texy
Re: Debian ARM on Raspberry Pi
Sat Apr 14, 2012 5:56 pm
Head's up -new Debian distro on the downloads page!
Texy
Omer
Sat Apr 14, 2012 8:52 pm
Hi folks,
I've managed to get wireless working on the board (with a zd1211 based adapter) with the new debian image and posted a little 'how-to' here.
Hope this comes in handy for people receiving their boards soon!
Cheers,
Omer.
Omer
Sat Apr 14, 2012 9:05 pm
[I can"t find a relevant sub-forum to post this so mods: please feel free to move this as you see fit]
Trying to get audio out from the stereo jack, I seem to have run into a problem with  the snd_bcm2835 kernel module.
Thinking out loud… Here'"s the log of my experiment:
Install alsa and mplayer
$ sudo apt-get install alsa mplayer
Play an audio file with mplayer
$ mplayer 108. Blackwater Park.mp3
Creating config file: /home/pi/.mplayer/config
MPlayer 1.0rc3-4.4.4 (C) 2000-2009 MPlayer Team
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing /home/pi/108. Blackwater Park.mp3.
Audio only file format detected.
Clip info:
Title: Blackwater Park
Artist: Opeth
Album: Blackwater Park
Year: 2002
Comment:
Genre: Unknown
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
AUDIO: 44100 Hz, 2 ch, s16le, 192.0 kbit/13.61% (ratio: 24000->176400)
Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3)
socket(): Address family not supported by protocol
AO: [pulse] Init failed: Connection refused
Failed to initialize audio driver "pulse"
[AO_ALSA] alsa-lib: confmisc.c:768:(parse_card) cannot find card "0"
[AO_ALSA] alsa-lib: conf.c:4170:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
[AO_ALSA] alsa-lib: confmisc.c:392:(snd_func_concat) error evaluating strings
[AO_ALSA] alsa-lib: conf.c:4170:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
[AO_ALSA] alsa-lib: confmisc.c:1251:(snd_func_refer) error evaluating name
[AO_ALSA] alsa-lib: conf.c:4170:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
[AO_ALSA] alsa-lib: conf.c:4649:(snd_config_expand) Evaluate error: No such file or directory
[AO_ALSA] alsa-lib: pcm.c:2190:(snd_pcm_open_noupdate) Unknown PCM default
[AO_ALSA] Playback open error: No such file or directory
Failed to initialize audio driver "alsa"
[AO SDL] Samplerate: 44100Hz Channels: Stereo Format s16le
[AO SDL] using aalib audio driver.
[AO SDL] Unable to open audio: No available audio device
Failed to initialize audio driver "sdl:aalib"
Could not open/initialize audio device -> no sound.
Audio: no sound
Video: no video
Exiting... (End of file)
Looks like no sound device is detected, let"s locate one.
# alsactl init
alsactl: init:1743: No soundcards found...
Hmm, no kernel modules loaded for audio perhaps?
# lsmod
Module Size Used by
fuse 49036 1
aes_generic 34484 2
arc4 764 2
zd1211rw 40444 0
mac80211 171628 1 zd1211rw
cfg80211 123084 2 zd1211rw,mac80211
Right, do we actually have a kernel module for audio?
$ modprobe -l
kernel/sound/arm/snd-bcm2835.ko
Cool! Where is the actual .ko?
$ locate snd-bcm2835.ko
/lib/modules/3.1.9+/kernel/sound/arm/snd-bcm2835.ko
Let"s load it.
# insmod /lib/modules/3.1.9+/kernel/sound/arm/snd-bcm2835.ko
insmod: error inserting "/lib/modules/3.1.9+/kernel/sound/arm/snd-bcm2835.ko": -1 Unknown symbol in module
dmesg says:
snd_bcm2835: Unknown symbol snd_ctl_add (err 0)
snd_bcm2835: Unknown symbol snd_pcm_new (err 0)
snd_bcm2835: Unknown symbol snd_card_register (err 0)
snd_bcm2835: Unknown symbol snd_card_free (err 0)
snd_bcm2835: Unknown symbol snd_pcm_lib_preallocate_pages_for_all (err 0)
snd_bcm2835: Unknown symbol snd_ctl_new1 (err 0)
snd_bcm2835: Unknown symbol snd_pcm_lib_malloc_pages (err 0)
snd_bcm2835: Unknown symbol snd_pcm_lib_ioctl (err 0)
snd_bcm2835: Unknown symbol snd_pcm_lib_free_pages (err 0)
snd_bcm2835: Unknown symbol snd_pcm_set_ops (err 0)
snd_bcm2835: Unknown symbol snd_device_new (err 0)
snd_bcm2835: Unknown symbol snd_card_create (err 0)
snd_bcm2835: Unknown symbol snd_pcm_period_elapsed (err 0)
snd_bcm2835: Unknown symbol snd_pcm_hw_constraint_step (err 0)
snd_bcm2835: Unknown symbol snd_pcm_format_width (err 0)
So it looks like snd_bcm2835 is broken.
It might be that I am blind, but I can"t seem to find any information regarding that particular module.
Any ideas?
Cheers,
Omer.
asb
Sat Apr 14, 2012 9:46 pm
Omer, did you try modprobe? insmod won"t handle module dependencies.
I haven"t tried the precise image put up for download, but the following works for me:sudo modprobe snd-bcm2835
sudo apt-get install alsa-utils
cat /dev/urandom | aplay
Sound should come out through either the 3.5mm jack or HDMI (it"s audo-detected, it will prefer HDMI I believe if your display claims support). If you need to adjust that, you can use amixer cset numid=3. This script throws up a dialog to change it:#!/bin/sh
CUR_OUTPUT=$(amixer cget numid=3 | tail -n1 | sed -e "s/[^[0-9]]*//g")
NEW_OUTPUT=$(zenity --list --title="Choose audio output (currently $CUR_OUTPUT)"
--column="Setting" --column="Description"
0 "Auto"
1 "Audio jack"
2 "HDMI passthrough")
RET=$?
if [ $RET -eq 0 ]; then
amixer cset numid=3 $NEW_OUTPUT
fi
EditArghh, wretched forum insists on stripping the backslash character in the code above. Ther eshould be a backslash after each of the lines from the NEW_OUTPUT up to and including 1 "Audio jack". In fact...http://pastebin.com/bxHnQnKz
pdp7
Sat Apr 14, 2012 10:14 pm
Thanks for the heads up, Omer! Looks like my RTL8187-based 802.11g adapter should now work. Although, it doesn't seem to have r8712u which is what my 802.11n adapters use. Fedora did have that (but also freaked out with USB hub). I look forward to trying out this new image tomorrow! [email protected]:/mnt/debian_pi/lib/modules/3.1.9+/kernel/drivers$ find . -type d |grep wireless./net/wireless
./net/wireless/rtlwifi
./net/wireless/rtlwifi/rtl8192cu
./net/wireless/zd1211rw
./net/wireless/ath
./net/wireless/ath/carl9170
./net/wireless/ath/ath9k
./net/wireless/libertas_tf
./net/wireless/rtl818x
./net/wireless/rtl818x/rtl8187
./net/wireless/mwifiex
./net/wireless/b43legacy
./net/wireless/iwmc3200wifi
./net/wireless/b43
./net/wireless/p54
./net/wireless/hostap
./net/wireless/wl1251
./net/wireless/rt2x00
pepedog
Sat Apr 14, 2012 10:33 pm
Add user to audio group so you don"t have to sudo
Omer
Sat Apr 14, 2012 10:41 pm
Ah. You are absolutely right, should"ve used modprobe!
[Also: probably should have waited until I had some sleep before accusing the kernel module of being broken ]
That kills my "Pi
Here"s what happens: [email protected]:~$ sudo modprobe [email protected]:~$ lsmod
Module Size Used by
snd_bcm2835 15304 0
snd_pcm 49240 1 snd_bcm2835
snd_seq 35080 0
snd_timer 13560 2 snd_pcm,snd_seq
snd_seq_device 3684 1 snd_seq
snd 31624 5 snd_bcm2835,snd_pcm,snd_seq,snd_timer,snd_seq_device
snd_page_alloc 2660 1 snd_pcm
fuse 49036 1 [email protected]:~$ sudo cat /dev/urandom | aplay
aplay: main:654: audio open error: Operation not permitted # So maybe set output before aplay? [email protected]:~$ sudo amixer cset numid=3 1
Message from [email protected] at Apr 14 22:35:23 ...
kernel:Internal error: Oops: 17 [#1]
kernel:Process amixer (pid: 1069, stack limit = 0xcac8a268)
kernel:Stack: (0xcac8bdd0 to 0xcac8c000)
<snip>
..and I have to power-cycle the poor thing to get it running again.
