jamkirbs
Rpi display via rca connector
Mon Jan 26, 2015 8:18 am
good day. I just installed an os to my rpi. It is raspbian os. I set it up using my hdtv via hdmi as its display. Now i want to connect it to my crt tv. The crt tv doesnt have a hdmi input, it only has rca component. But after plugging my rpi using rca, i dont have any display for my tv. Can someone help me. Thank you.
Re: Rpi display via rca connector
Mon Jan 26, 2015 8:21 am
Model of RPi ? A, B, A+ or B+
Did you use NOOBS to install Raspbian ?
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
jamkirbs
Mon Jan 26, 2015 9:34 am
I think it is a B model. Yes, i install raspbian using noobs. Is there any step i miss?
Mon Jan 26, 2015 9:52 am
jamkirbs wrote:I think it is a B model. Yes, i install raspbian using noobs. Is there any step i miss?
https://github.com/raspberrypi/noobs
How to change display output modes
By default, NOOBS will output over HDMI at your display’s preferred resolution, even if no HDMI display is connected. If you do not see any output on your HDMI display or are using the composite output, press 1, 2, 3 or 4 on your keyboard to select HDMI preferred mode, HDMI safe mode, composite PAL mode or composite NTSC mode respectively.
adieu
B.Goode
Mon Jan 26, 2015 9:54 am
jamkirbs wrote:i install raspbian using noobs. Is there any step i miss?
From https://github.com/raspberrypi/noobs/ -
The NOOBS interface provides the following functionality:
Install: Installs the selected OSes onto your SD card. Changing this selection erases all OSes currently installed.
[[ some options removed for clarity ]]
Display Mode Selection: By default, NOOBS will output over HDMI at your display's preferred resolution, even if no HDMI display is connected. If you do not see any output on your HDMI display or are using the composite output, press 1, 2, 3 or 4 on your keyboard to select HDMI preferred mode, HDMI safe mode, composite PAL mode or composite NTSC mode respectively.
Mon Jan 26, 2015 9:57 am
Thanks for that, great minds think the same :roll: :roll:
adieu
B.Goode
Mon Jan 26, 2015 10:05 am
fruitoftheloom wrote: Thanks for that, great minds think the same :roll: :roll:
Not trying to be annoying on purpose: clearly I was editing mine while you had already posted yours. Sometimes the forum software spots overlapping contributions and warns me, sometimes not...
jamkirbs
Tue Jan 27, 2015 6:54 am
Pressing 1,2,3,4 cannot solve the problem. I also try editing the
recovery.cmdline
but still nothing happened.
