tonyhansen
Re: Screenly OSE -- Digital Signage for the Raspberry Pi
Tue Oct 04, 2016 6:53 pm
ETexan wrote:
tonyhansen wrote:
  • The grabbers to reorder the list don't seem to work on an iPad.
Surely that must be an issue with the iPad browser's html implementation and nothing to do with screenly?
Not necessarily. It might be something in the javascript, CSS or HTML used by screenly that is not fully cross-browser compatible. I wouldn't know without digging deep into the bowels of the code.
vpetersson
Tue Oct 04, 2016 9:51 pm
To my knowledge, we're simply using Bootstrap (which should have full cross-browser support). If that isn't the case, please create an issue on Github. Perhaps it has been fixed in a later Bootstrap version.
Creator of Screenly (Screenly.io), the leading digital signage solution for the Raspberry Pi.
Twitter: @vpetersson | vpetersson.com
ETexan
Thu Oct 06, 2016 9:19 pm
Hey all, I've been working with the screenly API over the past weeks and thought I'd post some hints that might help out some other people.
I've been using Python and found that the requests library makes the GET and POST process of interacting with the API very simple.
It can be downloaded from here:
http://docs.python-requests.org/en/master/
I'm on Windows, so I used pip-Win to help me get set up to install the requests library
https://sites.google.com/site/pydatalog ... or-windows
Going through the documented API calls using these tools:
Retrieve information about all assets:
import requests
url = 'http://192.168.0.100:8080/api/assets'
r = requests.get(url)
	returns a list 'r' of data objects that describe each screenly assets
	r.json() returns a list of dictionary objects describing each screenly asset
	r.json()[0]['asset_id'] returns the asset_id value of the first screenly asset in the list
Retrieve information about a specific asset by asset_id value:
import requests
asset_value = '2d8331612b6c4c0e8075417a2d2e5db5'
url = 'http://192.168.0.100:8080/api/assets/' + asset_value
	returns a single data object describing the specific asset
	r.json() returns a single dictionary object describing that asset
	r.json()['asset_id'] returns the asset_id value of the screenly asset
	if there is no asset with the supplied asset_id, then r.json() returns []
Add a new screenly webpage asset:
The required values for adding a new webpage asset are name, mimetype, uri, and duration
import requests
dataDict = {'mimetype': 'webpage', 'duration': 10, 'name': 'Webpage 1', 'uri': 'http://www.google.com'}
r = requests.post(url, data=dataDict)
Add a new uploaded screenly image asset:
The minimum required values for adding a new image asset are name, mimetype, and duration.
The path to the file to be uploaded must also be supplied as a parameter to requests
import requests
dataDict = {'mimetype': 'image', 'duration': 10, 'name': 'Image 1'}
imgFile = {'file_upload': open('Z:/screenly/th.jpg', 'rb')}
#Note the use of forward slashes in this hard-coded example
#In practice, it would be better to use the tools found in the os module
r = requests.post(url, data=dataDict, files=imgFile)
Delete a screenly asset:
import requests
r = requests.delete(url)
Change order of screenly assets:
import requests
asset_value1 = '00784525f83c4fc391c2f52a2f54e5f2'
asset_value2 = 'd14b76a2ad83442597008f7a39e741a2'
url = 'http://192.168.0.100:8080/api/assets/order'
dataDict = {'ids': asset_value1 + ',' + asset_value2}
r = requests.post(url, data = dataDict)
Change screenly asset attribute:
import requests
asset_value = 'd14b76a2ad83442597008f7a39e741a2'
#Get the current settings
#Put the results into a dictionary object
dataDict = r.json()
#modify the value in the dictionary
# is_enabled = 0 makes inactive
# is_enabled = 1 makes active
dataDict['is_enabled'] = 0
#write the modified value back
vpetersson
Fri Oct 07, 2016 8:43 am
Nice work, ETexan.
ETexan
Fri Oct 07, 2016 4:42 pm
vpetersson wrote:Nice work, ETexan.
Thanks!
tonyhansen
Sun Oct 09, 2016 9:54 pm
[Edit: adding a bit more info here]
okay, I was successful in creating a pull request. I hope people find this mod useful.
I just filed the issue "add support for HTTP Basic Authentication #493", but instead of just being a complaint, it includes a complete fix within it. (The pull request went in as issue #495.) It's very straight forward, using bottle.py's auth_basic() decorator. I chose to do it using a new auth section within the server.conf configuration file:
[auth]
user=yourid
password=your pass phrase
If the values for user and password are empty, no password will be required.
Each of the @route()s that need to be protected get a new decorator:
@auth_basic(check)
check() is a function in server.py:
def check(user, passwd):
    return settings.check_user(user, passwd)
settings.py gets a new function:
    def check_user(self,user,pswd):
        try:
            au = self['user']
            pw = self['password']
            logging.info("check_user(" + user + "," + pswd + "), looking for (" + au + "," + pw + ")")
            if au == "" and pw == "":
                logging.info("check_user() requires no password")
                return True
            ret = au == user and pw == pswd
            logging.info("check_user() is returning %s" % ret)
            return ret
        except :
            e = sys.exc_info()[0]
            logging.info("check_user could not find a user " + str(e))
            return True
and the DEFAULTS configuration gets a new section as well:
    'auth': {
        'user': '',
        'password': ''
bjornhallberg
Thu Oct 13, 2016 7:14 am
Just discovered Screenly OSE / Pro and now have a quick question:
How does the Pro version fetch its data from the server? By timer or is it pushed on demand? Is it possible to run from a RPi that has no public IP / is behind a corporate firewall? Similar to how TeamViewer works?
vpetersson
Thu Oct 13, 2016 7:52 am
bjornhallberg wrote:Just discovered Screenly OSE / Pro and now have a quick question:
Hi Bjorn,
You can find the difference between Pro and OSE:
https://www.screenly.io/pricing/
Since those questions mostly relates to Pro, here are the answers for that:
Just using a regular HTTPS fetch.
Both. The primary method is push (using a websocket), but there's also polling in the case this fails.
Yes, that's the most common (and recommended solution). Providing the Raspberry Pi with a public IP is not recommended.
aamato
Fri Oct 28, 2016 12:01 am
Is it possible to upload automatically +400 videos? I don't want to do that manually.... thanks
vpetersson
Fri Oct 28, 2016 9:37 am
aamato wrote:Is it possible to upload automatically +400 videos? I don't want to do that manually.... thanks
In theory, yes. It would however require that you write a tool that either uses the API (https://github.com/wireload/screenly-os ... ocs/api.md) or directly on the device (copy to ~/screenly_assets and then insert them into the database).
teroenza
Wed Nov 02, 2016 11:16 pm
I installed Raspbian lite, then used the curl command to install Screenly after following the raspi-config setup instructions. It fails near the end of the installation, at the database migration step. Near the end of the error message it says it can't read the database file.
I tried running
python /home/pi/screenly/bin/migrate.py
and it complains "sqlite3.OperationalError: unable to read database file.
I tried the Screenly image itself, but nothing ever happens when booted. I'm using an original Rasperry pi (1st model).
I'm not sure how to export the terminal to a textfile if more information is needed.
vpetersson
Thu Nov 03, 2016 11:06 am
teroenza wrote:I installed Raspbian lite, then used the curl command to install Screenly after following the raspi-config setup instructions. It fails near the end of the installation, at the database migration step. Near the end of the error message it says it can't read the database file.
I tried running
Most likely, this is the result form either a corrupt SD card or a failed flash.
I would suggest that you do the following:
* Get a new SD card
* Re-download the disk image
* Verify the download using the MD5 file
* Flash it out again
bettybrdfrd
Fri Nov 04, 2016 3:21 pm
Relative beginner, so please be gentle. And I've tried to find an answer in the forums unsuccessfully.
I downloaded the Screenly image, and produced an SD card. But on power-on, I get a moment of login screen, then the vieo, repeated endlessly.
Note - I don't have a wired connection, just wireless. And I can't configure the wireless as I need to log in.
I can't log in as the video keeps playing (even trying Ctrl-Alt-F1 or whatever the magic is, with my attached keyboard)
Various threads suggest connecting to Screenly to stop the video. But I can't connect as I need to configure the wireless dongle first.
Solution 1: Use wired. I can't unless I take the Pi into a different room (where the router is) and work on the floor. OK, last resort.
Solution 2: Download a Raspbian image, configure wireless and then add screenly separately. OK, but shame I can't use the preconfigured SD card image.
