display has a black border of unused pixels visible and your diplay can output without overscan
disable_overscan=1
# Uncomment to force a console size. By default it will be display's size minus overscan.
display_rotate=0
# DPI-output activate / configure
enable_dpi_lcd=1
# Uncomment to force a specific HDMI mode (this will force DPI)
dpi_group=2
dpi_mode=87
dtparam_audio=on
hdmi_timings=960 1 2 6 250 160 1 0 10 40 0 0 0 60 0 32001000 8
gpu_mem=194
#Additional overlays and parameters are documented /boot/overlays/README
Posted: Mon Jan 16, 2017 6:55 pm
NOOBS_2016 wrote:the video:
my config.txt:
#hmid_safe=1
#hdmi_drive=2
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=off
dtparam=spi=off
dtoverlay=dpi24
disable_overscan=1
display_rotate=0
enable_dpi_lcd=1
dpi_group=2
dpi_mode=87
dtparam_audio=on
gpu_mem=194
Check your cable and/or interface board.
Tested your settings here, image is stable but shifted 6 pixel to the right.
6pixel offset to the right
NOOBS_2016 timing on my HW
EDIT: btw... display rotate command can be omitted
Posted: Tue Jan 17, 2017 9:25 am
by NOOBS_2016
Thank you for your help...now it is working fine :D
I forgot to connect all GND-pins of the display with all GND-pins of the RPi :roll:
But i have still a other frequency than you, with your frequency it is flickering.
My timing:
hdmi_timings=960 1 2 6 244 160 1 0 10 40 0 0 0 60 0 32900000 8
Posted: Wed Jan 18, 2017 8:32 am
Sounds like some crosstalking issues; good to hear you got it fixed.
I would not worry about driving frequency difference; as long as your picture is stable I would say 'mission completed'
Posted: Thu Jan 19, 2017 12:36 pm
by NOOBS_2016
I was interested which frequency for the CLK-signal is the lowest the RPi 3 is able to send out.
So i checked it with an oscilloscope and the result was 31,253,817 Hz.
I changed the frequency in the hdmi-timing-settings and it is still working fine
Posted: Sat Feb 11, 2017 9:36 pm
by holo85
These settings work for me:
hdmi_timings=960 0 20 50 70 160 0 10 10 30 0 0 0 60 0 19200000 1
Posted: Sun Feb 12, 2017 8:17 am
holo85 wrote:These settings work for me:
Please post your 'dpi_output_format' number too.
Using mine (dpi_output_format=262421) results in the display being offset to the left.
Posted: Sun Feb 12, 2017 9:45 am
by holo85
Sry,
# sharp LQ092B5DW01 parameter
dtoverlay=dpi18
overscan_left=1
overscan_right=1
overscan_top=0
overscan_bottom=0
enable_dpi_lcd=1
dpi_group=2
dpi_mode=87
dpi_output_format=278549
Posted: Sun Feb 12, 2017 12:08 pm
holo85 wrote:Sry,
dtoverlay=dpi18
overscan_left=1
overscan_right=1
overscan_top=0
overscan_bottom=0
enable_dpi_lcd=1
dpi_group=2
dpi_mode=87
Thanks for sharing! Works like a charm 8-) :!:
