Page 43 of 44
Re: Screenly OSE -- Digital Signage for the Raspberry Pi
Posted: Sat Aug 11, 2018 4:55 pm
by vpetersson
I can't see any reason why that wouldn't work. Only caveat is that the website cannot be too heavy.
itgadgets wrote:
Sat Aug 11, 2018 3:17 pm
Hi all,
First post here and new to Raspberry Pi
Can Screenly run just one item? i.e. one video file or web page
Reason i ask is that I am looking at setting up a display with 4 separate images using 4 Raspberry Pi each displaying one video, web page or image. They would be connected to a HDMI Quad Screen Multiviewer so we can have all 4 displaying at once or someone could select which one was required to be viewed at full screen.!
The information displayed needs to be view-able at all times as it is for an emergency service, no interaction is required for the displayed info.
If I am looking at this all wrong or there is a better solution please let me know! My original idea was to run it all from a PC with mutliple connections going to the Multiviewer, this was going to be an issue because the display is going to be in another room to the PC.
Posted: Tue Aug 21, 2018 7:08 pm
by jishac
There are no clear instructions on how to enable Screenly to not require an Internet connection. There is reference to an "offline" mode, but the page only mentions that it is possible and not how to properly configure the software.
Furthermore a quick glance at the source seems to indicate that the use of "enable_offline_mode" is no longer checked/used. As an additional note, the Raspberry Pi has a RTC which is configured and working.
Is there a way to get Screenly to bypass the default gateway (Internet) check and function without connectivity?
Thanks!
Posted: Wed Aug 22, 2018 4:27 pm
by amolodykh
Hi all,
Hi!
I don't know if this is a good solution, I also did not try to use a HDMI Quad Screen Multiviewer, but I think it should work well. You really can install Screenly OSE on your Pi's and display only one asset on each of them (don't forget to set duration field in the web interface, by default an asset becomes inactive after a few days).
Posted: Wed Aug 22, 2018 4:52 pm
by amolodykh
Thanks!
It seems recently we have received a similar question. Please take a look, here is the full answer https://support.screenly.io/hc/en-us/co ... -SSID-WiFi
Posted: Wed Aug 22, 2018 5:12 pm
by jishac
Thanks!
Hi amolodykh,
That answer is with regard to disabling the hotspot (which I've done) and the user has hardwired connections. My Pi's do not have ANY connection to the outside world. I feel this is often left out of the test cases. Rather the Pi will reach out and get an address only during periods where content will be uploaded or changed.
Thanks!
Posted: Thu Aug 23, 2018 6:07 am
by amolodykh
Thanks!
Hi amolodykh,
Thanks!
okay, apparently I did not quite understand you. could you please formulate what exactly you want?
Posted: Thu Aug 23, 2018 2:14 pm
by jishac
For screenly to work "offline" when no outside Internet connection is present at all. Display local content and local webpages only. Right now the server is hanging up due to the check in lib/utils.py for a default gateway.
I have tracked down the issue and will be creating a pull request with my suggestion of a fix.
[edit]
Here is a link to the pull request:
https://github.com/Screenly/screenly-ose/pull/885
Token Based Authentication
Posted: Wed Aug 29, 2018 11:03 pm
by galedon70
Is there a way to add the ability for token based authentication to Screenly in the OSE or Pro?
Re: Token Based Authentication
Posted: Mon Sep 03, 2018 10:06 am
by vpetersson
Not yet. It's however something that we have for the roadmap for Pro.
Posted: Sat Sep 08, 2018 12:41 am
by cable35
I would like to schedule assets to display by Day of the week
Like at our church i would want on Sunday at 8am to display our RTMP stream.
Then Sunday at 9am stop displaying the stream and display slide show of images.
Then Sunday at 10:30 am stop the slide show and display our RTMP stream again.
Then Sunday 11:30 until Saturday display the slide show of images again during the week.
Is there anyway to do this with OSE?
Thanks!
Posted: Mon Sep 10, 2018 10:26 am
by vpetersson
Thanks!
No, this isn't something that is supported in OSE at the moment.
Posted: Wed Sep 19, 2018 5:26 pm
by drconrad
We have been having issues for awhile now with the install failing for Screenly. During the install, everything goes fine except for the the final task of asset database creation. We are getting the following error.
TASK [screenly : Create default assets database if does not exists] ********************************************
An exception occurred during task execution. To see the full traceback, use -vvv. The error was: ImportError: cannot import name shell_loader
fatal: [localhost]: FAILED! => {"msg": "Unexpected failure during module execution.", "stdout": ""}
to retry, use: --limit @/home/pi/screenly/ansible/site.retry
PLAY RECAP *****************************************************************************************************
localhost : ok=46 changed=11 unreachable=0 failed=1
At first we thought it was a bad sd card, but we got a new one and we are still having this issue. I've tried running the install again with --limit @/home/pi/screenly/ansible/site.retry on the end, still erroring out. I haven't been able to find any info online about this at all, and don't really know jack all about Linux. Thank you!
