Alex_Landherr
Contact: Twitter
Mini HMDI Connector Dimensions on Pi Zero W?
Mon Aug 02, 2021 9:58 am
For designing a 3D-printed case I need the dimensions of the Mini HDMI connector on the Pi Zero W; i.e. width, height and depth. What are they in millimeters?
Helpful answers are appreciated.
I usually respond to Tweets directed at me.
JWST is the Sagrada Família of spacecrafts.
3D Printer: Original Prusa Mini+
OS:
  • Raspberry Pi OS
  • Windows 10
Programming Languages:
  1. Python
  2. Java
aBUGSworstnightmare
Re: Mini HMDI Connector Dimensions on Pi Zero W?
Mon Aug 02, 2021 10:16 am
Part is 690-019-298-903 as given on the schematic https://www.raspberrypi.org/documentati ... educed.pdf
Google would have let you find
https://datasheet.octopart.com/690-019- ... 065370.pdf
Last time for being fed with the spoon...
pidd
Tue Aug 03, 2021 1:22 am
But for the purposes of a case, you need the dimensions of mini HDMI plugs and they vary quite a bit.
Page 30 (pdf page 46) of the following document gives the official dimensions of Type C plugs https://web.archive.org/web/20160305072 ... ion13a.pdf
Imperf3kt
Contact: Twitter
Tue Aug 03, 2021 2:20 am
Just make sure your sidewall is no more than 1mm and pretty much any plug will fit.
If you must, leave a recessed gap 5mm around the port to be safe.
55:55:44:44:4C
52:4C:52:42:41
Rose tinted glasses are difficult to see through.
