9and3r
mopidy-touchscreen extension
Tue Jul 22, 2014 1:15 pm
Mopidy-Touchscreen
Hi.
I am developing an extension for mopidy.
The idea is to control the music from a touchscreen (In the future maybe also with buttons).
You can also see information and cover image of the song playing.
Features
Working
  • Seek Track
  • Play/Pause
  • Mute/Unmute
  • Change volume
  • Next/Previous track
  • See track info (track name, album, artist, cover image)
  • Shuffle on/off
  • Repeat one/on/off
  • Playback list and control
  • Playlists
  • Library
  • Menu (exit mopidy, restart...)
Planned
  • Use keyboard or GPIO buttons instead of touchscreen
Video
Example video showing the extension working on Ubuntu
Screenshots
Extension running on Texy's display
Code
Code on Github
Help will be appreciated :)
9and3r
Re: mopidy-touchscreen extension
Sun Aug 03, 2014 1:06 pm
First working version released (0.2.1 version)
Installation
First install mopidy
Install extension:
sudo pip install Mopidy-Touchscreen
It should work on Pi MusicBox but It has not been tested yet.
P4d0uch
Sun May 03, 2015 10:56 am
Hi, I tried your extension and i love it. But every time i start playing new song i get this error
WARNING  Element doesn't implement handling of this stream. Please file a bug.
ERROR    Unhandled exception in TouchScreen (urn:uuid:50c87d53-1467-451b-8ee6-4d37c7d53379):
  File "/usr/lib/python2.7/dist-packages/pykka/actor.py", line 200, in _actor_loop
    response = self._handle_receive(message)
  File "/usr/lib/python2.7/dist-packages/pykka/actor.py", line 294, in _handle_receive
    return callee(*message['args'], **message['kwargs'])
  File "/usr/lib/python2.7/dist-packages/mopidy/core/listener.py", line 33, in on_event
    getattr(self, event)(**kwargs)
  File "/usr/local/lib/python2.7/dist-packages/Mopidy_Touchscreen-0.3.2-py2.7.egg/mopidy_touchscreen/touch_screen.py", line 107, in track_playback_ended
    time_position)
  File "/usr/local/lib/python2.7/dist-packages/Mopidy_Touchscreen-0.3.2-py2.7.egg/mopidy_touchscreen/screen_manager.py", line 130, in track_playback_ended
    self.screens[main_screen_index].track_playback_ended(tl_track, time_position)
  File "/usr/local/lib/python2.7/dist-packages/Mopidy_Touchscreen-0.3.2-py2.7.egg/mopidy_touchscreen/main_screen.py", line 249, in track_playback_ended
    self.dirty_area.append(pygame.Rect(self.base_size / 2,
AttributeError: MainScreen instance has no attribute 'dirty_area'
Should i care?
9and3r
Mon May 04, 2015 10:53 pm
Glad you like the extension. This is a bug. It is already fixed on github. You can use the develop version of github or wait until I release a new version to pipy.
uselesshippy
Thu Aug 25, 2016 1:16 pm
Hi
I'm having problems installing this, I am running rasbpian on a pi 3.
I get the following:
Downloading/unpacking Mopidy-Touchscreen
Cleaning up...
Exception:
File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 122, in main
status = self.run(options, args)
File "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line 290, in run
requirement_set.prepare_files(finder, force_root_egg_info=self.bundle, bundle=self.bundle)
File "/usr/lib/python2.7/dist-packages/pip/req.py", line 1178, in prepare_files
url = finder.find_requirement(req_to_install, upgrade=self.upgrade)
File "/usr/lib/python2.7/dist-packages/pip/index.py", line 194, in find_requirement
page = self._get_page(main_index_url, req)
File "/usr/lib/python2.7/dist-packages/pip/index.py", line 568, in _get_page
session=self.session,
File "/usr/lib/python2.7/dist-packages/pip/index.py", line 694, in get_page
req, link, "connection error: %s" % exc, url,
TypeError: __str__ returned non-string (type Error)
Storing debug log for failure in /root/.pip/pip.log
root@raspberrypi:/home/pi#
am I doing something wrong?
chross
Tue Jun 06, 2017 8:56 am
I tried to install this on Pi MusicBox 0.7RC4 and got this error message:
 Downloading pygame-1.9.3.tar.gz (3.0MB)
    100% |################################| 3.0MB 9.4kB/s
    Complete output from command python setup.py egg_info:
    WARNING, No "Setup" File Exists, Running "config.py"
    Using UNIX configuration...
    sh: 1: sdl-config: not found
    sh: 1: freetype-config: not found
    Hunting dependencies...
    WARNING: "sdl-config" failed!
    WARNING: "freetype-config" failed!
    Unable to run "sdl-config". Please make sure a development version of SDL is                           installed.
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-Gk                          Oxyn/pygame/
/usr/local/lib/python2.7/dist-packages/pip/_vendor/requests/packages/urllib3/uti                          l/ssl_.py:122: InsecurePlatformWarning: A true SSLContext object is not availabl                          e. This prevents urllib3 from configuring SSL appropriately and may cause certai                          n SSL connections to fail. You can upgrade to a newer version of Python to solve                           this. For more information, see https://urllib3.readthedocs.io/en/latest/securi                          ty.html#insecureplatformwarning.
Could anybody tell me how to fix the installation?
Cheers
Christian