(I must admit I usually let my distro handle audio for me so I am not an alsa expert.)
Any ideas?
Thanks.
Omer
Sat Apr 14, 2012 10:47 pm
Thanks, I'll keep that in mind!
GizmoB73
Sun Apr 15, 2012 9:48 am
Hi Drew,
Hope you are having more luck with the Wireless setup than me?
I have been following Omer's wifi 'How To' which is excellent, but I have a different adapter and I guess YMMV applies here.
I have been banging my head on a wall for the last four hours without any luck using the new debian image.
I have tried two different adapters, with different but both unsuccessful results.
The Edimax EW-7811Un which seems to use the rtl8192cu drivers that I loaded via the $ sudo apt-get install firmware-realtek command.
This is definitely further than I got with the previous debian image.
Despite this, I cannot seem to get a wlan0 interface when the adapter is plugged in.
I also seem to get a long timeout (about 3 minutes I guess) with this message:
cfg80211: calling crda to update world regulatory domain
Which seems to fail in the end.
For me, the first sign of a problem is when inserting the adapter after installing the realtek drivers.  When I try $ lsusb it just seems to hang.
When I try $ dmesg I get:
usb 1-1.2: new high speed USB device number 5 using dwc_otg
usb 1-1.2: New USB device found, idVendor=7392, idProduct=7811
usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.2: Product: 802.11n WLAN Adapter
usb 1-1.2: Manufacturer: Realtek
usb 1-1.2: SerialNumber: 00e04c000001
cfg80211: Calling CRDA to update world regulatory domain
and that's the end of the dmesg.
I have also tried a Zyxel NWD2105.
This uses use the rt2870 chipset
I installed the drivers with $ apt-get install firmware-ralink
it seems to use the rt2800 driver according to the lsmod.
With this, after a reboot, I can usually get a wlan0 interface but have issues with the wpa supplicant.
When the interface starts I get:
wpa_supplicant: /sbin/wpa_supplicant daemon failed to start
run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
This is usually followed by a kernel panic shortly afterwards.
I'm going to have a rest now, but hope you have more luck.
Gary.
ferrymanr
Sun Apr 15, 2012 3:08 pm
I notice the new Debian6-13-04-2012 is less than half the size of the previous release.  I can't believe the code has been made more compact so what have we lost?
Richard
grumpyoldgit
Sun Apr 15, 2012 3:42 pm
In what way? The new image, at 1.9GB is about the same size as the previous one.
NeilNjae
Sun Apr 15, 2012 4:26 pm
Thanks for the new Debian image! The updated version, with driver modules, works a treat.
@Omer, thanks for the howto. Very useful. It was slightly different to get the WNA1100 dongle working. Here's what I did to get it going:
Unfortunately, the firmware required is in the squeeze-backports repo, so that needs to be added to the sources list. Edit the first two lines of /etc/apt/sources.list to read:
deb http://ftp.uk.debian.org/debian/ squeeze main non-freedeb http://backports.debian.org/debian-backports squeeze-backports main non-free
Then update apt and install the Atheros firmware from backports:
sudo aptitude updatesudo aptitude -t squeeze-backports install firmware-atheros
You can then follow the rest of the instructions from @Omer's howto about configuring the dongle. Alternatively, you could install and use wicd, which is probably more useful if you're moving the RPi from network to network.
NeilNjae
Sun Apr 15, 2012 5:13 pm
One other thing I had to do with the Debian image was resize it for the 8Gb SD cards I'm using. These are the steps I went through.
I did this on Ubuntu, with the card as /dev/sdd.
Start with the SD card image written to the card, in a card reader, but with nothing mounted.
$ sudo parted /dev/sdd
(parted) unit chs
(parted) print
(this gave me:)
Model: Generic- SD/MMC (scsi)
Disk /dev/sdd: 121535,3,31
Sector size (logical/physical): 512B/512B
BIOS cylinder,head,sector geometry: 121536,4,32. Each cylinder is 65.5kB.
