k5map
Wall mount RPi 2 case
Sun May 22, 2016 10:21 pm
Does anyone have a recommendation for a RPi 2 case which will also hold 1 Pi HAT board?
MysticWhiteDragon
Re: Wall mount RPi 2 case
Fri Jun 03, 2016 11:43 pm
You'll need an official 7" Pi TouchScreen, but it should work for you.
SmartiPi Touch
http://smarticase.com/collections/all/p ... tipi-touch
k5map
Sat Jun 04, 2016 12:33 am
Thanks for the link... I'm not using a 7" LCD but one of the Adafruit 20x4 LCD displays. The issue I'm trying to solve is locating a case which will hold the RPi and a HAT within the case and the LCD mounted through the top of the case.
