crusty-bobcat
Wii U Gamepad shell reused for Pi
Wed Jan 20, 2016 5:18 am
So this is my project where I'm sticking a RPI2B1.1 into a heavily modified Wii U Gamepad shell.
It will mostly be a streamer, but will also have a few emulators on it for the couple of games I have.
I plan on making it so I can still access the GPIO pins (the ones that remain after the project is done) so I can still continue to program them on the spot or whatnot.
The "TV" button on the Wii U will function as a shortcut to a Universal Remote Control app that'll control a IR transmitter so I can change channels on any tv. :)
I'll be adding a few hard buttons for keyboard shortcuts like "ESC" (while streaming) and Ctrl+C to cancel PI commands.
There will be 4 power button's that control various USB devices, mostly to switch off Wifi to save battery.
Might add a light sensor that auto controls the backlight on the screen (if I can figure out how to interface with that) otherwise just a slider that ill program somewhere.
Id like to add some kinda overlay or menu thats always on the screen (towards the right or something) so I can have quick access to little things, like closing the moonlight stream or brightness slider. No idea how I will program this but time will tell.
Done;
[*]Got moonlight to stream correctly, controller works perfectly. Just having issues with the touchscreen.
[*]I got a 4 usb hub with switches for each one, this will be used to control power to the wifi, and various other things.
[*]I decided to make it so the camera will be external usb mounted, mostly to save room, but also so I can rotate it freely.
Current Progress and WIP;
[*Controlling the back-light, it stays on even after the Pi is shutdown(or blanking)
[*]Need a 2-2.1amp 5v for 4 lithium batteries, as well as a way to balance charge the 4 batteries via micro usb.
[*]Shortcuts, so I can launch moonlight from the LXDE desktop, or from a touchscreen interface.
[*]Touchscreen input on moonlight (for selecting things, and for games that require a mouse temporarily)
[*]Finish Xbox buttons/analog setup, I already have a stripped usb xbox controller mobo.
[*]Disable the LAN/USBHUB chip and run a dedicated hub with its own power source, mostly to save battery. Though I need the schematics for the RPI2B1.1 so I know which resisters to bridge to get the one USB port working.
Notes; (things I've discovered for others to know)
[*]If you're using the official 7" screen and you want to use moonlight, you have to run the stream at 1280x768 resolution
do this by; (example)
moonlight stream -width 1280 -height 768 -mapping xbox.map -app Steam
[*]The Raspberry Pi can be mounted upside-down onto the display board, Added bonus of having easy access to the SD card
What it currently looks like;
Got the dpad installed, it came off a micro xbox controller.
buttons installed
Other people with simular plans; (using a Wii U shell)
iheir
Original Post;
So I was trying to find an Atari Lynx II case, but they were all too pricey for being broken.
So I started looking for alternatives, and ended up finding this Wii U Gamepad listing with the screen and mobo missing.
:!: http://www.ebay.com/itm/121611336867 :!:
currently $18.99 with free shipping from California. (sorry if UK users can't get it)
I went ahead and bought one, and also got the official rpi 7" screen.
The Wii U gamepad's screen is 6.2 inches, so I'll have to relocate the buttons to fit the screen, but I was planning on moving the analog sticks to the opposite side anyway so this isn't a problem for me.
Anyway, I figured you guys would love to take advantage of this so enjoy!
EDIT: Found the Trigger buttons and camera plastic bezel;
http://www.ebay.com/itm/181995595160
All further updates will be posted to WordPress; bigger pictures!
https://crustybobcat.wordpress.com/
Last edited by crusty-bobcat on Sun Feb 28, 2016 3:48 am, edited 10 times in total.
crusty-bobcat
Re: Wii U "gamepad" as case
Sun Jan 24, 2016 11:38 pm
rpi wii u case concept
Here's my concept of how I want to rearrange everything, I also got the measurements right so the screen fits correctly in the case.
I'm using the BacMan tutorials for quick references on relocating pieces.
http://bacman.co.uk/general-modding/
Still waiting on the screen to come in, bad weather according to Element14 :|
crusty-bobcat
Wed Feb 03, 2016 2:01 am
Got the screen and got it all chopped up and fitted.
I still need to figure out if i can safely trim the bezel. The touchscreen layer sits over a bit of the bezel so I'm afraid of hurting it (anyone got a clue whether its needed or not?)
Anyway, pics.
I mounted the RPI upsidedown over the lcd controller, this saves me a lot of room but wont be permanent as im doing other things to improve room.
The USB and Ethernet are perfectly flush with the screens backing, like it was meant to be~
The bezel is still on, still waiting on confirmation if its even feasible to cut or not.
crusty-bobcat
Re: Wii U Gamepad shell reused for Pi
Fri Feb 05, 2016 2:13 am
plastic weld
I plastic welded the dpad and buttons off, and sanded the bezel off. Its tested working after I sanded it.
I just added a layer of bondo to the cracks. (they formed from the two different types of plastics being melted together)
Stay tuned for more.
crusty-bobcat
Sun Feb 07, 2016 3:43 am
Well, I broke the touchscreen glass. which is fine because it was useless since it only worked on Raspbian.
Im gonna have to find a usb touchscreen that fits the screen dimensions, or just put a sheet of plexiglass on it and not have touchscreen.
I bondo'd the new buttons on and its ready to install, just a matter of finding a new screen cover/touchscreen.
oswinfaulhaber
Fri Mar 04, 2016 6:34 am
Hey, any updates to this project?
I know you only bought the shell, but:
Any idea if the WiiU gamepad screen is compatible with the pi?
crusty-bobcat
Fri Mar 04, 2016 5:12 pm
Some other people were trying to get it working, not sure how far they got. I see a lot of people using phone lcd's with custom controller boards.
