GrixSilva
4 pin momentary switch
Thu Sep 12, 2019 2:09 pm
Hi!
I would like to add a power button to my raspberry pi.
I made some research and I know i need to connect um pin to the ground and another one to 5v gpio pin.
My problem is I bought some momentary switch with 4 pins, something like this one:
https://images-eu.ssl-images-amazon.com ... ZZZZZ_.jpg
I would like to know witch pins I need to connect to my pi.
Thank you in advance!
hippy
Re: 4 pin momentary switch
Thu Sep 12, 2019 2:47 pm
No, not quite. Don't do that, it could well damage something.
My problem is I bought some momentary switch with 4 pins, something like this one: ...
Usually on miniature push-button switches there are two pairs of connected pins. A continuity meter will determine which pairs are connected. AFAIR -
    |  |     _        |
    |  |   _|_|_      |
    |  `---O   O---.  |
Or, if it doesn't work, rotate 90-degrees and it should. Note the legs may not be on a square pitch but can be coerced to fit.
pcmanbob
Thu Sep 12, 2019 2:53 pm
I don't know what you think you have researched but should never connect 5v to any gpio pin the gpio is not 5v tolerant , and if you connect ground and 5v to the switch you have linked to you would short 5v to ground , which would certainly cause you pi to stop dead , and possibly damage it.
I suggest you either do some more research or show us what research you have that says connect 5v to ground .
pin out bottom right
GrixSilva
Thu Sep 12, 2019 4:17 pm
I may be confused about connecting the power button pins to my pi.
I need to be more careful with my research.
Thank you for your replies!
