Breee
Mopidy + Spotify
Fri Jan 10, 2014 6:03 pm
Hi there!
I'm trying to set my PI to be a file and audio server. I was able to set up the file server, but i failed miserably while installing/configuring mopidy. My only source for audio is spotify. I also need some kind of software (web, windows, windows phone 8) to control mopidy.
My OS is raspbian.
Anyways, I tried to install mopidy using this ( http://docs.mopidy.com/en/latest/instal ... spberrypi/ ) tutorial, i guess it installed correctly, but i'm not able to start it.
Does anyone know any step-by-step tutorial on how to install this kind of system correctly, or do you happen to know how to do it?
Thanks.
Morfeus
Re: Mopidy + Spotify
Sat Jan 11, 2014 7:49 am
What happens if you type mopidy and hit enter at the terminal? Please post the output.
There is a very nice GUI to control mopidy, spottily and more:
http://sourceforge.net/projects/rompr/
Breee
Sat Jan 11, 2014 9:34 am
Output:
INFO Starting Mopidy 0.17.0
INFO Loading config from: builtin defaults, command line options
INFO Initialized $XDG_CONFIG_DIR/mopidy/mopidy.conf with default config
INFO Loading config from: builtin defaults, /home/pi/.config/mopidy/mopidy.conf, command line options
INFO Enabled extensions: spotify, mpd, http, stream, local
INFO Disabled extensions: none
ERROR Config value local/media_dir must be set.
Morfeus
Sat Jan 11, 2014 2:10 pm
Did you edit mopidy.conf at all? You'll find a how-to on the mopidy website.
Anyhow, it seems you did not. The directory where your local music is, must be set in mopidy.conf, as the last line of the output clearly tells you. Probably some other entries are also missing, but the startup stops there.
Please post your mopidy.conf
Steven007
Tue Apr 15, 2014 2:07 pm
I am a complete newbe in the use of linux and raspberry pi.
I have installed on my raspberry pi the Wheezy image and mopidy with spotify and soundcloud.
But can not start mopidy
I changed the /home/../.config/mopidy/mopidy.conf
but the changes doesn't work
charliedk
Sun Jan 25, 2015 9:10 pm
I fixed this problem.
Open Terminal and type:
sudo -i
nano /root/.config/mopidy/mopidy.conf
And then edit the file with the correct path.
