pkrakow
Audio Input w/ Pure Data: Frustratingly Close
Sun Feb 23, 2014 6:24 pm
Hi. I've been trying to get Audio Input and Output working on Pure Data for almost a year now (on and off with lots of frustration between sessions). I'm very close to getting it running, but I can't seem to get all the pieces working at once. I'd like some help.
Here's a quick status on my setup:
- I have the latest distribution of Raspian Wheezy.
- I have an logilink UA0053 USB soundcard (http://elinux.org/RPi_VerifiedPeriphera ... ound_Cards)
- I can get glitch-free audio output from Pure Data: [osc~ 440] ---- [dac~]
- I can record glitch-free audio using the following commands:
amixer sset Mic Capture 100%
arecord -d 4 -f dat /tmp/test.wav
aplay /tmp/test.wav
- I can get Pure Data to pick-up input from the microphone and route it to my soundcard, but the sound is really glitchy. This is with the exact same settings as the audio output test (ALSA)
- If I use QjackCtl to enable JACK, all audio stops working (see attached image)
Any thoughts or ideas? I'm pretty flummoxed by how difficult it is to get this working on the Pi.
pdMicrophone JACK (Silent).gif (46.58 KiB) Viewed 4008 times
pkrakow
Re: Audio Input w/ Pure Data: Frustratingly Close
Tue Feb 25, 2014 5:32 am
So I played around with QJackCtl settings this evening (see attached image), and I've made some progress. I can now get glitch free audio going from the microphone to the speakers (which is a major milestone). The only problem is that I've still got ~300ms of latency from the microphone to the speakers (which is way too much for my application).
I've emulated the Jack settings from the low latency audio page: http://wiki.linuxaudio.org/wiki/raspberrypi but the audio is still laggy. I'm going to play around with some other system settings this evening to see if I can tackle this tonight.
Updated QJackCtl Settings
pdMicrophone JACK (Delayed Loopback).gif (11.48 KiB) Viewed 3959 times
evanfeenstra
Fri Feb 28, 2014 5:21 am
Have you added dwc_otg.speed=1 to the cmdline.txt file? Audio input has to use usb speed 1 for some reason...
With this line added I have been able to record quality audio into puredata using ALSA
pkrakow
Sat Mar 01, 2014 10:52 pm
Yup. I've done that. I've been running PD through a VNC client. I'm going to try running it in headless mode, but for some reason jackd won't work from the command line. I get an error saying "JackServer::Open failed with -1"
"Failed to open server"
J__
Thu Apr 10, 2014 2:08 pm
Hello
Can you give any information about how did you manage to get audio out working fine on puredata?
[osc~ 440] ---- [dac~] makes a terrible glitch for me.
Same for the input, big crackles.
I run a creative sound blaster play;
I tried with usb speed 1. Audio works fine when I'm testing playing a single file
(aplay /usr/share/scratch/Media/Sounds/Vocals/Singer1.wav )
thanks for your advices,
J.
pkrakow
Thu Sep 18, 2014 4:58 am
I finally got everything working, and it was super easy. Here's what I did:
1) I bought a Wolfson Audio Card:
http://www.element14.com/community/comm ... wolfson_pi
2) I downloaded a Raspbian image that has the Wolfson drivers:
http://www.element14.com/community/mess ... oad#107186
3) I Installed Pure Data
J__
Thu Sep 18, 2014 9:13 am
I did the following to get it working:
USB 1 and turbo mode off, plus the following cmdline:
dwc_otg.speed=1 dwc_otg.microframe_schedule=1 dwc_otg.fiq_fix_enable=1 dwc_otg.lpm_enable=0 smsc95xx.turbo_mode=N sdhci-bcm2708.sync_after_dma=0 sdhci-bcm2708.enable_llm=1 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
and changing the input to 1 channel instead of 2 (pd -nogui -inchannels 1 -r 44100 )
RaTTuS
Contact: Twitter YouTube
Thu Sep 18, 2014 9:20 am
use 48khz audio data instead of 44.1Khz
Covfefe