Partition Table: msdos
Number Start End Type File system Flags
1 16,0,0 1215,3,31 primary fat32 lba
2 1232,0,0 26671,3,31 primary ext4
3 26688,0,0 29743,3,31 primary linux-swap(v1)
(Then carry on...)
(parted) move 3 118479,0,0
(parted) rm 2
(parted) mkpart primary 1232,0,0 118478,3,31
(parted) quit
$ sudo e2fsck -f /dev/sdd2
(allow it to add lost-and-found)
$ sudo resize2fs /dev/sdd2
Then put the card in the RPi and boot. You end up with a 7Gb partition...
$ df -h
Filesystem Size Used Avail Use% Mounted on
tmpfs 94M 4.0K 94M 1% /lib/init/rw
udev 10M 168K 9.9M 2% /dev
tmpfs 94M 0 94M 0% /dev/shm
rootfs 7.1G 1.3G 5.4G 20% /
/dev/mmcblk0p1 75M 28M 48M 37% /boot
ferrymanr
Sun Apr 15, 2012 5:42 pm
I was looking at the size of the zip archive, not the size of the filesystem created.  This suggests that there was either less data to compress than in the earlier version or that compression ratio has miraculously improved.
Sun Apr 15, 2012 6:06 pm
Its possible that the data on the image was more easily compressible - no miracles required.
“My wife said to me `...you’re not even listening`.
I thought, that’s an odd way to start a conversation.."
Joe Schmoe
Sun Apr 15, 2012 6:24 pm
I suppose that the obvious course of action would be to d/l the new image, mount it (the /dev/sda2 partition) on a Linux box and compare the size used to that of the size used in the old image.  Surely, someone could do that and report back...
dom
Sun Apr 15, 2012 7:09 pm
Richard
After releasing the last image a few posters commented that running "apt-get clean" would clear out the apt-get cache, which roughly halves the size of the compressed file. (Thanks for the suggestion!)
MoonTEC
Sun Apr 15, 2012 8:53 pm
Maybe now free space for better image compression was zero filled?
dd if=/dev/zero of=/erase_me.txt bs=1M count=2048
rm erase_me.txt
And as seen on .bash_history, apt cache was cleaned(makes about 320MB free space)...
sudo apt-get clean
NeilNjae
Sun Apr 15, 2012 9:01 pm
Oh, in case anyone's interested, there seems to be a bug in the Apache2 package installer that doesn't add the www-data group for the www-data (Apache) user. Fix it with
$ sudo groupadd www-data
$ sudo usermod -a -G www-data www-data
after installation, then restart Apache:
$ sudo service apache2 restart
I don't know if this is peculiar to RPi, or is an upstream bug.
Gooseman
Mon Apr 16, 2012 6:34 pm
GizmoB73 said:
Hi Drew,
Hi all,
same problem here with a Netgear N150 (RTL8188CUS chipset).. any ideas?
Achim
Tavalin
Mon Apr 16, 2012 10:58 pm
Was there a definite fix for the audio issue? I've done the apt-get install alsa-utils and the modprobe etc but it seems to cause my pi to crash when I try and play a file.
wcchandler
Tue Apr 17, 2012 11:50 pm
A twitter response sent me here, but I noticed a bug when running the Debian 04-13-2012 build.
OS: debian-04-13-2012
State: Initial Boot
Issue:
[email protected]rrypi:~$ perl test.pl
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_MESSAGES = "en_US.UTF-8",
LC_COLLATE = "en_US.UTF-8",
LC_CTYPE = "en_US.UTF-8",
LANG = "en_GB.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
To fix, run and select your locale from the menu:
[email protected]:~$ sudo dpkg-reconfigure locales
LANGUAGE = (unset),
LC_ALL = (unset),
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
/usr/bin/locale: Cannot set LC_CTYPE to default locale: No such file or directory
/usr/bin/locale: Cannot set LC_MESSAGES to default locale: No such file or directory
/usr/bin/locale: Cannot set LC_ALL to default locale: No such file or directory
Generating locales (this might take a while)…
en_GB.UTF-8… done
en_US.UTF-8… done
Generation complete.
