Photobooth crash on boot
Posted: Tue Sep 06, 2016 11:16 am
by thak
Hi!
I'v made a photobooth fro my wedding, mostly base on this tuto =>
http://www.instructables.com/id/Wifi-Ph ... /?ALLSTEPS
The things i changed are :
The pi, i use a pi2
Pi camera, i use the last one (2.1)
the screen, same size but not the same resolution
No touch/kernel change, i use a button to take the picture (so i changed the python script)
Picture resolution, i use higher resolution than the one the author use initially
Power Supply, i plug the box directly on the wall (no battery)
The problem is that i need 2 to 3 boot before everything run fine... And i don't know why...
I already check this file :
/var/log/messages
/var/log/syslog
/var/log/kernel.log
Even if will not understand a thing in it, but every log stop on the 27th of july, but i boot it many times since that date (in order to check it work fine on first boot)
I'm still learning linux command and everything around the raspberry, so if you need more info, could you just tell me how to get it too :)
Thanks a lot!
Re: Photobooth crash on boot
Posted: Mon Sep 12, 2016 10:45 am
by thak
Hi again!
No one have a little clue :'( ?
Even for just checking the boot log correctly ?
