I have recently made a tutorial for Adafruit's fantastic small OLED Displays... You can check it out here: http://www.youtube.com/watch?v=BeBfpJnN ... z0nLaGygPw
This forum post is simply a write up of the commands that I use in the video, so if you want to give it a go then it will all make more sense if you watch the tutorial!
1) After you have wired up your display boot up your Raspberry Pi and log in. You do not need to start up the desktop! We will only be using the terminal.
2) The first thing that we will need to do is to make sure that we have git-core installed. This will allow us to download all of the necessary libraries later. You can do this with this command:
sudo apt-get install git-core
sudo nano /etc/modprobe.d/raspi-blacklist.conf
blacklist spi-bcm2708
# blacklist spi-bcm2708
sudo reboot
git clone https://github.com/the-raspberry-pi-guy/OLED
6) Now change in to your new OLED directory with the command:
cd OLED
sh OLEDinstall.sh
8) Now that we have everything installed we can use the Python examples that I have provided. Change into the python-examples directory with the command:
cd python-examples
OLEDtext.py is the most basic and it displays text in various forms on to your OLED display. This illustrates font size and positioning.
OLEDip.py finds your internal IP address and prints it to the display. Perfect for all those SSHing people out there!
OLEDclock.py displays the date and clock... It does so by vertically scrolling every second
OLEDimage.py takes any image and converts it into a usable format. It then displays it on the OLED display!
10) You use these programs by typing:
sudo python OLEDtext.py
sudo python OLEDip.py
sudo python OLEDclock.py
sudo python OLEDimage.py <nameofimage>
I have included some pictures of penguins as an example of the OLEDimage.py program... Use it with this command:
And that is it! I hope that you enjoy the tutorial and if you have any problems/issues please address them where I will see them at: theraspberrypiguy@gmail.com
Thanks for watching!
The Raspberry Pi Guy
