ettman8
Wall plug project box
Fri Jan 05, 2018 7:52 am
I’m in the process of making some home automation sensors for home.
The first will be a PIR sensor.
I want to avoid having a wall plug AND project box, additionally I want the sensor at the same height as the wall plug it will be powered from.
Does anyone have a suggestion of a project box that has a built in power supply and has an AU plug on it?
Below is sort of what I need but any better recommendations would be appreciated.
https://www.jaycar.com.au/3-pin-plug-pack-case/p/HB5900
mattmiller
Re: Wall plug project box
Fri Jan 05, 2018 8:34 am
Mixing mains voltages inside a project box is very dangerous (to you - other people - and your actual project!)
Not to be recommended
misho.petrov
Mon Jan 29, 2018 8:42 pm
Here is an idea I used to create a portable 3G/4G access point, using Pi 1 B, two small, black, plastic boxes, glued one to the other, psu 220/5 V 2A inside the smaller one and a wall power plug adapter (chinese to european standard).
Hope this'll help you. ;)
1. RPi B 512 MB + Sandisk 2GB c4, vesa mount;
2. RPi B 512 MB + Hama 16GB c10, heat sinks, micro fan, built-in lead-acid battery, duplicated factory plugs, 4,3" TFT, usb mini wireless keyboard, TDA2822 and speakers;
3. RPi 2 + Maxell 16GB c10.
Who is online
Users browsing this forum: No registered users and 9 guests
