IBM Portable PC
DSD (Digital Speech Decoder)
Tue Mar 08, 2016 10:48 am
I have finally built DSD on my Pi 2b+ and it 'appears' to be working, albeit barely:
An error occured while using the portaudio input stream
Error number: -9981
Error message: Input overflowed
Sync: -X2-TDMA mod: C4FM inlvl: 19% src: 0 tg: 0 slot0 [SLOT1] VOICE e:========R====R===E====R=====R=================== R=====R====R
Error number: -9981
IBM Portable PC
Re: DSD (Digital Speech Decoder)
Sun Mar 13, 2016 10:51 pm
I am running Darkice and Icecast on the same Pi, however stopping both made no change, I am still getting errors like:
Sync: -X2-TDMA mod: QPSK inlvl: 157% src: 0 tg: 0 [SLOT0] slot1 VOICE e:====R=====R========R=========================
Error number: -9981
Error number: -9981
Error number: -9981
Error number: -9981
Error number: -9981
Error number: -9981
Sync: (-X2-TDMA) mod: QPSK inlvl: 87% src: 0 tg: 0 [slot0] slot1 VOICE e:========R===========R=========R=========R======= R======R=========R
It has been suggested elsewhere that DSD is saturating a CPU core, which could be causing DSD to fall behind. However I do not believe that DSD is a single-threaded application?
Nfarrow
Contact: Website Facebook Twitter YouTube
Sat Jan 21, 2017 10:25 am
What command are you using to run it?
Twitter: @farrownick
Instagram veggievampire
I own a lot of Pis....
Nfarrow
Mon Jan 23, 2017 5:39 am
Wondering if anyone has got, "Digital Speech Decoder" working on a Pi. I personally am trying to use it on an audio file but I am a little stuck when it comes to running the software. Any help would be appreciated.
----errors-------
pi@raspberrypi:~/dsd-master $ dsd -fa -ma -i /tmp/pipe - -w dmrtest.wav
Digital Speech Decoder 1.7.0-dev (build:HEAD-HASH-NOTFOUND)
mbelib version 1.3.0
Writing audio to file dmrtest.wav
ioctl reset error
ioctl speed error
ioctl stereo error
ioctl setfmt error
Audio In Device: /tmp/pipe
----Install----
wget https://github.com/szechyjs/dsd/archive/master.tar.gz -O dsd.tar.gz
tar -xzf dsd-master.tar.gz
cd dsd-master
./travis_deps.sh
mkdir build
cd build
cmake -DCMAKE_INSTALL_PREFIX=$HOME/mbelib -DCMAKE_INSTALL_PREFIX=$HOME/itpp ..
make
sudo make install
--run----
echo "constructing a pipeline"
mkfifo /tmp/pipe
mplayer QPSKsound.mp3 -> /tmp/pipe
