QBall1977
Re: RaspiLight (ambient light)
Fri Nov 02, 2012 3:51 pm
Just wondered has anyone thought about or had a look at these Ikea lights? Ideal (I would have thought for an ambilight project) and with a control unit (easily / hacked / replaced by RPi?).
http://hackaday.com/2011/08/19/adding-u ... ed-strips/
Could you use Raspbian or even XBMC to control this via USB? That would be awesome, and cheap too. I think the lights are around £30 (that's with the PSU and controller!)
Just a thought. Please keep up the good work and keep us inspired! :D :D :D
____________________________________________
Looking for where to start - try Kernel Panic - http://goo.gl/EEQ5J
metRo_
Sun Nov 04, 2012 3:51 pm
It only works if I'm running XBMC in a windows machine, isn't it?
Just trying to understand what you've done:
1-You've modified the XBMC so that can send some info about the colors on the screen.
2-RPi receive that information.
3-Turn on the leds according.
is that?
How difficult is do this in the raspbmc or is impossible play a video and at the same time take the color information about the frames?
Thaks for your project:)
thedruid
Mon Nov 05, 2012 10:53 am
From what i understand you are netiher running boblight client or boblight daemon, or?
Is it possible to make your ambiPi XBMC build for iOS? (Apple tv 2)
VZoltan
Mon Nov 05, 2012 12:54 pm
dominicclifton wrote:Sure.
Hook up the raspberry pi as per this diagram:
http://learn.adafruit.com/light-paintin ... i/hardware
hi, i just got my leds,
Q:
what if i have an active usb hub and the hub powers the pi via usb port. (5V2A)
do i still have to power the pi and the leds via GPIO
or is it ok powering the pi and the leds via the HUB ?
dominicclifton
Mon Nov 05, 2012 5:47 pm
would not recommend using hub to power the LEDs, hook it up as per wiriing diagram i linked to. Don't use the microusb connector.
dominicclifton
Mon Nov 05, 2012 5:55 pm
LEDs are on special offer from the people i bought mine from (alas, not adafruit due to uk import duty).
Price lists here:
http://www.wst168.com/E_Download.asp
Contact details here:
Shenzhen Diya lighting Co.ltd (Shenzhen)
Diya Industry Co., Ltd (Hongkong)
Factory:#21,ShanCheng Industry Zone,Songbai Rd.,Shiyan Town,Bao'an District,Shenzhen,China
Msn: fre_led01@hotmail.com ( online )
Skype: diyasunky
Phone: +86 0755 29005531 Mobile: +86 1501400 9416
Fax: +86 0755 29005531
www.wst168.com
www.sz-diya.cn
They accept paypal too.
VZoltan
Mon Nov 05, 2012 8:37 pm
dominicclifton wrote:would not recommend using hub to power the LEDs, hook it up as per wiriing diagram i linked to. Don't use the microusb connector.
ok but help me pls:
which wire is what ? :(
http://learn.adafruit.com/system/assets ... 1344878827
i have this:
http://vzoltan.com/led.JPG
it has two cables hanging at the ends,
red and blue
and 4 between leds, blue green yellow red.
VZoltan
Mon Nov 05, 2012 10:25 pm
ok i found this to my leds:
Red=5V DC
Green=Clock
Yellow=Data
Blue=Ground
dominicclifton
Tue Nov 06, 2012 1:11 am
Yeah, that looks right. If you get the clock and data the wrong way round you won't do any harm, but don't get the +5V line wrong.
What i did is to connect my LED's +5v and Ground at BOTH ENDS to my PSU and then connect the PSU to the Pi. And then finally connect the clock and data to the Pi.
The reason for connecting the LEDs and both ends is to ensure a more even power distribution to all the LEDs. If you only connec them at one end you may find that the ones nearest the PSU are brighter.
For testing purposes you can just connect one end to the PSU but for a final installation I recommend both ends.
Keep us all posted on your progress.
dominicclifton
Tue Nov 06, 2012 1:12 am
Also, if you look at the LEDs' circuit boards under a magnifying glass (or digital camera zoom) you can probably work out which color is which from the markings on the LEDs' PCBs.
VZoltan
Tue Nov 06, 2012 11:34 am
dominicclifton wrote:Also, if you look at the LEDs' circuit boards under a magnifying glass (or digital camera zoom) you can probably work out which color is which from the markings on the LEDs' PCBs.
what am i doing wrong?
i have two row of led (25-25)
one end of each is connected to psu +5 and GND and the other end is connected to each other
but only 1-1 led is lit.
1 is colse to the psu and 1 is at the end of the other row.
http://vzoltan.com/rpi/psuled.jpg
dominicclifton
Tue Nov 06, 2012 11:42 am
first off, try with just one set of LEDs.
second, how are you testing the LEDs? using pixelpi? if so what command are you using?
VZoltan
Tue Nov 06, 2012 11:47 am
dominicclifton wrote:first off, try with just one set of LEDs.
righ now leds are only connected to psu nothing else.
ok, one set connected with both end to psu, or only one end?
