evilkitty
Should a case be dc ground or earth grounded
Mon Sep 04, 2017 11:34 am
Image of setup: http://i.imgur.com/CyOkW3C.jpg
My case is a moded PSU with 2 wall worts crammed inside (12v/5v)
Currently i am using a 2 prong ac wire, but i could switch to a 3 prong, but if i do should the case be earth ground or dc ground?
at present the case has no intentional ground connection ac nor dc
My Pi Server: http://imgur.com/a/6xIUI | Thermostat: http://imgur.com/a/4LVnT
Re: Should a case be dc ground or earth grounded
Mon Sep 04, 2017 11:41 am
The RPi GND should NOT be connected to your household earth. So just connect any RPi peripherals to the DC 0V on pin#6 (and others https://pinout.xyz/pinout/ground).
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
evilkitty
Mon Sep 04, 2017 1:40 pm
I mean the case not the pi, the case has no connection
karrika
Mon Sep 04, 2017 1:59 pm
This is a very good question. If your Pi is in an environment where there is a risk that the high voltage inside a Pi could cause damage then the case should be connected to earth to protect the user.
But the Pi runs a very low voltage so there is no risk involved (unless you are oprating the Pi while someone is doing open heart surgery at the same time).
So grounding the case to anything will just make ground currents possible. I would not connect the case to anything.
evilkitty
Mon Sep 04, 2017 2:52 pm
in other news TIL i need to get some washers for my case fan as my fat ass cat will bend the grill so that it touches the fan
Burngate
Mon Sep 04, 2017 5:13 pm
If mains goes into a metal case (or if there's any metal that can be reached by a small finger), then the metal must be connected to mains earth.
Mains earth is protective; it does nothing until something goes wrong.
When the pvc insulation on the mains wiring gets abraded so that the live wire touches metal, that's when it's a life-saver - literally.
