jbenjamin
Printer Emulator
Thu Oct 17, 2019 3:02 pm
Hi! I want to make my raspberry pi into a printer emulator (I don't have one yet so I'm open to using any that is most efficient for this purpose). Basically when I connect my raspberry pi, I want the PC to think an USB printer is connected. If possible, I wouldn't mind if the raspberry pi the documents that the PC sends to print and saved it somewhere as a digital copy. The reason I am looking for a printer emulator is that the PC is an old DOS based system that needs a printer to be connected in order to run, and simply plugging in a USB is not helping :roll: . The thing I am really confused is what signals does the emulator need to send to make the PC believe it's a printer. Please let me know if you have any ideas :D .
Re: Printer Emulator
Thu Oct 17, 2019 5:44 pm
Only the Raspberry Pi Zero and 4B can be in "Gadget Mode" aka USB Client, see:
https://blog.gbaman.info/?p=699
https://blog.gbaman.info/?p=791
Though can not understand why you can not plug a USB Printer into the "DOS" machine.
Thinking outside the box is better than burying your head in the sand...
scruss
Thu Oct 17, 2019 7:09 pm
Have you seen the Retro-Printer? I don't know how well it works, but the developer has been around a long time, and they've done quite a bit on producing a driver that accepts old dot-matrix codes and prints the result as PDF.
Sometimes an elderly workflow is irreplaceable, and this is exactly why RWAP made this device.
Pronouns: he/him
jbenjamin
Fri Oct 18, 2019 3:09 pm
Currently that is what we are doing. But the thing is that we really don't want the hard copy of the files, and it is just a waste of space if we are not going to use it much.
It looks promising, but it seems like you need a centronics port, which the system does not have
PiGraham
Fri Oct 18, 2019 3:50 pm
It seems to me you would first need to know what printers your 'DOS computer' supports. It you will emulate a printer it would be one of those the legacy machine supports.
Alternatively you might consider writing a printer driver to run on the DOS machine Then you could make the driver write the rendered print image to file on a networked file server or a local USB storage device.
Indeed somebody has probably done that already.
Maybe this is useful, although I see no mention of it running of antique machines. Maybe DOS emulators on windows?
https://www.printfil.com/?gclid=CjwKCAj ... LgQAvD_BwE
Either way diy it sounds like a very challenging project.
if at all possible find a way to convert the source document file into a format that a modern machine can print (to file or otherwise).
scruss
Fri Oct 18, 2019 6:48 pm
I'm guessing that there's a small list of USB printers that are supported, since the overlap between MS-DOS and USB is not very great?
(unless this is a Windows command terminal application, which would mean it's more likely to support more printers - but isn't really running under DOS)
In theory, you could use the Linux USB Printer Gadget module (g_printer) to make a Raspberry Pi Zero appear as a USB printer. You'd have to find the correct USB Vendor and Product ID so that your computer might identify the fake printer correctly: but that would require you to work out which printers are supported by your DOS program, and which printers support spooling data in a format you can convert to something useful.
(For example, a HP LaserJet P3005 mono laser from ~2006 supports USB, and talks both PostScript and PCL. PostScript's usually trivial to convert to PDF, PCL would need GhostPDL. Whether these formats get spooled via USB in a way that g_printer's prn_example code can read is a big question.)
In practice, no one on this board has documented a working solution with g_printer, though some have thought about it: g_printer search results
A device that claims to do this is the RedTitan Virtual Printer: again, untried.
Pronouns: he/him
jbenjamin
Wed Oct 23, 2019 8:50 pm
Talked to a rep from them and it may work, but it is really expensive.
RWAP
Sun Nov 03, 2019 9:00 pm
What does the system use to connect the original printer? A parallel port, a serial port, or a USB port?
The Retro-Printer works with a centronics port (or parallel to centronics cable), and we have also used it with a USB to serial port adaptor.
If you want to capture the output from a USB port, then you can use a USB to centronics adaptor - there are lots of cheap options, or look at something more like our Interceptor software emulator - although that is designed to sit between a USB printer and a USB port....
RWAP
Sun Nov 03, 2019 9:09 pm
This is basically what we did for the Interceptor module - although we didn't try the software on a Raspberry Pi 4B - we got it working on Banana Pi M1+ and Odroid C1/C1+ / C2 - see https://www.retroprinter.com/the-rwap-interceptor-s/
This reads the parameters of a connected default USB printer and then sets the gadget printer to mimic the USB printer. It would need to be adapted to store the output - as it was designed to be a printer capture device in time critical situations, we avoided the actual print conversion (which slows down the printing process).
If you only wanted to create a PDF of the captured output, then you are stuck with questioning what printer language you need to capture and convert..
Is it plain text? For a USB printer, this is unlikely.
Is it PCL ? Easy - you can use GhostPCL for this.
Is it ESC/P or ESC/P2 - you can use our own PrinterToPDF (public domain convertor)
If it is ESC/POS or a Windows printer driver, then you will need to write a conversion routine
