dendesigns
Re: Screenly OSE -- Digital Signage for the Raspberry Pi
Thu Oct 15, 2015 11:59 am
Thanks for answer in quick. Great app by the way...we're really enjoying Screenly - keep up the good work :)
forum6691
Thu Oct 15, 2015 3:37 pm
forum6691 wrote:Hi everybody
I have a problem with diplay on my raspberry PI 2
I 've initialy used a video converter HDMI to VGA to plug on Big TV screen.
The max capacity of TV screen is 1360*768 at 60 Hz in progressive mode, but it seems that the 1024*768 resolution gives better pictures
So, I change resolution to 1024*768 in the .screenly.conf file .
With this configuration, it's OK with adapter VGA, but if I switch hdmi cable instead, I get the video during the boot of the raspberry, but when it swith to the graphic mode to display the picture of screenly, th screen stays black definetively !
I'm annoyed, because with VGA, I can't have the sound, so I would use the HDMI cable.
Is there a special parameter to configure the resolution very finely (resolution and frequency) to correct my problem with direct HDMI connection ?
Thanks.
Cyril
Hello. No one has responded to my initial issue. Is there anybody who could have an idea on this problem. I suppose it's a configuration problem with my Xserver, but what files must I trim to resolve my problem. Changes on the screenly.conf file are not sufficient !
Thank you for your help.
Cyril.
vpetersson
Fri Oct 16, 2015 10:40 am
Thanks.
Cyril
Cyril.
Officially, we only support HD resolution in Screenly. That said, it might work in other resolutions too.
This is however more of a Raspbian issue than a Screenly issue. You might need to reconfigure X11 to work with that resolution. The resolution in screenly.conf only affects some elements in Screenly. It doesn't change anything in how X11 work.
Creator of Screenly (Screenly.io), the most popular digital signage solution for the Raspberry Pi and Sonar (databat.io), Google Analytics for the physical world.
Twitter: @vpetersson | blog.viktorpetersson.com
forum6691
Sat Oct 17, 2015 5:17 am
Thank you for the information Victor.
However,how the parameter of resolution define in the sreenly.conf acts ont the X server. It seems , it surcharge a value in the X server, but which ?
I 'd like to be sure that if I modify the resolution in the X server, this one will not be overwrite by screenly ?
vpetersson
Sat Oct 17, 2015 9:27 am
forum6691 wrote: However,how the parameter of resolution define in the sreenly.conf acts ont the X server. It seems , it surcharge a value in the X server, but which ?
Screenly does not change any resolution in X11. Those settings are merely for internal usage within the application.
forum6691 wrote: I 'd like to be sure that if I modify the resolution in the X server, this one will not be overwrite by screenly ?
No, Screenly will not overwrite these values.
forum6691
Sat Oct 17, 2015 4:04 pm
After 1 hour and multiple reboots, I 've found the problem with my HDMI interface.
I 've edited the /boot/config.txt file of my raspberry and added the line config_hdmi_boot=11 to force to the maximum the level of signal on the HDMI connector of the raspberry, and it's OK anymore.
drin_pogi
Sat Oct 17, 2015 7:14 pm
Hi. How can I change the color blue of webpage? I want to change it to color green. Thank you.
KallieK
Mon Oct 26, 2015 3:40 pm
Greetings Everyone,
I've recently loaded Screenly-OSE on my Raspberry Pi 2. Is there a limitation displaying Concerto content?
I just get a black screen when I add my concerto web page as an asset on Screenly-OSE.
BTW: Using the latest Concerto 2.3.0 on Ubuntu 14
vpetersson
Mon Oct 26, 2015 5:13 pm
KallieK wrote:Greetings Everyone,
We do not officially have any Concerto integration, and we cannot unfortunately allocate any resources to this right now for this. That said, if you're happy we're happy to learn more about this if you're making any progress.
KallieK
Mon Oct 26, 2015 6:06 pm
Thanks for the quick reply :)
I'll keep at it. I am able to see the Concerto content using Epiphany and Iceweasel... I like the Screenly Pro edition but for my implementation the site is in a rural area in South Africa with limited and at times no internet connectivity, so I'm forced to load the Digital Signage content from a local resource (server on the local LAN).
Screenly-OSE is perfect for local 'isolated' implementations which would make a Screenly player with Concerto CMS perfect.
Is there anyone on this forum that have had success in this regard? ( Rpi2 + Screenly-OSE ----> Concertp 2.3.0 )
darrellj
Tue Nov 03, 2015 6:34 pm
Hey Guys!
