marknotgeorge
A RasPi case made out of Lego? How original!
Sat Jul 07, 2012 1:19 pm
When I got my Pi, I did what any parent would do, and raided my daughters' Lego tub. Starting with the webpage of Biz's famous case on my laptop beside me (which soon got turned off due to rampaging kittens), I designed the case with access to all the ports and visibility for the blinkenlightzen. I think I did rather well:
2012-06-23-123 (Custom).jpg (38.38 KiB) Viewed 3440 times
After building the prototype (and one-and-only production model), I stuck the design in Lego Digital Designer for some tweaks with the benefit of an infinite brick tub.
I used the colours to highlight the layers. Note the use of flat plates to help support the PCB. The one below the micro USB power socket on the prototype is actually a Tyco Megabloks brick, which is slightly taller than a Lego flat plate. The layer of white plates below the roof may not be necessary when using the ideal bricks, as I put it there to help tie the bricks used on the prototype together.
Feel free to tweak and do what you will with it.
By the way, anyone know how to get a list of parts for Buy a Brick?
RaspiCase.zip
Here's the LDD file.
(9.73 KiB) Downloaded 252 times
Mark (not George), Derby, UK.
AquilaRapax
Re: A RasPi case made out of Lego? How original!
Tue Jul 10, 2012 2:54 pm
you can you a litte java tool called "BrickHelper" to extract partlists direct out of the ldd files.
you can get it here: http://www.blarworld.net/software.html :D
LEGO Parts can be ordered at bricklink.com or at Pick a Brick on shop.lego.com.
marknotgeorge
Tue Jul 10, 2012 10:33 pm
Thanks for that!
MacbethAUT
Wed Jul 11, 2012 8:40 am
I've had the same idea! Here is my take on my lego case:
I only need openings for the SD Card, Power and HDMI.
