TMFS
Full Contained Self Powered Pi
Wed Jul 11, 2012 5:40 pm
I recently got a Raspberry Pi from my work. After about a day of digging around in my scrap piles I came up with this little guy. A model B Pi that needs only to be plugged into a keyboard. It is self powered and has a bluetooth mouse and a fan cooling system running of the GPIO pins. There will be more to come and a video soon.
TMFS
Re: Full Contained Self Powered Pi
Wed Jul 11, 2012 6:42 pm
http://www.facebook.com/video/video.php ... 2869570988
This is a short video of it working.
mikerr
Wed Jul 11, 2012 6:48 pm
Self powered - do you mean self contained ?
I'm interested in the write-up if you do one - what screen is that using ?
TMFS
Wed Jul 11, 2012 6:53 pm
Self contained power... I just meant it has a battery. The whole case was made out of trash parts. The battery is from an ARdrone.
Step
Wed Jul 11, 2012 7:04 pm
I was hoping that screen was infact a solar panel. None the less a good little bit of kit youve made there
TMFS
Wed Jul 11, 2012 7:27 pm
Solar power was an add-on that i intended on installing. However, the panels that I have will only power the Pi and fan not the screen.
two_sheds
Wed Jul 11, 2012 10:21 pm
I really like that - nice job!
But is it just me that's thinking Orac ?!
http://en.wikipedia.org/wiki/Orac_(Blake%27s_7)
zardoz99
Wed Jul 11, 2012 11:26 pm
That was my first thought as well.. ORAC was a masterpiece of forward thinking.
two_sheds
Wed Jul 11, 2012 11:33 pm
zardoz99 wrote:That was my first thought as well.. ORAC was a masterpiece of forward thinking.
:D So how to make a Pi produce THAT Orac sound when booting up.
I know nothing - can this be done?
(Sorry - wrong thread to ask that!)
Still I LOVE TMFS's case.
And I can't believe it's made of scrap!
(Who has scrap like that?!)
P1nky
Thu Jul 12, 2012 11:04 am
two_sheds wrote: :D So how to make a Pi produce THAT Orac sound when booting up.
What it really needs is the shutdown sound effect, and some kind of LED chaser ring installed!
Any possibility of a parts list and/or build plan - I REALLY need to build one of these.
TMFS
Thu Jul 12, 2012 3:51 pm
I will post a parts list and attach the .ai file for the laser cut case. However, I would suggest that you don't use an ARdrone battery. They are expensive, unless you have a few laying around like I did.
fhlipZero
Thu Jul 12, 2012 11:44 pm
definite bump for parts list and how/what kind of LCD you are using, great possibilities
Jim JKla
Thu Aug 09, 2012 6:39 pm
I think his case looks better than the origiinal Orac
http://www.youtube.com/watch?v=NoHkaFDTiD8
And it was bigger. ;)
TMFS
Thu Aug 09, 2012 6:49 pm
So, I know some of you have been asking me for plans to build the TMFS case. Here is a list of materials, but keep in mind this case was made with stuff laying around my office.
1. You will need a 12 volt LCD screen that has a yellow RCA port.
2. You need a 12-14.5 volt battery (I used an AR Drone lithium polymer battery and put the charging unit inside the case too so I can plug it in to charge rather than taking the battery out to charge.)
3. You will need one of those car cigarette lighters with a usb port.
4. I know most of you dont have access to a laser cutter but you will need one for your acrylic casing.
5. A small low voltage laptop fan.
Take the 12volt car usb plug and take it appart, then wire it to you 12volt supply. Plug your Raspberry Pi into the usb. Wire the LCD directly to your 12volt supply. Plug the fan into the 5v and ground GPIO pins.
If you want buy a bluetooth mouse and keyboard to stay completely wireless.
Montala
Thu Aug 09, 2012 7:05 pm
Just tried to access that, and was informed that "The requested topic does not exist."
Something is obviously not quite right somewhere!
TMFS
Thu Aug 09, 2012 7:11 pm
Yeah, they must have moved it. Thats why I posted it above. Sorry I don't have links to specific parts but my case was made from scrap stuff laying around.
TMFS
Thu Aug 09, 2012 7:12 pm
Here is a GPIO diagram
MrMaxPowers
Sat Aug 11, 2012 4:24 am
Awesome build! Thinking something like this for my next project. I'm going for a karaoke gaming box for parties :D Great job thanks for sharing!