So I have just installed Screenly OSE on my Raspberry PI 2 to equip our Lobby TV with Digital Signage Capabilities. I have noticed that periodically, the connection to the IP address to manage Screenly times out and is unreachable. A quick fix for this is to unplug and re-plug the device. That, however, is not a feasible solution as our TV is mounted pretty high. I have noticed that the connectivity returns hours later and everything works fine again. I'm not sure whats causing this issue. Any ideas?
vpetersson
Tue Nov 03, 2015 7:40 pm
darrellj wrote:Hey Guys!
Are you using the image or the self-installed version?
Also, have you upgraded to the latest version?
darrellj
Tue Nov 03, 2015 8:42 pm
Also, have you upgraded to the latest version?[/quote]
I'm using the self installed version. It appears to be the latest version. Pulled it from here: https://raw.github.com/wireload/screenl ... install.sh.
vpetersson
Tue Nov 03, 2015 9:37 pm
darrellj wrote: I'm using the self installed version. It appears to be the latest version. Pulled it from here: https://raw.github.com/wireload/screenl ... install.sh.
Try using our disk image instead. It has a number of enhancements and might work better for you.
darrellj
Tue Nov 03, 2015 10:26 pm
Will do! Is WiFi support already configured out the box?
RaspiNewb
Tue Nov 17, 2015 11:08 am
Hey Guys,
i just set up Screenly on my Raspi. Everything goes as well and i manually changed the Standard EndTime to 10 Years in
the future in the screenly-ose.js.
So i just read Screenly is able to playback rtmp Links via OMXplayer?
But i dont be able to set up one of these.
I just changed the accepted URL Types in the utils.py file so i could save the rtmp link in the backend but there comes
just this error
Server Error: No connection adapters were found for 'rtmp://pssimn24livefs.fplive.net/pssimn24live-live/_definst_/stream1'
where i have to configure the adapter?
vpetersson
Thu Nov 19, 2015 12:18 pm
RaspiNewb wrote:Hey Guys,
just this error
I suggest you open an Issue for this on Github.
mmt-8
Sat Nov 28, 2015 3:35 pm
Hi guys, I have a very basic question of Screenyl's workflow. It seems to be really nice application but isn't there a server software where you can manage your screens? How can you define screens and monitor them?
sunlight335
Mon Nov 30, 2015 1:53 pm
I am trying to install screenly with berryboot and keep getting this error.
http://tinypic.com/r/10eovb5/9
If anyone can help that would be
great!
vpetersson
Mon Nov 30, 2015 2:25 pm
mmt-8 wrote:Hi guys, I have a very basic question of Screenyl's workflow. It seems to be really nice application but isn't there a server software where you can manage your screens? How can you define screens and monitor them?
Yes, there is. That product is called Screenly Pro (https://www.screenlyapp.com/tour/).
vpetersson
Mon Nov 30, 2015 2:27 pm
sunlight335 wrote:Hi,
great!
Screenly is not currently supported by BerryBoot, but we have a beta version of a BerryBoot image available here:
http://releases.screenlyapp.com/2015-11 ... ryboot.img
Feel free to give it a shot and let us know how it goes.
sunlight335
Mon Nov 30, 2015 3:21 pm
I got it working.
It does not let me expand the filesystem in the config.
It says /dev/root does not exist or is not a symlink. Dont know how to expand.
Dies this prevent me from using any screenly features ?
Regards
vpetersson
Mon Nov 30, 2015 4:28 pm
sunlight335 wrote:I got it working.
Regards
Yes, that's probably because the image you're using isn't built for BerryBoot (which uses a slightly different setup). Try the one above.
karhyv
Wed Dec 09, 2015 7:33 pm
I am running on Screenly a web page which should open a new window but it gets blocked. The same web page on a "normal" computer behaves similarly if popups are blocked in web browser. Is there a popup blocker in Screenly (uzbl?) and how it can be disabled?
vpetersson
Wed Dec 09, 2015 8:07 pm
karhyv wrote:I am running on Screenly a web page which should open a new window but it gets blocked. The same web page on a "normal" computer behaves similarly if popups are blocked in web browser. Is there a popup blocker in Screenly (uzbl?) and how it can be disabled?
No, there is no pop-up blocker per se. Instead, I think that's by design in UZBL. I think a better solution would be to resolve this issue in the webpage, as you would normally want to prevent any kind of pop-up like behavior.
