purelife
Any good cheap Pi cases out there?
Fri Aug 10, 2012 1:14 am
Will cases for the Pi overheat it?
Mick1152
Re: Any good cheap Pi cases out there?
Fri Aug 10, 2012 4:16 am
I'm using a case from modmypi.com currently. My second Pi is going to go into an old Gameboy.
My Pi is overclocked and it doesn't get hot inside the case which only has moderate ventilation in it IMO. There are plenty of examples of cases with none or almost no ventilation and nobody has had any issues with temps as far as I know.
LetHopeItsSnowing
Fri Aug 10, 2012 10:55 am
I use the Raspberr Punnet, you can print one out yourself onto Card, cut it out and stick it together
http://www.raspberrypi.org/archives/1310
Really cheap, it'll cost you 1 peice of A4 card and 10 minutes of your time
"am I getting slower, or is stuff more complicated; either way I now have to write it down - stuffaboutcode.com"
