kidkangaroo
bluetooth headless deck for car - EL-D01 USB DAC no sound!
Mon Mar 03, 2014 3:21 pm
Hi guys - I'm working on getting a EL-D01 USB DAC work. I've built the bluetooth headless pi for streaming audio direct to my amp in my car (see instructables for great tutorial!)
Anwyay - so it plays from the headphone jack just fine, just can't get it to output or work with the DAC.
I think it can see it just fine:
pi@raspberrypi ~ $ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: DAC [USB Audio DAC], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
  Subdevices: 7/8
  Subdevice #1: subdevice #1
  Subdevice #2: subdevice #2
  Subdevice #3: subdevice #3
  Subdevice #4: subdevice #4
  Subdevice #5: subdevice #5
  Subdevice #6: subdevice #6
  Subdevice #7: subdevice #7
pi@raspberrypi ~ $ aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
pulse
Playback/recording through the PulseAudio sound server
sysdefault:CARD=DAC
USB Audio DAC, USB Audio
Default Audio Device
front:CARD=DAC,DEV=0
Front speakers
surround40:CARD=DAC,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=DAC,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=DAC,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=DAC,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=DAC,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=DAC,DEV=0
IEC958 (S/PDIF) Digital Audio Output
sysdefault:CARD=ALSA
bcm2835 ALSA, bcm2835 ALSA
I've updated /etc/modprobe.d/alsa-base.conf with the following: (found on http://drewlustro.com/hi-fi-audio-via-a ... spberry-pi)
#options snd-usb-audio index=-2
options snd-usb-audio nrpacks=1
and also updated /etc/asound.conf with the following:
pcm.mmap0 {
    type mmap_emul;
    slave {
      pcm "hw:0,0";
pcm.!default front:DAC
But still no love...
