owenj
Re: RoadApplePi - The Elegant Black Box Solution for your car
Thu Jan 30, 2020 5:28 pm
jsable wrote:
Tue Jan 28, 2020 3:43 am
I just tried to install this on a brand new Raspberry Pi Zero W with a 16GB microSD card and Raspbian Buster Lite. I saw on github that this was updated to work with Buster lite. The errors that I am getting are:
E: Unable to locate package php7.0-mysql
E: Couldn't find any package by glob 'php7.0-mysql'
E: Couldn't find any package by regex 'php7.0-mysql'
E: Unable to locate package php7.0-bcmath
E: Couldn't find any package by glob 'php7.0-bcmath'
E: Couldn't find any package by regex 'php7.0-bcmath'
Failed to disable unit: Unit file hostapd.service does not exist.
ffmpeg-3.4.2 seems to have issues:
/usr/bin/ld: libavfilter/libavfilter.a(allfilters.o): in function `register_all':
/RoadApplePi/ffmpeg-3.4.2/libavfilter/allfilters.c:404: undefined reference to `ff_af_acopy'
/usr/bin/ld: /RoadApplePi/ffmpeg-3.4.2/libavfilter/allfilters.c:404: undefined reference to `ff_af_aeval'
/usr/bin/ld: /RoadApplePi/ffmpeg-3.4.2/libavfilter/allfilters.c:404: undefined reference to `ff_asrc_aevalsrc'
collect2: error: ld returned 1 exit status
make: *** [Makefile:108: ffmpeg_g] Error 1
Mysql seems to have erred as well:
Step 4. Building and installing RoadApplePi
gcc raprec.c -o raprec -Wall -lmysqlclient -lm
raprec.c:34:10: fatal error: mysql/mysql.h: No such file or directory
 #include <mysql/mysql.h>
compilation terminated.
make: *** [Makefile:3: raprec] Error 1
cp raprec /usr/bin
cp: cannot stat 'raprec': No such file or directory
make: *** [Makefile:8: install] Error 1
rm: cannot remove '/var/www/html/index.html': No such file or directory
sudo: mysql: command not found
Done! Please reboot your Raspberry Pi now
pi@DashCamPi:/RoadApplePi $
Can these be installed separately? Or does anyone have an idea as to how to get this working? Any help would be appreciated!
~John
Hello John,
To use RoadApplePi with Buster, instead of typing:
git clone https://github.com/JVital2013/RoadApplePi
replace it with:
git clone https://github.com/matt2005/RoadApplePi
This repo has been updated to support Buster and Buster Lite for RoadApplePi. Then when you run
cd RoadApplePi
 ./setup.sh
 sudo reboot
it should install properly. The old repo you're trying to clone from is trying to install old versions of php and mysql which don't work with Buster.
Hope this helps!
ITzAndy94
Sun Feb 02, 2020 8:54 pm
hi how many dash cams would this run at the same time please ?
Vegalyp
Mon Mar 09, 2020 1:07 am
So, the RoadApplePi does not detect the Raspberry Pi Camera Module. When I examine the logs, it throws out V4L2 errors stating controls are not recognized. Has anyone been able to get a Pi Camera Module working with this? If so, could you point me in the direction of what I may be doing wrong?
chrisjordon
Sun May 03, 2020 1:27 pm
Good solution for the car. If you want to buy bmw scanner you can visit at https://www.autoscanit.com/
olsonb2
Sat May 09, 2020 8:43 pm
Greetings,
I am so excited to this project off the ground. I bought all the devices and have big plans for it. However I’m confused while following your guide. When you say “ On another device, go to http://raspberrypi/. --Note: Your device hostname can be changed by running sudo raspi-config on your pi. I've changed mine to "roadapplepi". A feature to change this from the web app will be added in the future”, how do you access http://raspberrypi/ from another device? Everything installs correctly and I’ve followed every step up to that point, but I cannot move on without connecting. Should there be a web server program running in the background that allows me to connect or am I missing something? Both my laptop and pi can connect and I have physical and SSH connection so I’m not sure what I’m missing. Thanks!
UPDATE: just saw the post about using Matt’s version in order to work with Buster and I can now access it. However, now I’m having issues accessing the AP once I set it up. The AP does ant show up on my laptop’s network list.
Leylander
Tue Sep 08, 2020 10:39 pm
Awesome work.
How do I support this project?
Items of interest for me:
1. Multi camera - even if it means multiple Raspberry pis;
2. GPS integration (Bluetooth);
3. Auto-connect to SMB share for storage of recordings and associated data (GPS, ODBII, etc.);
4. Integration of 4g dongle for internet sharing (possibly via additional wifi dongle).
Thanks!
tmdrake
Contact: Website Skype Twitter YouTube
Fri Dec 25, 2020 1:03 am
I hope to resurrect this project...doing my own power manager that will turn on/off the pie.
The SMB upload would be a nice feature as soon as I get the hardware done today I will post some pictures. I plan to take the roadpi on the road for my first 500 mi drive.
-Rawr!
http://www.tmdrake.com
(will be moving to other Socal Network sources)
ChrisY3
Thu Apr 29, 2021 3:17 pm
Hi.
Is anybody still following this ?
I've just built one, but cannot connect to it. I can SSH to it fine, but "RoadApplePi" with or without ".local" have no communication with it at all. Nor does trying to go in with the ip address.
Ideas please ?
Chris
moosepi67
Tue May 18, 2021 12:51 am
Has anyone gotten GPS and time overlay working with this? I have a script working without the raprec starting but it only records H.264 and those don't pull up in the browser.
