danbsfc
Re: Screenly OSE -- Digital Signage for the Raspberry Pi
Mon Mar 02, 2015 3:57 pm
vpetersson wrote:
danbsfc wrote: HTTP/1.1 200 OK
Date: Mon, 02 Mar 2015 15:45:10 GMT
Server: Apache
X-Powered-By: PHP/5.4.23
Cache-Control: max-age=172800
Expires: Wed, 04 Mar 2015 15:45:10 GMT
Connection: keep-alive
Content-Type: text/html
Hmm, that looks reasonable.
Try this (on the pi):
python -c 'import requests; x = requests.head("http://www.google.com"); print x.status_code'
Replace "http://google.com" with your URL.
The code I get is 403
el gropo
Fri Mar 13, 2015 12:31 pm
Im new to Rasp Pi....Have installed Screenly OSE using instructions on site. I can upload video files and get them to play on the screen, great. However, when I Ctrl + Alt + F1 and try and login, the username 'pi' and password 'raspberry' do not work -'Login incorrect'. Any advice? I am trying to login to configure a wifi adaptor to work with the pi.
rsenio
Wed Apr 01, 2015 7:45 pm
I've noticed jpg's have stopped working all together. I even tried downloading the latest pre-built image to a new SD card, but the result is the same.
For the time being I have had to move my jpgs to a web server and display them using a URL asset.
forum6691
Thu Apr 16, 2015 7:32 pm
Hello guys
I've just installed screenly OSE on a raspberry PI 2. It's OK :)
I've 2 questions yet:
1- How to arrange the sequence of the pictures displayed. Must I use an alphabetic order to named the pictures as I read on an old post ?
2- How to change text and logo picture of the first screen displayed (this with the Manage Ip adress) ? And how to reduce the time of display for this first screen (it's too long for me) ?
Thank you
Cyril.
vpetersson
Wed May 06, 2015 9:13 am
Server: Apache
Ok, that's the problem. The web server is blocking the connections from Screenly.
Creator of Screenly (Screenly.io), the leading digital signage solution for the Raspberry Pi. Now hacking on WoTT (github.com/WoTTsecurity/agent),
Twitter: @vpetersson | vpetersson.com
vpetersson
Wed May 06, 2015 9:15 am
forum6691 wrote:Hello guys
Thank you
Cyril.
1) No you can re-order the list by simply dragging them around.
2) The easiest way to do this is to disable it entirely. You can do that in '.screenly/screenly.conf'. Just set 'show_splash' to 'False' (https://github.com/wireload/screenly-os ... ly.conf#L9).
vpetersson
Wed May 06, 2015 9:16 am
rsenio wrote:I've noticed jpg's have stopped working all together. I even tried downloading the latest pre-built image to a new SD card, but the result is the same.
Try run the upgrade script. We had an issue recently.
vpetersson
Wed May 06, 2015 9:19 am
el gropo wrote:Im new to Rasp Pi....Have installed Screenly OSE using instructions on site. I can upload video files and get them to play on the screen, great. However, when I Ctrl + Alt + F1 and try and login, the username 'pi' and password 'raspberry' do not work -'Login incorrect'. Any advice? I am trying to login to configure a wifi adaptor to work with the pi.
Those are the credentials for Screenly OSE. Perhaps it has to do with the keyboard. Some keyboards (such as the Apple keyboards) do not work well with the Raspberry Pi.
info_seeker
Thu May 07, 2015 10:30 am
I've downloaded and installed the OSE and working well. I require it to view an internal website page, the internal site is a sharepoint site with windows authentication.(ntml and kerberos)
If I access the site through chromium from the Pi it pops up the usual authenication box ( username and password). Good so far.
Hoewever when I access the webpage though uzbl-browser as a test it doesnt even prompt for a username and password, it goes straight to a 401 Unauthorised Error. (i was hoping to make use of the auth.py script to automatically set the username and password but cant if it doesnt )
Is there something I can do for this? It cant be the sharepoint site as its works as expected through chromium.
Thanks in advance.
vpetersson
Thu May 07, 2015 12:36 pm
info_seeker wrote:I've downloaded and installed the OSE and working well. I require it to view an internal website page, the internal site is a sharepoint site with windows authentication.(ntml and kerberos)
Thanks in advance.
Screenly (or rather the underlaying browser, UZBL), doesn't handle this kind of authentication very well. There is a workaround described here (http://www.screenlyapp.com/use-cases/da ... agios.html) that might work for you.
putridp
Thu May 07, 2015 2:12 pm
I love Screenly, it's (almost) a perfect solution for me.
One question, is there a way of doing a Ken Burns effect on slides (pan/zoom whilst a photo is displayed)?
Thanks!
vpetersson
Thu May 07, 2015 6:02 pm
putridp wrote: One question, is there a way of doing a Ken Burns effect on slides (pan/zoom whilst a photo is displayed)?
No, that's unfortunately not possible right now. Perhaps in the future, but it's almost impossible to do with the current browser. This is your best bet for that:
https://github.com/wireload/screenly-ose/issues/257
info_seeker
Fri May 08, 2015 10:50 am
Thanks for the quick reply. But I cant create secret URL on the sharepoint site as its out of my scrope.
