PI Red transparent case from Element14 Don't buy it
Posted: Fri Jul 20, 2012 12:56 am
by labidus
Its a piece of junk and its too big, really to big... 8$ wasted, its something that should cost no more then 2$...
I prefer to say it before other get it and regret it! :)
Re: PI Red transparent case from Element14 Don't buy it
Posted: Fri Jul 20, 2012 8:59 am
by nadnerb
Can you post some photos of the case and with the pi installed.
Posted: Fri Jul 20, 2012 5:35 pm
by respOnder
I also have one of these cases from Element 14, called the 'Pi sandwich'. The posts that lock the 2 halves together broke after a couple of times trying to take them apart. It just uses a tight fit between a pin and post, so it's difficult to take apart or assemble.
Now if I pick up the case just holding the top half, the bottom wants to fall off! I already dropped my Pi board on the ground once accidentally.
Wouldn't reccomend this case...
Posted: Sun Jul 22, 2012 3:35 am
by labidus
After some time to play with my pi that i received friday, the case is no good.
why?
Hard to plug/unplug usb device or the usb power. Impossible to remove or put the sd card unless your remove the pi from the case.
Here a pic of the case I am talking about
Posted: Sun Jul 22, 2012 7:09 am
by Henley
I bought one of the 'slot together' acrylic cases off eBay. It was £15!! Held together with two elastic bands. I am not careless with stuff like this but it literally snapped in several places without any pressure. I felt compelled to try and offer others something far more substantial which is what I'm working on at the moment.
Posted: Sun Jul 22, 2012 7:13 am
by Jim JKla
This is all valid feedback.
Posted: Mon Jul 23, 2012 6:19 am
by MaDoGK
@labidus: Have you tried complaining to Element14? I just wondered what there reply would be.
Posted: Wed Jul 25, 2012 12:24 pm
by bkhbud
We are Bud Industries and we make these cases. Thank you for your input and suggestions. We have made a few changes. First, we wanted an easy to use, inexpensive box. Part of that was to avoid using hardware. We did not realize how challenging people might find opening the box so we now have an instruction sticker on the outside of the packaging. It is easy to open if you make sure you hold onto all 4 sides at the same time and lift up without wiggling. Check it out in the video http://www.youtube.com/watch?v=GKV29FfZoO4 . We do recognize that installing the sd card can be a challenge and there are a couple of solutions. First, if you remove the lid, you have more access. Second, you can pop the board out to install and uninstall. Finally, you can snap the post that holds the board from slipping and it will give you more room. We are looking to retool the box with bigger windows which would solve the problem and we hope to have these units in stock shortly.
We apologize for the problems you have had with the box, particularly opening and closing. I think we have solved that problem and we appreciate your input.