Solution 3: Any suggestions?
teroenza
Fri Nov 04, 2016 9:40 pm
I did what you suggested, and get the same issue. The power light comes on, but nothing else, no boot sequence or anything. The pi should be fine as I can boot raspbian on it.
Would it be an issue using an microSD to regularSD converter? The pi1 has a full-size SD slot, and all I had around were micro cards.
[EDIT] I put the microSD card in my Raspberry pi 2, and got the same result. Lights on, no boot.
bjornhallberg
Sun Nov 06, 2016 6:21 pm
Hi Bjorn,
Great, thanks! I've been running Screenly Pro (Free) for a while now. Administering the screen works through the firewall but I have an intermittent problem with the system becoming unreachable. Always around midnight so I suspect some sort of switch reboot or whatnot. Should I muck around with the system to set up a cron reboot (or network refresh) every night or is there some sort of built-in mechanism for this? Perhaps it is better to change to OSE and just Teamviewer in to the network to administer the screen?
BAHbKA
Sun Nov 13, 2016 1:02 pm
is it possible to show content from a website which requires authentication?
karhyv
Thu Nov 17, 2016 1:14 pm
I have a strange problem. Several weeks now (from late August), Google Docs presentation refuses to run in Screenly because of Javascript (which apparently is missing). Nothing has changed in the setup. HTML pages without Javascript run fine.
I have rebuilt the system - twice - from the ground up from the original 4G SD image but the error persists. What is going on?
vpetersson
Thu Nov 17, 2016 3:49 pm
karhyv wrote:I have a strange problem. Several weeks now (from late August), Google Docs presentation refuses to run in Screenly because of Javascript (which apparently is missing). Nothing has changed in the setup. HTML pages without Javascript run fine.
It could be a change upstream in Google Docs perhaps. Is anyone else able to reproduce this?
hans12345
Fri Nov 18, 2016 12:54 pm
Thanks for Screenly! I would like to change the default End date for new assets, e.g. from 1 week to 1 year. Is that possible, maybe by changing a Python file? Which file would that be?
karhyv
Fri Nov 18, 2016 1:07 pm
Google Docs is certainly one suspect. I experimented with a test which basically just loads a Google Slides file instead of trying to display the slide show. I got an error message about "unsupported browser version". Uzbl getting old?
hans12345
Sat Nov 19, 2016 5:44 pm
While testing Screenly sometimes does not show a recently added asset. The asset is in the list, activated (ON) but does not show on screen. Only a reboot does. Is this a known bug or an error on my part? I am using a RPi 1b+ with a 8G SD with 5G available.
vpetersson
Sat Nov 19, 2016 7:33 pm
hans12345 wrote:While testing Screenly sometimes does not show a recently added asset. The asset is in the list, activated (ON) but does not show on screen. Only a reboot does. Is this a known bug or an error on my part? I am using a RPi 1b+ with a 8G SD with 5G available.
No this is not a known bug. Please do this:
* Try upgrading to the development branch
If that doesn't fix it, please open a Github issue with precise steps on how to reproduce the issue.
hans12345
Sat Nov 26, 2016 2:28 pm
Sorry about that: I could not reproduce the error, so I am very happy with Screenly now.
Also glad that Screenly is sturdy / resilient in the sense that it can startup OK without an ethernet connection and when that becomes available later the web interface is working without a restart. So that is good in a not so stable network environment!
Still open is my question a few entries back about changing the default end date of an asset.
BAHbKA
Sat Dec 03, 2016 9:57 am
After updating screenly yesterday, my raspberry is no longer connecting via wifi. My WIFI settings: "/etc/wpa_supplicant/wpa_supplicant.conf":
# WLAN
network={
    ssid="BAHbKA"
    psk="99999999"
# WLAN Handy HotSpot
network={
    ssid="Wasabi"
    psk="99999999"
I have 2 SD cards with different version of screenly both with same settings. The older version is always connecting without any problem while the updated version don't.
Can anyone help?
vpetersson
Sat Dec 03, 2016 2:47 pm
Yes, we should document this better, but please see this Github issue:
https://github.com/wireload/screenly-ose/issues/516
BAHbKA wrote:After updating screenly yesterday, my raspberry is no longer connecting via wifi. My WIFI settings: "/etc/wpa_supplicant/wpa_supplicant.conf":
# WLAN
network={
    ssid="BAHbKA"
    psk="99999999"
network={
    ssid="Wasabi"
    psk="99999999"
Can anyone help?
