darth_brando
raspberry pi 3 b to laptop via portable dvd player
Mon Jun 18, 2018 6:31 pm
so im starting a bit of a project, i realize this is a more advanced project which will require direct connection bypassing, soldering and inserting of certain video boards to accomplish. and i am prepared and know how to do that.
what i need help with is selecting which boards i will need in order to fully integrate and interface the raspberry pi with this protable dvd player.
http://portablemedia.manualsonline.com/ ... 7.html?p=4
i am using an ematic epd707 (7" screen) portable dvd player (which does have AV out) with a raspberry pi 3 model B.
what i want to do is utilize a video board connection and a GPIO connection that connects the pi to the screen and the pi to the optical drive. (or at the least allows a selection transfer between pi and onboard driver on the screen ie
switch pos1= rpi on screen
switch pos2=optical drive/mp3 usb/sd input on screen) while screen source switching will work i would prefer to be able to use the optical drive and media ports on existing dvd player boards directly on the pi. if this is not entirely possible i do understand.
the other major modification i want to do is to insert 18650 Li-ion capacitor bank for powering of the device (i fully realize this will require 3 power circuits: screen, optical drive, rpi) an i could use some help picking out proper inverters and battery port parts.
i realize these mods will add bulk and make it so the finished project doesnt fit in the dvd players original case, thats not a problem.
in short what im asking for is help picking out:
video driver connection board (with multi source input options and active source switch options)
18650 capacitor bay parts (i just need the bay parts and wiring and inverters i have/can get the capacitors done on selection)
figuring out where and how to do the bypasses on the dvd players boards.
darth_brando
Re: raspberry pi 3 b to laptop via portable dvd player
Mon Jun 18, 2018 7:30 pm
note on capacitor inverter/step up booster parts.
i will be using 6x 2600mAh 3.7v 18650 Li-ion capacitors in 3 different power circuits (each circuit using 2x in parallel)
i will need a converter to 5v for the Raspberry Pi
and a converter for the dvd players voltage settings.
i am upgrading the dvd players battery from its stock to 18650s as 5200mAhx5v=26 ish Wh vs the stock batteries 8 hour operation.
Who is online
Users browsing this forum: No registered users and 6 guests
