mkeeley
Re: Free Pascal compiler for the Pi (freepascal.org)
Fri Mar 09, 2012 2:34 pm
Delphi was probably my favorite "language" when programming was my full time job, so good to hear open pascal will be available.
Conn
Thu Mar 15, 2012 10:05 pm
+1 for Pascal and Lazarus on Rpi!
I'll code my software with Pascal if I can.
Cheers,
Conn
jwdietrich
Sun Mar 25, 2012 7:33 pm
Lazarus is a great tool for cross-platform programming. Therefore it would be great to have it on the Pi, too; this would enable development with the same source files for Windows, desktop Linux, Android, Mac OS X and Pi.
For some purposes, Lazarus may be inefficient, e.g. development of embedded applications not requiring any GUI. Here, pure Free Pascal will be a great, and still cross-platform solution.
fredycc
Mon Mar 26, 2012 3:52 pm
Lazarus / FPC is an excellent alternative programming development, I work on windows, linux and mac os x with good results, it would be great to see it working in Pi.
Regards
wt536
Sat Apr 14, 2012 11:09 pm
spacetime said:
Wow, it seems that the Pascal community does exist
I still believe in Pascal - easy to write and easy to read.
@Cephas Borg
I was under impression that I am the only one who likes Turbo Pascal so much!
You are not alone. My Pascal code used far less disc than the lads' C++.
The .DFM in Borland C++ is a Delphi Form, so the heritage shows.
plugwash
Sun Apr 15, 2012 12:37 am
plugwash said:
With freepascal it depends if you are running an "armel" distro (basic EABI calling convention) or an an "armhf" distro (eabi vfp calling convention). Currently freepascal doesn"t support eabi vfp so if you use an armhf distro you won"t be able to link pascal programs against c libraries correctly.
Just to let you know i've fixed this now. I haven't tried a "hardfloat for pi" configuration yet (only a v7 hardfloat configuration) but I don't expect there to be any problems and intend to put a correctly configured package in the "armhf for pi" repositry in due time.
pmalheiros
Mon May 14, 2012 12:27 pm
FYI I've managed to install FPC 2.6.0 and Lazarus 0.9.30.4 in my new Raspberry PI. I used debian 6 and installed the freepascal available in Sourceforge.
Still needs more testing but I'm happy with the results.
egroc
Wed May 16, 2012 2:29 pm
Hi pmalheiros, can you write simple instructions about how to install lazarus on Pi? Where I can find lazarus for ARM?
Thanks.
plugwash
Wed May 16, 2012 9:33 pm
apt-get install lazarus
Nobody
Sat Jun 02, 2012 11:45 am
egroc wrote:Hi pmalheiros, can you write simple instructions about how to install lazarus on Pi? Where I can find lazarus for ARM?
Thanks.
plugwash wrote:apt-get install lazarus
Well unfortunately that does not work (with my debian image). "sudo apt-get install fpc" however does.
plugwash
Sat Jun 02, 2012 11:53 pm
hmm, seems lazarus isn't in squeeze armel, it is in wheezy armel though.
Nobody
Sun Jun 03, 2012 12:47 pm
plugwash wrote:hmm, seems lazarus isn't in squeeze armel, it is in wheezy armel though.
I think I know how I could go around this problem - but what does that actually mean? What's the difference between "squeeze" and "wheezy"?
plugwash
Mon Jun 04, 2012 12:44 am
Debian releases are given codenames (named after toy story characters). squeeze is the current stable release, wheezy is currently "testing" and will become the next stable release.
pbreneman
Thu Jun 07, 2012 12:41 pm
I hope to have access to a friend's Raspberry Pi soon to do more testing with Free Pascal.
I already have a number of minimal distributions of Free Pascal on this educational project page:
http://www.turbocontrol.com/monitor.htm
Environment Monitoring Programs
Information and example programs for an educational programming project.
I've recently added ARM Linux files on these pages (using Qemu for my testing):
- Hello World
- Easy Email
- Easy fpGUI
- Simple Window
As soon as I'm able to get my hands on a Raspberry Pi I hope to add a new file on this page:
- Simple Serial
If anyone here could test any of these and let me know how they work that would be very helpful to me.
I hope that the nice Free Pascal tools can be used a lot on the Raspberry Pi.
Regards,
Paul Breneman
stafil
Thu Aug 09, 2012 10:07 pm
Hi, I installed 2012-07-15-wheezy-raspbian to qemu. After entering sudo apt-get install fpc to start the installation and is not successful. Please help. thank you
avra
Mon Oct 29, 2012 10:49 am
CodeTyphon/Lazarus/FreePascal can create executables for Raspberry PI (with download link for all needed libraries and dependencies and PI emulator for Windows if you don't have the real board yet):
http://www.pilotlogic.com/sitejoom/inde ... spbian-app
Examples of accessing PI I/O pins:
http://www.lazarus.freepascal.org/index ... 404.0.html
http://www.lazarus.freepascal.org/index ... l#msg96604
plugwash
Mon Oct 29, 2012 11:52 am
stafil wrote:Hi, I installed 2012-07-15-wheezy-raspbian to qemu. After entering sudo apt-get install fpc to start the installation and is not successful. Please help. thank you
If you want help with problems like this you need to tell us what errors you are getting.
mikew
Tue Nov 20, 2012 9:58 pm
Many thanks for these clear instructions. They enabled me to successfully install Lazarus on a clean new Pi with Squeezy, with no serious errors as far as I can see. Now to get down to the real stuff - trying to compile somebody else's software...
jwdietrich
Tue Apr 30, 2013 6:27 pm
More detailled instructions are to be found at http://wiki.lazarus.freepascal.org/Laza ... spberry_Pi .