I plan on finding many, many more of these.
wcchandler
Wed Apr 18, 2012 12:59 am
Impact: None
Type: Suggestion
[email protected]:~$ last
pi       pts/2        wrieless         Wed Apr 18 00:17 - 00:17  (00:00)
pi       pts/1        c-XX-XX-XX-XXX.h Fri Apr 13 09:43 - 00:24 (4+14:40)
pi       pts/1        wrieless         Fri Apr 13 09:05 - 09:06  (00:01)
pi       pts/0        wrieless         Fri Apr 13 09:02   still logged in
pi       tty1                          Thu Jan  1 00:03   still logged in
pi       tty1                          Thu Jan  1 00:03 - 00:03  (00:00)
reboot   system boot  3.1.9+           Thu Jan  1 00:00 - 00:57 (15448+00:56
suse     tty1                          Fri Apr 13 08:54 - down   (00:01)
suse     tty1                          Fri Apr 13 08:54 - 08:54  (00:00)
reboot   system boot  3.1.9+           Thu Jan  1 00:00 - 08:55 (15443+08:55
suse     tty1                          Fri Apr 13 08:47 - down   (00:03)
suse     tty1                          Fri Apr 13 08:47 - 08:47  (00:00)
reboot   system boot  3.1.9+           Thu Jan  1 00:00 - 08:50 (15443+08:50
root     tty1                          Thu Apr 12 15:14 - down   (00:21)
root     tty1                          Thu Apr 12 15:14 - 15:14  (00:00)
reboot   system boot  3.1.9+           Thu Jan  1 00:00 - 15:36 (15442+15:36
reboot   system boot  3.1.9+           Thu Jan  1 00:00 - 15:02 (15422+15:01
suse     tty1                          Fri Mar 23 14:55 - down   (00:05)
suse     tty1                          Fri Mar 23 14:55 - 14:55  (00:00)
reboot   system boot  3.1.9+           Thu Jan  1 00:00 - 15:01 (15422+15:00
grayg    tty1                          Fri Mar 16 15:09 - down   (00:12)
grayg    tty1                          Fri Mar 16 15:09 - 15:09  (00:00)
reboot   system boot  3.1.9+           Thu Jan  1 00:00 - 15:21 (15415+15:21
suse     tty7         :0               Mon Feb 13 10:36 - 10:41  (00:05)
grayg    tty1                          Mon Feb 13 10:28 - down   (00:14)
grayg    tty1                          Mon Feb 13 10:28 - 10:28  (00:00)
reboot   system boot  3.1.4+           Thu Jan  1 00:00 - 10:42 (15383+10:42
grayg    pts/0        dc4-arm-01.cam.b Fri Feb 10 14:11 - 14:49  (00:38)
grayg    tty1                          Fri Feb 10 14:10 - down   (00:39)
grayg    tty1                          Fri Feb 10 14:10 - 14:10  (00:00)
reboot   system boot  3.1.4+           Thu Jan  1 00:00 - 14:50 (15380+14:49
reboot   system boot  3.1.4+           Thu Jan  1 00:00 - 14:09 (15380+14:08
reboot   system boot  3.1.4+           Thu Jan  1 00:00 - 14:03 (15380+14:02
grayg    pts/0        dc4-arm-01.cam.b Fri Feb  3 12:27 - crash (-15373+-12:
reboot   system boot  3.1.9+           Thu Jan  1 00:00 - 14:03 (15380+14:03
grayg    pts/0        10.177.67.55     Tue Jan 17 15:09 - down   (00:07)
reboot   system boot  3.1.4+           Thu Jan  1 00:00 - 15:16 (15356+15:16
pauld    tty1                          Tue Jan 17 14:35 - down   (00:30)
pauld    tty1                          Tue Jan 17 14:35 - 14:35  (00:00)
grayg    tty7         :0               Tue Jan 17 14:32 - 14:34  (00:01)
grayg    pts/0        10.177.67.55     Tue Jan 17 14:31 - down   (00:35)
reboot   system boot  3.1.4+           Thu Jan  1 00:00 - 15:06 (15356+15:05
reboot   system boot  2.6.35.7         Thu Jan  1 00:00 - 11:43 (15212+11:43
pauld    pts/0        :0               Fri Aug 26 10:06 - 10:06  (00:00)
pauld    tty8         :0               Fri Aug 26 10:06 - crash (-15212+-10:
pauld    tty7         :0               Fri Aug 26 10:05 - 10:05  (00:00)
pauld    tty1                          Fri Aug 26 09:58 - 09:59  (00:00)
pauld    tty1                          Fri Aug 26 09:58 - 09:58  (00:00)
pauld    pts/0        :0               Fri Aug 26 09:46 - 10:01  (00:15)
pauld    pts/0        :0               Fri Aug 26 09:26 - 09:41  (00:15)
pauld    pts/0        :0               Fri Aug 26 09:20 - 09:22  (00:01)
pauld    tty7         :0               Fri Aug 26 09:18 - down   (00:43)
reboot   system boot  2.6.35.7         Thu Jan  1 00:00 - 10:02 (15212+10:01
mx.so.1  ibdrm.so.2   dl.so.2          Sat Feb  7 07:19 - crash (-37+-7:-18)
at.so.1  .so.1        ibexif.so.12     Sun Feb  8 01:31 - crash (-38+-1:-30)
.0.so.0  /libgdk_pixb so.0             Wed Dec 18 06:19 - crash (-20075+-6:-
mp.so.3  yring.so.0   /lib/libgmodule- Mon May  9 01:08 - crash (-19121+-1:-
o2.so.2  .0           ib/libgpg-error. Wed Sep  4 12:17 - crash (-9743+-12:-
0        stcdda-0.10. libgstaudio-0.10 Fri Feb  6 13:06 - crash (-36+-13:-6)
ibgstnet .so.0        ces-0.10.so.0    Tue Jul  1 05:38 - crash (-20270+-5:-
.1       sr/lib/libha libguileopts.so. Sat Nov 29 12:02 - crash (-22612+-12:
libicute icutu.so.44  test.so.44       Wed Apr 27 16:14 - crash (-19109+-16:
ibkeyuti libkrb5.so.3 sr/lib/libjpeg.s Sun Nov 26 15:51 - crash (-19687+-15:
bmad.so. ibmagic.so.1 .6               Tue May 20 16:06 - crash (-22419+-16:
pauld    tty7         :0               Thu Aug 25 16:56 - down   (00:03)
reboot   system boot  2.6.35.7         Thu Jan  1 00:00 - 16:59 (15211+16:58
*L       *K           *                Thu Jan  1 00:00 - crash  (00:00)
:G       *F           *                Thu Jan  1 00:00 - crash  (00:00)
FB       *A           *                Thu Jan  1 00:00 - crash  (00:00)
*=       *<           *                Thu Jan  1 00:00 - crash  (00:00)
*6       ;6           *                Thu Jan  1 00:00 - crash  (00:00)
*1       m1           *                Thu Jan  1 00:00 - crash  (00:00)
*,       *,           *                Thu Jan  1 00:00 - crash  (00:00)
*'       y'           *                Thu Jan  1 00:00 - crash  (00:00)
#       *"           *                Thu Jan  1 00:00 - crash  (00:00)
**       7.0          *                Thu Jan  1 00:00 - crash  (00:00)
pauld    tty1                          Thu Jan  1 00:00 - crash  (00:00)
pauld    tty1                          Thu Jan  1 00:00 - 00:00  (00:00)
reboot   system boot  2.6.35.7         Thu Jan  1 00:00 - 16:59 (15211+16:59
reboot   system boot  2.6.35.7         Thu Jan  1 00:00 - 17:09  (17:09)
wtmp begins Thu Jan  1 00:00:05 1970
System is completely usable...  just a suggestion.
observing
Thu Apr 19, 2012 12:44 am
Just a quick note of thanks to everyone who are contributing to this thread. Thanks to all the great information in it, I had absolutely no problems loading up Debian on an 8GB SDHC card and running it on the Pi.
davehiggins21
Thu Apr 19, 2012 12:57 pm
Don't have my PI yet but thought I would get ahead by preparing my SDHC card. I downloaded the latest Squeeze image and ran SHA1sum to check the download (on Windows XP) and got a checksum of f821205afdbd6136b0f2d32264b526b2cbddb5fc which is the same as is found in the SHA1 file which is downloaded with the image but different to the one on the downloads page which is 5e9b87ec7597f0ccae47c9cf153516fe803a4b3a.
Am I doing this wrong or understanding it wrongly??
Return to “Debian”
