Ancher
Raspberry Pi Midi-keyboard
Sun Nov 16, 2014 2:17 pm
Hi everyone!
Here's a little details on my Raspberry Pi Midi-keyboard project I made as a degree work at school. This is my first attempt on making something with a RaspPi. https://www.youtube.com/watch?v=mpeTHLr1vlc
I've been interested in music and technology (and music technology) for almost my entire life, and when we had to come up with something to create as a degree work at our (finnish) college, I thougt it would be awesome to combine those two and create an instrument. As I thought of a method of implementation, I came across to my RaspPi I'd had for a while, which was perfect for the project.
I'm using Debian Wheezy as the distro, for it suits well with my needs. I made the program with Python, which I'd never used before. Luckily I learned it a little along the way. As the sound driver I used ALSA which comes within the distro. The software-synthesis happens with Timidity, a software synthesizer that renders midi data in real time without an external synthesizer (please correct me if I said it wrong). With Timidy its simple to change your soundfonts by just changing the .sf2-file path to timidity's configuration file.
The code:
The program itself is quite simple. I use Pygame to recognize the keypresses and output the midi data. If the key is pressed, the defined midi value plays. If the key is raised, the sound turns off.
def keypress():
        event = pg.event.wait()
        if event.type == pg.KEYDOWN:
                if notes.get(key, 0):
                          midiout.note_on(notes.get(key) + noteOffset, velocity)
                return "d_" + key
        if event.type == pg.KEYUP:
                          midiout.note_off(notes.get(key) + noteOffset, 0)
                return "u_" + key
The notes-variable contains all the key values, for example:
notes = { "n":72, "j":73 }
etc. You can just put the key names there, and the number defines what note plays (72 is C in the 4th octave).
The rest of the code just defines different fuctions for some keys on the keyboard. With the up and down arrow keys you can change volume, left and right changes the instrument and so forth. You can really change them to do anything you like. As the keyboards layout I used a pattern made by Paul von Janko (google it). I also made a layout like in an accordion. You can change it to anything.
Mechanics:
For the project I used an old Keytronic keyboard that I bought from a local flea market for 1€. The RaspPi is a model B+, which fits under the keyboard (with the help of two drawer handles :D). I also used a ps/2-usb adapter to connect the keyboard to the RaspPi. For the speaker I used a 10€ travel speaker (which could be better...).
Pics:
https://www.dropbox.com/s/l0rry4g4ff5r0 ... 6.jpg?dl=0
https://www.dropbox.com/s/q794vuxj3pq22 ... 5.jpg?dl=0
https://www.dropbox.com/s/vg8g7gsoelg7c ... 4.jpg?dl=0
So, there's a quick introduction to my project. Please feel free to leave feedback, good or bad. Cheers!
EDIT (3.10.2017):
The needed packages for the project are Python 2.7 and Pygame for it, ALSA (Advanced Linux Sound Architecture) and Timidity. You can install them straight through apt-get or by downloading them with wget.
Timidity needs to be set to use ALSA to produce the sounds and this can be done by going to /etc/init.d/timidity (It’s there so it launches when the device boots) and adding parameters
”-iAD -B2,10 -Os”
The parameters “iAD” and “-Os” make Timidity use ALSA as the sound driver and “-B2,10” sets the buffer size to 1024. The bigger the buffer size is, the more there’s latency (if it’s too small the sound distorts).
You can change the sound “fonts” by changing the .sf2-file path in Timidity’s config file at /etc/timidity/timidity.cfg.
The program’s source code can be found at my GitHub: https://github.com/anttus/Raspberry-Mid ... eyboard.py
Images:
https://www.dropbox.com/s/jwsw89qqeajnu ... 1.jpg?dl=0
https://www.dropbox.com/s/kd2ug7sfeuvd6 ... 2.jpg?dl=0
https://www.dropbox.com/s/47nzrtr2ekidg ... 3.jpg?dl=0
https://www.dropbox.com/s/xc321690q0ksw ... 4.jpg?dl=0
https://www.dropbox.com/s/iqrdor88limg8 ... 5.jpg?dl=0
https://www.dropbox.com/s/flqxupxjbtqul ... 6.jpg?dl=0
Hopefully this clears out the project a little. :)
mahjongg
Re: Raspberry Pi Midi-keyboard
Sun Nov 16, 2014 3:22 pm
are you using the PI's USART for a MIDI interface? With a couple of optocouplers and some DIN connectors you can build a real MIDI interface.