When I connect to the share point from chromium (from the pi) it pops up an authorisation box but with uzbl-browser( from screenly) or epiphany it doesnt pop up a box and fails immediately with 401 error. Any help if you could point me in the right direction would be very helpful
vpetersson
Fri May 08, 2015 3:05 pm
info_seeker wrote:Thanks for the quick reply. But I cant create secret URL on the sharepoint site as its out of my scrope.
No, not really unfortunately. It's not supported. The only workaround I can think if is to set up an intelligent proxy in front of the Sharepoint server that would authenticate and then reverse proxy, but it's not a very clean solution.
illiac4
Wed May 13, 2015 4:24 am
Is there some kind of link that we can create a custom portfolio for stocks and then display them in numbers and graphs?
Like google portfolio or. something?
jarodsc
Tue Jun 02, 2015 2:04 pm
Hello
I installed Screenly OSE on a Raspberry pi B+, it works perfectly,but after few hours running, the images and videos continue displaying on TV, but I lost web/ssh connection to the RPI.
Image OK
SSH DOWN
WEB (8080) DOWN
PING OK
What you think about that?
vpetersson
Tue Jun 02, 2015 2:29 pm
jarodsc wrote:Hello
Image OK
SSH DOWN
WEB (8080) DOWN
PING OK
Hard to determine without logs. Please post the content of /tmp/screenly/*.log.
vpetersson
Wed Jun 03, 2015 7:46 pm
Hey guys,
Real quick: we currently have a campaign where give away Raspberry Pi-kits (Raspberry Pi 2, case, power kit, Micro-SD card etc) if you sign up for a 12 month plan of Screenly Pro.
You can order the bundles from here: https://goo.gl/OAneYV.
Thanks for all your support!
N3tguru
Mon Jun 22, 2015 5:57 am
We really like Screenly for our internal screens. We prefer not to expose the screens to the web. Any plans to offer a server for management and content grouping? SAS works for most customers, I understand that. But those who are in a regulated environment would benefit from a strictly internal (non internet facing) deployment.
Aside from having to replace our SD cards after 1 year of use, Screenly has worked well for us. The population of OSE screens has reached a point where management would be a welcome addition.
vpetersson
Mon Jun 22, 2015 9:11 am
N3tguru wrote:We really like Screenly for our internal screens. We prefer not to expose the screens to the web. Any plans to offer a server for management and content grouping? SAS works for most customers, I understand that. But those who are in a regulated environment would benefit from a strictly internal (non internet facing) deployment.
Hi there,
Sorry, but we do not have any plans of either releasing a self-hosted version of Screenly Pro nor to add that to OSE (as it would cannibalize Pro).
GiraffeDog
Thu Jul 02, 2015 11:07 am
Hi
I've been running OSE for a couple of months now, on an older Pi (not the Quadcore one, the one before that!). I love it!!
One thing I've noticed is that after several hours (there doesn't seem to be any set amount of time), the screen just goes black and we don't get any content displaying any more. I assumed it was memory, because we were displaying images as well as websites (weather) and videos that we had reduced in size using Handbreak.
The only work around I've managed to do was either to pull the power or as I have now done added a root CRON job to restart the device daily.
Is this a known issue?
GD
pHeoz
Thu Jul 09, 2015 8:41 am
GiraffeDog, isn't it the screen going off after a certain amount of time ?
If it is, try to add this line at the end of the /etc/rc.local file (above exit 0) :
sh -c 'setterm -blank 0 -powersave off -powerdown 0 < /dev/console > /dev/console 2>&1'
danbsfc
Mon Jul 13, 2015 2:19 pm
Crashing after a couple of hours since the last update on both my Pi's.
See log below...
Mon, 13 Jul 2015 11:17:36 Loading browser...
Mon, 13 Jul 2015 11:17:36 Browser loading file:///tmp/screenly_html/black_page.html. Running as PID 2330.
Mon, 13 Jul 2015 11:25:06 Generating asset-list...
