[Originally mis-posted in beginners, sorry!]
I would like my Pi 3 in a case. I also want it cool, so want to put a 5v fan mounted over the SOC. (Should airflow be away from the SOC, or towards it?)
However, I also want to (a) not modify the board in any way and (b) be able to use 40-pin IDC connectors with the board.
Most case/fan combinations I have seen simply plug onto the GPIO connector. What, if any, are the alternatives, bearing in mind my two constraints?
One approach I have thought about is to take an "extra tall" header, and solder the fan connectors to it, which should allow me to connect a cable to the header pins as well.
An alternative would be to tap the 5v via a micro USB plug/socket arrangement, I suppose..
