Audio from pin
Posted: Sun Mar 06, 2016 8:57 pm
by leonardo123
I would like to know if there is a method with the raspberry pi for reproduce the audio from pin using pwm, or by some other metods.
Thank you in advance.
Re: Audio from pin
Posted: Sun Mar 06, 2016 9:07 pm
by DougieLawson
That's precisely what you get on the analog audio 3.5mm jack. It can even be done on a RPiZero with some simple additional hardware.
Re: Audio from pin
Posted: Sun Mar 06, 2016 9:26 pm
by leonardo123
I have a raspberry pi model B and i need to output the audio signal from the pin because i need to do this with model B
Re: Audio from pin
Posted: Sun Mar 06, 2016 9:42 pm
by GTR2Fan
Does your Model B not have a 3.5mm audio jack socket?
Re: Audio from pin
Posted: Mon Mar 07, 2016 4:53 pm
by leonardo123
yes but i want to output the audio signal from the pin !!!!
i can do it or no???!!!!
Re: Audio from pin
Posted: Mon Mar 07, 2016 5:01 pm
by Douglas6
No. You might be able to get raw audio PWM by remapping pins, but you'll be missing the RC filter circuit to get usable sound.
