TekRush
12V Fan on PI GPIO
Sat May 26, 2018 9:18 pm
I have a 12V 0.10A Fan (Brushless DC) lying around and I would like to use it on my Raspberry Pi 3B. Would it be possible to run it at its max RPM but not destroy the Pi, keeping in mind that I have a few LEDs hooked up and will be hooking up other things too.
Any help would be appreciated
pcmanbob
Re: 12V Fan on PI GPIO
Sat May 26, 2018 11:40 pm
Hi.
You will need an external 12V supply as the pi does not have 12V on it, you will also need a transistor and resistor to allow the 3.3V of the gpio to control the 12V
If you search the forum you will find several posts about this very subject.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
Pomgonewalkabout
Sun May 27, 2018 7:42 am
Control it via a relay ?
Z80 Refugee
Sun May 27, 2018 7:47 am
Military and Automotive Electronics Design Engineer (retired)
For the best service: make your thread title properly descriptive, and put all relevant details in the first post (including links - don't make us search)!