Mon, 13 Jul 2015 11:25:10 Showing asset General Presentation (video)
Mon, 13 Jul 2015 11:25:12 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 11:27:52 Showing asset General Presentation (video)
Mon, 13 Jul 2015 11:27:53 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 11:30:32 Showing asset General Presentation (video)
Mon, 13 Jul 2015 11:30:33 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 11:33:26 Showing asset General Presentation (video)
Mon, 13 Jul 2015 11:33:27 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 11:36:08 Showing asset General Presentation (video)
Mon, 13 Jul 2015 11:36:09 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 11:38:56 Showing asset General Presentation (video)
Mon, 13 Jul 2015 11:38:58 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 11:41:45 Showing asset General Presentation (video)
Mon, 13 Jul 2015 11:41:47 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 11:44:34 Showing asset General Presentation (video)
Mon, 13 Jul 2015 11:44:35 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 11:47:18 Showing asset General Presentation (video)
Mon, 13 Jul 2015 11:47:19 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 11:50:07 Showing asset General Presentation (video)
Mon, 13 Jul 2015 11:50:08 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 11:52:50 Showing asset General Presentation (video)
Mon, 13 Jul 2015 11:52:52 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 11:55:39 Showing asset General Presentation (video)
Mon, 13 Jul 2015 11:55:41 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 11:58:20 Showing asset General Presentation (video)
Mon, 13 Jul 2015 11:58:21 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 12:01:00 Showing asset General Presentation (video)
Mon, 13 Jul 2015 12:01:02 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 12:03:42 Showing asset General Presentation (video)
Mon, 13 Jul 2015 12:03:43 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 12:06:21 Showing asset General Presentation (video)
Mon, 13 Jul 2015 12:06:22 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 12:09:06 Showing asset General Presentation (video)
Mon, 13 Jul 2015 12:09:08 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 12:11:53 Showing asset General Presentation (video)
Mon, 13 Jul 2015 12:11:54 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 12:14:35 Showing asset General Presentation (video)
Mon, 13 Jul 2015 12:14:36 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 12:17:16 Showing asset General Presentation (video)
Mon, 13 Jul 2015 12:17:17 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 12:19:57 Showing asset General Presentation (video)
Mon, 13 Jul 2015 12:19:58 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 12:22:43 Showing asset General Presentation (video)
Mon, 13 Jul 2015 12:22:45 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 12:25:26 Showing asset General Presentation (video)
Mon, 13 Jul 2015 12:25:28 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 12:28:12 Showing asset General Presentation (video)
Mon, 13 Jul 2015 12:28:13 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 12:30:54 Showing asset General Presentation (video)
Mon, 13 Jul 2015 12:30:56 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 12:33:40 Showing asset General Presentation (video)
Mon, 13 Jul 2015 12:33:42 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 12:36:34 Showing asset General Presentation (video)
Mon, 13 Jul 2015 12:36:36 current url is file:///tmp/screenly_html/black_page.html
Mon, 13 Jul 2015 14:17:41 Loading browser...
Mon, 13 Jul 2015 14:17:41 Browser loading file:///tmp/screenly_html/black_page.html. Running as PID 3136.
Mon, 13 Jul 2015 14:17:46 Scheduler init
Mon, 13 Jul 2015 14:17:46 update_playlist
Mon, 13 Jul 2015 14:17:46 Generating asset-list...
Mon, 13 Jul 2015 14:17:46 generate_asset_list deadline: 2030-01-13 15:44:00
Mon, 13 Jul 2015 14:17:46 update_playlist done, count 1, counter 0, index 0, deadline 2030-01-13 15:44:00
Mon, 13 Jul 2015 14:17:46 Entering infinite loop.
Mon, 13 Jul 2015 14:17:46 Last update: 2015-06-19 10:57:45.503958
Mon, 13 Jul 2015 14:17:48 Received non 200-status
Mon, 13 Jul 2015 14:17:48 get_next_asset
Mon, 13 Jul 2015 14:17:48 refresh_playlist
Mon, 13 Jul 2015 14:17:48 refresh: counter: (0) deadline (2030-01-13 15:44:00) timecur (2015-07-13 14:17:48.328315)
Mon, 13 Jul 2015 14:17:48 get_next_asset after refresh
Mon, 13 Jul 2015 14:17:48 get_next_asset counter 0 returning asset 1 of 1
Mon, 13 Jul 2015 14:17:48 Showing asset General Presentation (video)
Mon, 13 Jul 2015 14:17:48 Asset URI /home/pi/screenly_assets/2032e88fb03d4cffa4b4b906d30b7b74
Mon, 13 Jul 2015 14:17:48 Displaying video /home/pi/screenly_assets/2032e88fb03d4cffa4b4b906d30b7b74 for 154
Mon, 13 Jul 2015 14:17:50 current url is file:///tmp/screenly_html/black_page.html
vpetersson
Thu Jul 30, 2015 8:10 am
Hey guys,
Just wanted to post here that we're currently hiring one or two developers to join the Screenly team.
The job post is available here:
https://www.upwork.com/jobs/Python-Soft ... a16785957c
We'd love to have someone from the community join us. The candidate would work both on Screenly OSE and Screenly Pro.
mortti
Wed Aug 05, 2015 7:15 pm
Screenly web interface stopped responding.
Source: /var/log/supervisor/screenly-access.log
IP masked - - [20/Jul/2015 04:01:26] code 400, message Bad request version ('\xc0')
IP masked - - [20/Jul/2015 04:01:26] "??U?H Ԧf-??K?e?e?\?'??3????*?+?#?,?$?	?" 400 -
IP masked - - [20/Jul/2015 04:01:27] "GET //vtigercrm/vtigerservice.php HTTP/1.1" 404 32
Bottle v0.12.7 server starting up (using WSGIRefServer(fast=True))...
Listening on http://0.0.0.0:8080/
Hit Ctrl-C to quit.
Then I ran screenly update script:
Ensuring all Python modules are installed...
Running migration...
bash: line 31: 9223 Illegal instruction python $SCREENLY/misc/migrate.py
Restarting app-server...
Got it working again. Just to ask what was that all about and how to prevent it from happening again.
Thanks for your support.
