mjonker
Using Lego 42055 and IBM Watson to identify bricks
Mon Jan 16, 2017 12:31 pm
A fun way to learn about Watson Visual Recognition and creating your own classifier, is with
Lego 42055, and a Raspberry Pi.
This is on top of this Lego 42055 machine
What you can notice in the video is the time it takes to identify a brick, we have 12 bricks, that are transported in 16 seconds. It took 40 seconds more to finish the recognition process.
https://www.youtube.com/watch?v=Uv8izH_soQQ
Not all identifications are correct
We can gain some performance by tighter coupling, but the measurements show that I takes up to 2 seconds to classify an image.
This is the round trip to the Watson Cloud Services.
To train Watson with the images, I first did a couple of rounds just collecting frames/images.
For each brick ca. 35 images are used to train, and not to forget: the "negative" images, those are the images that have no brick but "only" transporter belt.
I made sure the lighting and camera distance stayed (more or less) the same.
First I had hoped to keep op with the fysical world and show live icons.
In the end, I decided to demonstrated the recognition skills by photographing the order in which the bricks were put on the transport belt.
This is how I mounted the Raspberry Pi on the Lego machine
jkexbx
Re: Using Lego 42055 and IBM Watson to identify bricks
Thu Oct 12, 2017 12:28 am
I would love to create the same thing. I have been having a lot of difficult getting started with Watson. I was hoping you could lead my in a good direction or provide the source that you used.
Thanks,
Jacob
mjonker
Fri Oct 13, 2017 8:29 am
Hi, I shared a more technical explanation here: https://www.ibm.com/developerworks/comm ... pi?lang=en
I have used the JAVA version of the Watson SDK : there are other options available here: https://github.com/watson-developer-cloud
The basic mechanism I used here was:
  • let the Raspberry Software for the Camera take a picture every second
    save the picture in a folder
    another software process monitors this folder (in my case a java program)
    the new pictures are send to the IBM cloud where I used my own model (you need to train it first)
    the result code is mapped to a picture that I display
Who is online
Users browsing this forum: Baidu [Spider] and 6 guests
