matt.b
Help with building and installing snd-aloop
Sun Nov 24, 2013 7:14 pm
Dear all,
i want to install snd-aloop on my Raspberry. On http://confoundedtech.blogspot.de/2012/ ... pback.html i found a tutorial for Ubuntu.
With this tutorial i tried to install it on wheezy.
On Step 8 i run the config
sudo ./configure --with-cards=bcm2835,loopback,hrtimer --with-sequencer=yes
and i get the message:
checking for directory with kernel source... Please install the package with full kernel sources for your distribution
or use --with-kernel=dir option to specify another directory with kernel
sources (default is /usr/src/linux).
Since this error "make" isn't running:
make all-deps
make[1]: Entering directory `/usr/src/modules/alsa-driver-1.0.25'
make[1]: Für das Ziel »all-deps« ist nichts zu tun.
make[1]: Leaving directory `/usr/src/modules/alsa-driver-1.0.25'
Please, run the configure script as first...
Does somebody know what to do?
matt
AutoStatic
Re: Help with building and installing snd-aloop
Sun Nov 24, 2013 7:19 pm
matt.b wrote:Does somebody know what to do?
sudo modprobe snd-aloop
The snd-aloop module is already included in the RPI default kernel.
RPi and real-time, low-latency audio: http://wiki.linuxaudio.org/wiki/raspberrypi
RPi audio repository: http://rpi.autostatic.com/
RPi and audio blog: https://autostatic.com/tag/raspberrypi/
