Page 25 of 45
Re: Screenly OSE -- Digital Signage for the Raspberry Pi
Posted: Thu Jan 08, 2015 2:50 pm
by dansnell
I will test with a different SD card and see if that fixes the issue.
Just wondering also if just switching off the TV could cause issues? We have it running in a cafe and they turn off the tv at the end of the day and turn it in the morning to start the system.
Daniel
Posted: Thu Jan 08, 2015 2:54 pm
by vpetersson
dansnell wrote:I'm using the disk image.
If you haven't made any other modifications to the system, I would say that it is most likely hardware related. Try a different SD card (and make sure to only use Class 10 ones).
Posted: Sat Jan 31, 2015 10:04 pm
by alphawere
I am having issues with screenly OSE and it seam that no matter what images i upload ones from the net or that i have created in the gimp all are 1920 by 1080 the only content that shows is the big buck bunny
This is a downloded img from your site
Thanks in advance
AlphaWere
Posted: Sun Feb 01, 2015 12:53 pm
by vpetersson
alphawere wrote:I am having issues with screenly OSE and it seam that no matter what images i upload ones from the net or that i have created in the gimp all are 1920 by 1080 the only content that shows is the big buck bunny
Make sure that the time of the system is properly set. This is a common issue, since the Raspberry Pi doesn't have any built-in Real-time Clock. (RTC).
Also, double check and make sure that the assets shows up under 'active' .
Posted: Tue Feb 03, 2015 11:13 pm
by alphawere
I dont know if this has been brought to your attention but but you have a custom domain name server set up in the /etc/resolv.conf I found this out due to the fact I could not get the PI running Screenly OSE to connect to the internet via ping execpt only when I used googles IP address (216.58.210.3) this was the main problem i was having with viewing new content as the Pi was not able to contact with any NTP servers.
May i suggest that you use the google name sever as shown below
nameserver 8.8.8.8
Posted: Wed Feb 04, 2015 8:16 am
by vpetersson
alphawere wrote:I dont know if this has been brought to your attention but but you have a custom domain name server set up in the /etc/resolv.conf I found this out due to the fact I could not get the PI running Screenly OSE to connect to the internet via ping execpt only when I used googles IP address (216.58.210.3) this was the main problem i was having with viewing new content as the Pi was not able to contact with any NTP servers.
nameserver 8.8.8.8
By default Raspbian (as well as our pre-installed image) uses DHCP. As such, the /etc/resolv.conf is populated by the DHCP data.
Posted: Wed Feb 04, 2015 11:35 am
by alphawere
Yes but by default the Raspbian image uses googles 8.8.8.8 but yours had an internal 192.168.1.* based ipaddress could you please double check this fact
Posted: Wed Feb 04, 2015 11:37 am
by vpetersson
alphawere wrote:Yes but by default the Raspbian image uses googles 8.8.8.8 but yours had an internal 192.168.1.* based ipaddress could you please double check this fact
We'll look into it, but it should be overridden on boot by the DHCP server. The only case it wouldn't be overridden would be in case the DHCP server doesn't provide a DHS (and IMHO is then incorrectly configured).
Posted: Wed Feb 04, 2015 4:29 pm
by alphawere
Something i have just noticed i wanted to crate a screen from a HTML file with iframes of local bus times but when i select webpage from the asset type on the upload page it automaticly redirect me to the Public URL page at the moment i can get by this by leaving it as an image file then correcting it after upload
Thanks AlphaWere
Posted: Wed Feb 04, 2015 4:42 pm
by vpetersson
alphawere wrote:Something i have just noticed i wanted to crate a screen from a HTML file with iframes of local bus times but when i select webpage from the asset type on the upload page it automaticly redirect me to the Public URL page at the moment i can get by this by leaving it as an image file then correcting it after upload
Thanks AlphaWere
You can't upload a HTML page. You need to serve it via a web server.
Posted: Wed Feb 04, 2015 11:03 pm
by alphawere
it seams to me that screenly is saying that it can see screenshot also the work around i mentioned works
Posted: Thu Feb 05, 2015 8:48 am
by vpetersson
I guess that's somewhat of a usability bug. 'Web page' refers to remote pages.
Posted: Fri Feb 06, 2015 1:11 pm
by peterA
Hi.
Just want to share my experiances on Screenly OSE with you.
I have been running Screenly OSE for over a year on 2 screens as information for the emloyees in 2 different lunchrooms.
A couple of days ago both of them halted, after restart the worked for a couple of hours just to halt again.
The only common between them is that the show webpages from the same server.
The solution was to disable the firewall.