Does it matter which end is connected to the psu first and than to each other?
is it some kind of sequence ?
dominicclifton
Tue Nov 06, 2012 12:07 pm
when leds are only connected to a PSU with no clock and data signals they will behave randomly. connect up to the pi, run pixel pi's 'chase' mode to test them.
VZoltan
Tue Nov 06, 2012 12:09 pm
dominicclifton wrote:when leds are only connected to a PSU with no clock and data signals they will behave randomly. connect up to the pi, run pixel pi's 'chase' mode to test them.
OK! thanks for the patience :)
VZoltan
Tue Nov 06, 2012 12:26 pm
if i wont succeed, will u upload one of your working setup as a rpi-image, pls?
something is wrong:(
pi and leds are connected to psu like it is on that picture.
i get this:
pi@raspbmc:~/PixelPi$ sudo git clone git://github.com/hydra/PixelPi.git
Cloning into 'PixelPi'...
remote: Counting objects: 94, done.
remote: Compressing objects: 100% (55/55), done.
remote: Total 94 (delta 54), reused 78 (delta 39)
Receiving objects: 100% (94/94), 25.33 KiB, done.
Resolving deltas: 100% (54/54), done.
pi@raspbmc:~/PixelPi$ cd PixelPi
pi@raspbmc:~/PixelPi/PixelPi$ sudo git checkout ambipi
Branch ambipi set up to track remote branch ambipi from origin.
Switched to a new branch 'ambipi'
pi@raspbmc:~/PixelPi/PixelPi$ sudo python pixelpi.py ambipi --chip WS2801 --udp-ip 192.168.2.107 --udp-port 20434 --num_leds 50
  File "pixelpi.py", line 1, in <module>
    import cwiid
ImportError: No module named cwiid
and no light at all, none :(
VZoltan
Tue Nov 06, 2012 1:07 pm
now i have pi running and first 3 leds on (full rgb -white-)
still no luck on the software side :(
VZoltan
Tue Nov 06, 2012 1:48 pm
i did install python and GPIO stuff as described here:
http://thegreatgeekery.blogspot.ca/2012 ... s2801.html
but i got
pi@raspbmc:~/PixelPi$ sudo python pixelpi.py  --chip WS2801 --mode chase--refresh_rate 1
    import cwiid
still :(
ok, now ive commented the first line in pixelpi.py
#cwiid
and rund a all_on test
every led get full white, and RPi just froze :)
well it is some kind of progress:)
http://vzoltan.com/rpi/allon.jpg
VZoltan
Tue Nov 06, 2012 2:36 pm
first big step for me :)
"cahse" test at 30
http://www.youtube.com/watch?v=LDOGyqx8U4Q
testing with this
sudo python pixelpi.py chase --chip WS2801 --num_leds 50 --refresh_rate 30
"fade" test at 30
http://www.youtube.com/watch?v=i0I3MREBYcY
testing with this
sudo python pixelpi.py fade --chip WS2801 --num_leds 50 --refresh_rate 30
When it reaches full rgb WHITE, it just froze :(
why?
dominicclifton
Tue Nov 06, 2012 2:42 pm
Well done! Good to see your LEDs working. Now you just have to run pixelpi in ambipi mode and my xbmc build and set your networking settings up.
VZoltan
Tue Nov 06, 2012 2:44 pm
dominicclifton wrote:Well done! Good to see your LEDs working. Now you just have to run pixelpi in ambipi mode and my xbmc build and set your networking settings up.
even with this
#cwiid
line at the first line?
and what about this white error (freez)
VZoltan
Tue Nov 06, 2012 3:09 pm
your xbmc is set up and up and running,
rpi gives me this:
pi@raspbmc:~/1/PixelPi$ sudo python pixelpi.py ambipi --chip WS2801 --udp-ip 192.168.2.100 --udp-port 20434 --num_leds 50
Start Ambi listener 192.168.2.100:20434
  File "pixelpi.py", line 555, in <module>
    args.func()
  File "pixelpi.py", line 219, in ambipi
    serversocket.bind( (args.UDP_IP, args.UDP_PORT) )
  File "/usr/lib/python2.7/socket.py", line 224, in meth
    return getattr(self._sock,name)(*args)
socket.error: [Errno 99] Cannot assign requested address
chase test still works.
dominicclifton
Tue Nov 06, 2012 3:14 pm
Check your ip address with 'ifconfig' it should be the ip address of the Pi itself.
VZoltan
Tue Nov 06, 2012 3:20 pm
Data error (led count mismatch, expected: 50, received: 104)
Resetting...
Turning all LEDs Off
with 104 set on, it is working, but i have only 50
how can i set up to 50 ?
just a quick demo:
http://www.youtube.com/watch?v=8oVkOye9f8M
now i have to put the leds on the frame, and enjoy :) (i will upload a video when its ready)
BTW, there is no SOUND with your xbmc bulit!!! can you help me with that?
VZoltan
Tue Nov 06, 2012 9:38 pm
Sound is OK :)
but still cant configure to 50 leds :(
and im not sure how to organize the leds around the frame, where to start with what led
id like to put
Top=16
Bottom=16
Left=9
Right=9
total=50 :)
Who is online
Users browsing this forum: No registered users and 15 guests
