spacetime
DVB-T stick with AF9015
Fri Jun 01, 2012 9:09 pm
I'm trying to install DVB-T stick with AF9015 to be used with w_scan (using Debian image).
http://elinux.org/RPi_VerifiedPeripherals says it should work.
Can somebody who managed to install it describe what needs to be done in order to make it work?
I was also trying to add V4L-DVB to the Debian image.
But the compilation always ends with some error.
Any hint appreciated.
Pascal is easy to write and easy to read
turbopascal.org
dukla2000
Re: DVB-T stick with AF9015
Fri Jun 01, 2012 9:28 pm
Daily driver: Pi3B, 64GB Samsung Evo+ @100MHz, DVB-T, onboard WiFi for internet, BT/USB dongle for KB/mouse, 250GB HDD via USB for media, Raspbian Jessie Lite with Openbox desktop.
Museum: Pi B
spacetime
Sat Jun 02, 2012 10:38 pm
Thanks.
Finally I managed to make it work.
I had to compile a new kernel with dvb support.
Credits also go to Mark.
turbopascal.org
FelipeGar
Thu Nov 22, 2012 10:53 pm
Hello:
I also have a af9015 stick and i'm new with R.PI.
¿Can you tell me how to compile a kernel with dvb support?
spacetime
Fri Nov 23, 2012 10:34 am
RPi Kernel Compilation
http://elinux.org/Rpi_kernel_compilation
Before compilation enable at least the following modules (menuconfig):
<M> DVB for Linux
[*] Load and attach frontend and tuner driver modules as needed
[*] DVB/ATSC adapters --->
<M> Support for various USB DVB devices
<M> Terratec CinergyT2/qanu USB 2.0 DVB-T receiver
<M> Afatech AF9015 DVB-T USB2.0 support
turbopascal.org
rivalcomp
Fri Nov 23, 2012 10:48 am
Sorry if it's not relevant here.
I've tried to install my stick with AF9015 chipset successfully under Raspbmc. In addition to having DVB support kernel (Raspbmc already has it) you'll need a firmware from here: http://www.otit.fi/~crope/v4l-dvb/af901 ... es/4.95.0/ Place this file to /lib/firmware directory. Several pages say you don't need firmware for this chipset because of kernel support (firmware is already compiled into the kernel?) but by looking at dmesg you can see an error message about seraching for a firmware file mentioned above.
I could run tvheadend and watch only one channel. But no more. Something is wrong with my system (stick/power supply/DVB-T coverage) so it's not working properly but the stick was recognized by kernel and tvheadend.
Raspberry Pi 512MB
cjan
Sat Nov 24, 2012 10:07 am
wonder which player can do DVB-T ? vlc can not do, i mean not under xmbc.