/Peter
Posted: Tue Feb 10, 2015 9:52 pm
by marque1968
I tried Screenly on a Raspberry Pi 2 B, but the Digital Signage doesn't start. Port 8080 is available and I can add screens (from my notebook), but the Pi just shows me rasberrian with no cursor...
Is it me messing up, or is screenly not happy with the new hardware?
Posted: Wed Feb 11, 2015 5:35 pm
by vpetersson
marque1968 wrote:I tried Screenly on a Raspberry Pi 2 B, but the Digital Signage doesn't start. Port 8080 is available and I can add screens (from my notebook), but the Pi just shows me rasberrian with no cursor...
We're actually still working on this. The work is a bit behind schedule, but we hope to get there soon. Here's the relevant issue on Github:
https://github.com/wireload/screenly-ose/issues/256
Posted: Sun Feb 15, 2015 8:48 pm
by MaxR
Hi! Is it possible to manage content locally on Pi? It would help me a lot. Maybe I need to install anything additional?
Thank you!
Posted: Sun Feb 15, 2015 11:29 pm
by vpetersson
MaxR wrote:Hi! Is it possible to manage content locally on Pi? It would help me a lot. Maybe I need to install anything additional?
Thank you!
If you mean by managing content on the filesystem, this it not supported. You can however manage assets in the web interface.
Posted: Mon Feb 16, 2015 8:36 am
by MaxR
Thank you for reply!
Now I've got exactly the same issue. Is there any fixes on it?
One of the assets I display is a webpage with form authentication, as a work-around I've plugged a keyboard into the pi and type in the username/password when the session expires (about once every 2 weeks, which is fine). At some point, screenly lost the ability to take a keyboard input (that is to say rasbian detects and uses the keyboard but the browser that screenly uses can not). Was this an enhancement or is there an option to change this?
Posted: Thu Feb 26, 2015 8:55 am
by vpetersson
Hey guys,
I just wanted to let you know that Screenly OSE (and Pro) now supports the new Rasbperry Pi 2 (B+).
Disk-images and installation instructions can be found here:
http://www.screenlyapp.com/ose.html
Posted: Mon Mar 02, 2015 8:57 am
by danbsfc
Hi!
May I first begin by saying thank you for creating Screenly! We tried many different solutions but since finding Screenly, we've settled on it and love the way it performs. Also, it doesnt crash! This was an issue we had with other solutions. Screenly appears to be incredibly stable which is incredibly important.
One question, if I try to add a link to our website as an asset, it replies with
Server Error: Could not retrieve file. Check the asset URL.
Is this because our pages are .PHP and not .HTML?
I could always convert to HTML and upload to a different directory but using the native page would be ideal.
Thanks in advance!
Dan
Posted: Mon Mar 02, 2015 10:39 am
by vpetersson
danbsfc wrote:Hi!
Thanks for the kind words, Dan.
In terms of PHP and HTML files -- neither is supported. Screenly can display HTML assets, but not serve them. You will need to host them on an external webserver and point Screenly to the IP/URL.
Posted: Mon Mar 02, 2015 3:30 pm
by danbsfc
vpetersson wrote:
danbsfc wrote:Hi!
Sorry. Basically, I have tried adding our website via the add asset as a url but each time it throws an error. If i try adding http://www.google.co.uk, it works as does http://www.bbc.co.uk for example.
If i were to save the webpage as a html file instead of a php and re-upload to our web hosting, would this fix it?
EDIT: Even after uploading a HTML file to our webserver and pointing Screenly to it, I still get the error message "server error could not retrieve file. check the asset url"
Posted: Mon Mar 02, 2015 3:44 pm
by vpetersson
danbsfc wrote: If i were to save the webpage as a html file instead of a php and re-upload to our web hosting, would this fix it?
Yeah, that's unlikely to fix it.
This is most likely some strange header issue. We've seen that a few times in the past where websites will send the wrong header.
Can you post the output of:
curl -I http://[your url]
Posted: Mon Mar 02, 2015 3:45 pm
by danbsfc
HTTP/1.1 200 OK
Date: Mon, 02 Mar 2015 15:45:10 GMT
Server: Apache
X-Powered-By: PHP/5.4.23
Cache-Control: max-age=172800
Expires: Wed, 04 Mar 2015 15:45:10 GMT
Connection: keep-alive
Content-Type: text/html
Posted: Mon Mar 02, 2015 3:54 pm
by vpetersson
danbsfc wrote: HTTP/1.1 200 OK
Server: Apache
Hmm, that looks reasonable.
Try this (on the pi):
python -c 'import requests; x = requests.head("http://google.com"); print x.status_code'
Replace "http://google.com" with your URL.
