jezmck
USB Webcam? (Command Line)
Tue May 29, 2012 11:02 pm
I'm quite an experienced linux user when it comes to using it as a web server, but need help with this.
(Debian)
I've seen a number of pages about using a webcam from the command line, in particular this page, but /dev/video0 doesn't exist.
Running usb-devices I get
T:  Bus=01 Lev=02 Prnt=02 Port=01 Cnt=02 Dev#=  5 Spd=480 MxCh= 0
D:  Ver= 2.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS=64 #Cfgs=  1
P:  Vendor=045e ProdID=0770 Rev=00.26
S:  Manufacturer=Microsoft
S:  Product=Microsoft LifeCam-VX700  v2.0
C:  #Ifs= 4 Cfg#= 1 Atr=80 MxPwr=168mA
I:  If#= 0 Alt= 0 #EPs= 1 Cls=0e(video) Sub=01 Prot=00 Driver=(none)
I:  If#= 1 Alt= 0 #EPs= 0 Cls=0e(video) Sub=02 Prot=00 Driver=(none)
I:  If#= 2 Alt= 0 #EPs= 0 Cls=01(audio) Sub=01 Prot=00 Driver=snd-usb-audio
I:  If#= 3 Alt= 0 #EPs= 0 Cls=01(audio) Sub=02 Prot=00 Driver=snd-usb-audio
So it has been detected, but I don't understand what step(s) there are in the middle.
Any help will be appreciated.
slimdan22
Re: USB Webcam? (Command Line)
Thu May 31, 2012 5:17 pm
They added USB Webcam support on the Raspberry Pi yesterday according to their Github
https://github.com/raspberrypi/firmware ... c66b1a95f8
You can just download the new modules, or use the Raspberry-PI update tool by Hexxeh
http://hexxeh.net/?p=328117855
jezmck
Thu May 31, 2012 5:49 pm
Ooh, cool.
I'll try the rpi-update firmware updater by Hexxeh.
markb
Fri Jun 01, 2012 4:09 pm
No can do, I repeatable
get:
connecting to http|92.242.132.15|:21... failed: connection timed out.
any ideas?
markb
Sat Jun 02, 2012 11:08 am
markb wrote:No can do, I repeatable
get:
any ideas?
My fault! however when I try and run rpi-upgrade I get a message "1: syntax error: redirection unexpected
netomx
Sat Jun 02, 2012 11:07 pm
it seems we need a module
edit: anoyone eith the zc3xx.c module already compiled for the latest kernel?
Trevor.Cushen
Wed Jun 13, 2012 1:12 pm
http://blog.pixelami.com/2012/06/raspbe ... n-squeeze/
this link worked for me but check the comment I made about the wget URL and don't over look the ldconfig tip
Good luck :)
ashigupta
Wed Sep 12, 2012 5:47 am
hii..
i am not able to set up /dev/video0 drive which is required to use usb webcam to capture images or videos...if someone has setup usb cam on debian version...tell me how to setup this....
thanx in advance...
