Take Timed Pictures and Upload
Posted: Sat Jun 14, 2014 2:01 am
by demonmaestro
Okay is there any software or something that i can use that will take a picture from a webcam at say ever 60 minutes and upload them via ftp to a server?
Thank you for all the help in advanced.! :D
Re: Take Timed Pictures and Upload
Posted: Sat Jun 14, 2014 2:47 am
by danjperron
Check post for time lapse.
A lot of them use motion or mjpg-streamer.
I prefer mjpg-streamer but your webcam need to be mjpeg compatible.
http://www.raspberrypi.org/forums/viewt ... 19#p471519
1- I use crontab to capture one image every minute to create time lapse. Every hour will be the same thing.
2- I also add a water mark with the current time and temperature.
3- Then I transfer the image into my NAS server , a Mybook live from WD.
4- At midnight every day , a cron tab script take each snapshot and record a small video of the day.
This is an example of timelapse. One picture every minute.
https://dl.dropboxusercontent.com/u/488 ... _12_15.mp4
I do have a D.I.Y but it is in french and it's more than timelapse. The state is still preliminary.
https://docs.google.com/document/d/1512 ... sp=sharing
If you decide to try mjpg-streamer , these scripts will help you to start
First, a script to start mjpg-streamer with a 720P webcam (compatible mjpeg)
streamer720p.sh
killall mjpg_streamer
/usr/local/bin/mjpg_streamer -i "/usr/local/lib/input_uvc.so -n -f 10 -r 1280x720" -o "/usr/local/lib/output_http.so -p
10088 -w /usr/local/www" &
A script to capture and transfer image into a ftp site
SnapShot.py
#!/usr/bin/python
import time
import os
import sys
import re
import subprocess
import datetime
now = datetime.datetime.now()
# capture image
SnapImage = "/var/www/chart/data/image.jpg"
subprocess.call(["/usr/bin/wget","-O",SnapImage,"http://127.0.0.1:10088/?action=snapshot"])
# create a stamp image file
StampImage = "PondImg_" + now.strftime("%Y_%m_%d_%H_%M_%S") + (".jpg")
# transfer image to mycloud WD disk
subprocess.call(["/usr/local/bin/FtpImage.sh",SnapImage,StampImage,"userName","userPassword"])
And the script to ftp
ftpImage.sh
#!/bin/bash
IN_LOCAL=$1
OUT_REMOTE=$2
USER=$3
PASSWD=$4
sleep 5
ftp -v -n 10.11.12.4 <<END_OF_SESSION
user $USER $PASSWD
cd /Daniel/PiData/Images
prompt off
binary
put $IN_LOCAL $OUT_REMOTE
bye
END_OF_SESSION
Daniel
Posted: Sat Jun 14, 2014 2:55 am
by demonmaestro
Thank you for responding. But I am just wanting to take a picture ever hour and upload it to my web server that is all.
The link you sent me to for mjpg-streamer is the one i had wrote.
Posted: Sat Jun 14, 2014 3:06 am
by danjperron
Create a script with fswebcam to capture image and use the script from my post to transfer in ftp
Run the script by crontab every hour
Daniel
Posted: Sat Jun 14, 2014 3:47 am
by demonmaestro
I was to be honest looking for step by step instructions ;)
Posted: Sat Jun 14, 2014 9:09 am
by DougieLawson
demonmaestro wrote:I was to be honest looking for step by step instructions ;)
http://www.instructables.com/id/Simple- ... i-and-a-c/
You'll want to update the code
time.sleep(60)
to
time.sleep(3600)
so that it only gets a photo every hour (rather than every minute)
Posted: Sat Jun 14, 2014 1:26 pm
by danjperron
In the learning place,
the timelapse method is already there in step by step mode.
http://www.raspberrypi.org/learning/web ... pse-setup/
The only thing to change is the script you put into the crontab.
1 - install fswebcam
sudo apt-get install fswebcam
2- install ftp
sudo apt-get install ftp
3- create a script to capture and transfer via ftp
#!/bin/bash
#change these parameters to fit your need
USER=Daniel
PASSWD=12345
SERVERIP=10.11.12.4
#do fswebcam twice , the first is to get webcam in stable condition
fswebcam -r 1280x720 --no-banner /dev/null -F 3
sleep 2
fswebcam -r 1280x720 --no-banner   $IN_LOCAL
#ok now we will transfer via ftp
/usr/bin/ftp -v -n $SERVERIP <<END_OF_SESSION
user $USER $PASSWD
cd /Daniel/SnapFolder
prompt off
binary
bye
END_OF_SESSION
4 - make it runnable
sudo chmod +x SnapShot.sh
5 - finally add the script into the crontab.
sudo crontab -e
0 * * * * /home/pi/SnapShot.sh
I prefer crontab for two reasons. you are not using resource in between snapshot and in case of software crash/kill it will restart itself every hour.
I hope this is good enough for you.
B.T.W. if you are using sftp instead , it will be better since you could use scp command. But this is a different story.
N.B. I use a static file name. If you want to keep the image you will need to add the date stamp into the file.
Daniel
