neinnein1310
Pi Zero as middle man between pc and keyboard
Mon Jul 26, 2021 11:47 am
I'm trying to achieve the effect of Kyria Oled split keyboard by connecting an Oled display to the Pi Zero and using the Pi Zero as a middle man between any keyboard and pc which will be able to calculate the number of WPM and display it. Was wondering if I can connect the keyboard to the Pi Zero via micro USB port and then install an usb expansion board onto the Pi Zero to plug it straight into the pc. If it is possible then how do I send the keystrokes from the Pi Zero to the pc. Or if I should use Pi Zero as a standalone keylogger to calculate WPM. Thank you in advance.
thagrol
Re: Pi Zero as middle man between pc and keyboard
Mon Jul 26, 2021 12:58 pm
Not possible. The zero has 1 USB controller with a single port. It can do host or device but not both at the same time. Most "USB expansion" boards are repackaged USB hubs.
I'm a volunteer. Take me for granted or abuse my support and I will walk away
All advice given is based on my experience. it worked for me, it may not work for you.
Need help? https://github.com/thagrol/Guides
mahjongg
Mon Jul 26, 2021 7:12 pm
You could try to use a PS/2 keyboard, it doesn't need an USB interface, and the interface can be "bit banged" with GPIO's.
Imperf3kt
Contact: Twitter
Mon Jul 26, 2021 9:43 pm
Could you track it with software on the target device and send that data to the Pi to be merely displayed (not processed on the Pi itself)
55:55:44:44:4C
52:4C:52:42:41
Rose tinted glasses are difficult to see through.
trejan
Mon Jul 26, 2021 9:58 pm
A Pi 4 could do it as it has two separate USB controllers. Do you really want to wait for your keyboard display to boot before you can type anything though?
LTolledo
Mon Jul 26, 2021 10:21 pm
neinnein1310 wrote: I'm trying to achieve the effect of Kyria Oled split keyboard....
just buy the keyboard you mentioned... as save yourself some unforeseeable "white elephant" and agony....
Some people be like:
