The keyboard I'm using is LED lit. I was thinking about unsoldering the Ethernet jack and USB ports have use through the wall jacks instead. I'm not sure about wiring the usb ports back up though. Are there any tutorials out there that show specifically how to resolder the ports properly that will allow four ports to come directly off the board? I was also thinking about modelling a GPIO pin header so that the pins are accessible from the top left of the keyboard. The Pi cobbler would just run underneath to the new port. Here is my project so far. Any suggestions?