Posted: Thu Sep 27, 2018 2:42 am
by rusko124
Hi drconrad, can you tell which version of ansible you use?
Posted: Tue Oct 09, 2018 7:14 pm
by hubcity344
I have tried to install Screenly using the following link:
https://www.screenly.io/ose/
Option 1 works, but I cannot access the Pi at all once it's installed, other than to add media. I need to be able to SSH into the device for security purposes, so this is not an option.
Option 2 is the same as option 1.
Option 3 is missing some instructions and does not work. Once I get ready to install the software, there are 4 prompts, one of which asks about disabling Screenly Network Manager. No matter how I answer, it tells me it is not installed and installation halts. This does not work.
Option 4 has been giving me grief. I can load the image and get it going on one connection/port, but when I plug it into another port on the same network subnet, it will turn on, but not connect. There is currently a working device in that port, so I know there is Internet access.
This just seems like an extremely complicated process to get digital signage working.
Any thoughts?
Posted: Wed Oct 10, 2018 6:52 am
by rusko124
Any thoughts?
Hi , hubcity344! Can you answer a few of my questions?
For 1 and 2 options: Can you try use CTRL+ALT+F1 to log in to the console?
For 3 option: Can you try install Network Manager?( sudo apt-get install -y network-manager)
Posted: Tue Nov 13, 2018 5:25 pm
by jokas
Hi there,
i also tryed to connect my Pi with Screenly over Wlan.
What do I have to do, to disable the wlan access data overwrite by Screenly on every reboot and set my main Wlan Router as accesspoint for Screenly?
Posted: Tue Nov 13, 2018 5:35 pm
by jokas
i also tried to connect my Pi with Screenly over Wifi to my Wlan Router, but it doesn't work.
Where do I have to put the configuration data, and is there more to do to prevent the overwrite after a reboot.
Would be great to get some help here, to get access to Screenly over Wifi.
regards,
jo
Posted: Wed Nov 14, 2018 4:26 am
by rusko124
regards,
jo
Hi, jokas! Can you tell me what version of Screenly-OSE you are using and what version of Raspberry Pi you have, please?
It is also possible you will be able to find useful information here https://support.screenly.io/hc/en-us/co ... ew-network.
Posted: Wed Nov 14, 2018 10:53 am
by jokas
Hi rusko,
I use the latest versions of Hard- and Software. I figured out, that there was an Issue with the 5Ghz Wifi. With 2,4 it works.
But now I got the next problem:
In the settings is a option: Reset wifi config
After clicking I get a Info "Reset was successful. Please reboot the device."
After reboot the recent Wifi Connection will used again.
Did I missed something? How do I change the Wifi connection?
Posted: Wed Nov 14, 2018 11:28 am
by rusko124
Hi rusko,
jokas, Can you try reproduced this steps:
- Delete file initialized from /home/pi/.screenly/ or click reset wifi in web interface
- Remove or replace files from /etc/NetworkManager/system-connections/
- sudo cp /home/pi/screenly/ansible/roles/network/files/wifi-connect.service /etc/systemd/system/
- sudo systemctl enable wifi-connect
- rm -f /home/pi/.screenly/disable_manage_network
- Reboot
Posted: Fri Dec 21, 2018 6:00 am
by devbeans
i have done some modifications to the source code and now i want to create a custom disk image of that code. so how to do that?
Posted: Wed Dec 26, 2018 6:41 am
by mikewalla
We are using our own page as signage with experimental built of Screenly. Despite having set up the local time correctly, the local time (javascript) on the page keep returning GMT+0. This is not the case when opened from another device. Anyone having the same issue? One more thing, we tried with stable built, and the time was correct, but some of CSS just didn't work. Here the script:
                var d = new Date()
                document.getElementById("time").innerHTML = d;
Posted: Thu Jan 03, 2019 7:44 pm
by Stefan_Rasp
i tried to make a disk image with the file "create_screenly_ose_build.sh", but every time the same result:
+ '[' -b /dev/sdb ']'
+ echo '/dev/sdb is not a device. Exiting.'
+ exit
someone can help me?
thanks in advance
Posted: Mon Jan 07, 2019 8:15 am
by rusko124
Stefan_Rasp wrote: Hi,
+ exit
thanks in advance
Hi!
Currently, Screenly-OSE uses pi-gen to build the image
https://github.com/Screenly/pi-gen
Posted: Fri Jan 11, 2019 8:03 am
by Stefan_Rasp
Thanks for your answer.
I tried to use the same procedure Pi-Gen using the Screenly files.
That's correct?
Or can you kindly explain me the right steps?
Thanks a lot
