RobParker
Case for Model B "Rev 1"?
Sat Mar 07, 2015 12:02 am
I've got a couple of old original Model Bs and wanted to get cases for them but it seems a lot of the cases (like the PiBow) are for the "rev 2" which has hole next to the USB ports which the original did not.
Can anyone recommend any cases that'll fit the first generation ones?
Cheers
toxibunny
Re: Case for Model B "Rev 1"?
Sat Mar 07, 2015 7:28 am
maybe I'm misunderstanding, but I think that unless the case _requires_ using the 'mounting' holes, then it'll work fine with rev.1 and rev.2 equally.
pibow should be fine, as should 99% of small plastic cases. definitely double-check you're getting them for the original pi though, and not a + or pi2 type...
note: I may or may not know what I'm talking about...
RobParker
Sat Mar 07, 2015 10:43 am
The PiBow (coupe version at least) requires the mounting hole next to the USB stack.
Lots of the cases don't make it clear though :-(
killor
Sat Mar 07, 2015 1:24 pm
Hi !
I have made many enclosure in these three years
here I expose some model for the first version of the Raspberry Pi.
https://lh4.googleusercontent.com/-3bJF ... to1458.jpg
in birch wood version..
https://lh3.googleusercontent.com/-blkO ... to1469.jpg
enclosure Adapter for Piface board..
http://www.raspberrypi.org/forums/downl ... hp?id=2888
enclosure Adapter for Wolfson Pi board....
http://www.raspberrypi.org/forums/downl ... hp?id=7765
Under the avatar, you see the link AMAZON store :mrgreen:
Now I'm more for the use of wooden case , as they are more ecofriendly
and more resistant than acrylic enclosure.
Birch wood enclosure por RASPI2
Feel free to comment !!
Thank's
We have a discount for purchases made in ETSY site :o
Discount Codes :MAYTHE4TH :!:
gjb2048
Thu Mar 12, 2015 8:33 pm
This worked well for me: http://www.modmypi.com/raspberry-pi/cas ... ry-pi-case whilst my Rev 1 B worked :)