The PI supports the special MIDI baud rate that is needed.
discussion about setting the 31250-baud rate is here: viewtopic.php?f=63&t=19908
Ancher
Sun Nov 16, 2014 3:42 pm
mahjongg wrote:are you using the PI's USART for a MIDI interface? With a couple of optocouplers and some DIN connectors you can build a real MIDI interface.
I do not use Pi's USART. Thanks for the tip, though, I really hadn't thought about that... :)
TonyD
Mon Nov 17, 2014 4:29 pm
mahjongg wrote:...The PI supports the special MIDI baud rate that is needed.
Where would I find more information on setting the 31250-baud rate on the Pi?
[mod edit] here: viewtopic.php?f=63&t=19908
Tony
Ravenous
Mon Nov 17, 2014 5:22 pm
I like the idea. Especially the raspi mounted underneath between the handles.
This reminds me - a while ago this project was on the front page:
http://www.raspberrypi.org/joytone/
That one might be interesting to you, as normal PC keyboard keys are roughly in a "hexagonal" arrangement. So with the right "isomorphic" arrangement of keys you can play in any key with a simple change of position. Of course there are only four rows of keys on a regular keyboard so the amount of different keys would be limited, but it might be worth trying :)
EDIT: I just googled Paul von Janko, and realised his keyboard arrangement IS isomorphic. So I think you've already built one! :oops:
Ancher
Mon Nov 17, 2014 5:30 pm
Ravenous wrote:I like the idea. Especially the raspi mounted underneath between the handles.
That Joytone is something very, very cool! :D And yes, I think the Janko's layout is sort of isomorphic and it would be nice if there was like double the amount of keys on the keyboard...
Nerelod
Sat Sep 30, 2017 1:45 pm
Awesome project, I wanted to do this for a while, but I have no one to help me. So if you can make a more in depth guide of how to set up all of the software, it would make me very happy. Thanks.
mlepage
Sat Sep 30, 2017 4:28 pm
That is wild. Great job.
I've been pondering the idea of getting a cheap MIDI keyboard and using a Teensy (microcontroller board) to make a digital software synth with its analog outputs. Some day...
Ancher
Tue Oct 03, 2017 3:31 pm
Thanks! I've edited the description a little and added the source code. Hopefully it helps you. :)
Ancher
Tue Oct 03, 2017 3:32 pm
Thanks! That sounds like a cool project. Let me know how it turns out. :)
Nerelod
Thu Oct 05, 2017 9:23 pm
Awesome, Im going to start working on my version now, Great project!
Nerelod
Thu Oct 05, 2017 10:16 pm
Sorry but im a new and my teacher is not good at this and I got this error:
File "/home/pi/Desktop/MusicKey/Raspberry-MidiKeyboard/midikeyboard.py", line 23 in <module>
midiout = pg.midi.Output(3)
File "/usr/lib/python2.7/dist-packages/pygame/midi.py", line 414, in __init__
raise MidiException("Device id invalid, out of range.")
MidiException: 'Device id invalid, out of range.'
Ancher
Sat Oct 07, 2017 8:49 am
The port number needs to be the same as it is in ALSA configuration, I think.
Nerelod
Sat Oct 07, 2017 1:12 pm
I will spend the rest of my evening working on this, I am determined to finish this project. So anymore details are very much welcome, im new to linux. Thanks! :D
stewkingjr
Sun Jan 07, 2018 1:55 pm
Thanks for posting your project. I'm currently "renovating" an older electronic organ with multiple keyboards and stops. I handle the keys ok and am working on handling the stops but i have been procrastinating on a decision of sound. Your work had given me a possible solution for generating the tones. Thanks!
Ancher
Mon Jan 08, 2018 8:20 am
Wow, thanks! Good luck with your project. :)
dazzy
Sun Mar 18, 2018 6:14 pm
I'm trying to make a keyboard like this for a school project but I'm not really very well versed in Linux nor programming generally and I get this error:
File "123.py", line 72, in <module>
key = keypress()
File "123.py", line 44, in keypress
key = pg.key.name(event.key)
AttributeError: 'Event' object has no attribute 'key'
It might be a really simple problem but I don't know how to solve it.
Ancher
Mon Mar 19, 2018 2:05 pm
key = keypress()
Hi and thanks for checking this out!
I'm not sure what kind of set up you have but one thing that you could do is check if the indentations of the code are correct (because Python needs that). There could also be some problem with Pygame and the program can't find "event = pygame.event.wait()".
Andreas5204
Tue Apr 07, 2020 10:53 pm
I'm currently trying to build this project. Can you help me reslove this problem? I'm getting the same error message and I don't know what to do.
