pixelriffic
In search of a larger case
Mon Oct 16, 2017 8:47 pm
Hi folks,
A year or two ago, I ran across a case for a Pi that was about 4X the size of the common enclosures. It was around $100. Sadly, I did not buy it at the time, and wish I did. I can no longer find it. Clearly, some are a fan of the teeny weeny little cases, and sure, some are pretty cool, but I'd like a larger case. Among other things, it would be handy to put a linear power supply inside the unit, and make it look like it belongs on the shelf with the other audio gear. Anyone know of such a thing? My searches have led me only to the tiny little enclosures we all know.
landyvlad
Re: In search of a larger case
Thu Oct 19, 2017 2:39 pm
I agree I'd prefer a case with power supply internal so just a normal wall plug.
Watching.....
pixelriffic
Thu Oct 19, 2017 5:36 pm
Watching.....
An internal supply would be great, and the added weight would help prevent the unit from scooting around.
I did run across this 3D pattern for a case that could be promising. A friend has a 3D printer, but the quality of the output is not something I'd want to look at on a shelf. Still, it's on the right track.
https://www.thingiverse.com/thing:655304
Douglas6
Thu Oct 19, 2017 5:37 pm
Try a Google search on 'project boxes' or 'project cases'. You may not find anything Pi specific, but there's a huge variety.
pixelriffic
Thu Oct 19, 2017 10:45 pm
I do appreciate the suggestion, but I should probably clarify my original request. I'm not looking for a project, but rather a ready to go case. Sure, I might make a modification or two, but I don't have time to dedicate to starting from scratch. For those that do, ebay also has some very nice cases for modest prices.
landyvlad
Fri Oct 20, 2017 3:08 am
In case anyone cares
source for cases and lots of components
https://www.audiophonics.fr/en/diy-encl ... -6336.html
they have some nice stuff but NOT cheap. (Too expensive for me!)
landyvlad
Fri Oct 20, 2017 3:14 am
I'm looking at the possibility of a project which will have two separate Raspberry Pi's in the one case (along with a power supply and a few other bits and pieces)
The main issue that my brain is wrestling with at the moment is the fact that the pi has connectors on at least two sides.. so setting it up in a case , with access to the various ports where needed, isn't easy.
It may come down to some (or all) of the ports needing to be routed to panel mount USB connectors, and RCA connectors for the hifiberry board) .
(not an ideal solution but a possibility I suppose).
Anyone know where I can get these, affordably?
I'm in Australia, in case that's relevant....
Cheers
RaTTuS
Fri Oct 20, 2017 8:45 am
http://www.pcsl.eu/1u-Rack-Mount-Case-f ... -Computers
there are others for 2 or 3 RPi
search for rack mount cases ?
Covfefe
mikerr
Fri Oct 20, 2017 9:03 am
I use the WDLABS 6x6 case in a few instances where I want more room:
http://wdlabs.wd.com/category/pidrive-enclosures/
Big enough for a pi + HDD, or 2 Pi - but I think you might need bigger if you want 2x pi plus psu ?
Or there are various versions of the MediaPi case:
https://www.amazon.co.uk/Limited-Raspbe ... 00JNXERM2/
https://www.amazon.co.uk/SB-Components- ... B00SEGYY7C
rurwin
Fri Oct 20, 2017 9:23 am
This one looks close to what you want. It doesn't have an internal power supply, but it does have a power-switch.
http://uk.farnell.com/element14/pi-desk ... nsku=false
pixelriffic
Fri Oct 20, 2017 2:17 pm
Thanks for all who replied. The Media Pi is by far the closest to what I had in mind. It has a USB hub as a bonus, and connections routed to the back, where they would be on any other audio component, and as RCA connectors at that. That's a big difference from all the others, as they just expose the Pi's connectors. The rack mount case is interesting, and adds the space, but I think the Media Pi case would look nicer on a shelf overall. Appears that there is still room to put a Hifi Berry in there too. It In fact, I just ordered one.
stephj
Tue Nov 14, 2017 12:26 pm
I am currently running in one of these. It is a nice bit of work but actually costs more that the Pi did!
Just be aware you will lose one of your USB sockets; what isn't shown in the image is the USB power dongle that is required to power the msata adapter card that sits on top of the Pi. Notice in the image the top right full size USB socket and the right hand micro USB power sockets are surrounded by a white line; this is where the dongle goes.
I have a 16GB SSD msata card mounted in it with all my development projects\source etc. including a copy of the fstab file that contains the mount details for this card.
It saves an awful lot of hassle when upgrading to the next version of Rasbian.
evilkitty
Thu Nov 16, 2017 2:03 am
IF you are willing to go the DIY route, i took a old computers power supply and made it a case
link in signature for pictures
images are not quite upto date, been trying to get a odd noise out of my audio, not sure if it is EMI noise, software bug, or a defect in my pi
My Pi Server: http://imgur.com/a/6xIUI | Thermostat: http://imgur.com/a/4LVnT
Who is online
Users browsing this forum: No registered users and 13 guests
