MacFizz
Performance of transcoding video with ffmpeg/avconv
Thu Nov 14, 2013 9:00 am
Hi
I need to convert mp4 videos to other formats (mostly xvid and flv).
It all works OK using avconv but it is very slow.
It's encoding at less than 1 frame per second !!!
- Why is it so slow ?
- Is there a way to improve this ?
Thx
Macfizz
topguy
Re: Performance of transcoding video with ffmpeg/avconv
Thu Nov 14, 2013 9:32 am
Because the CPU on the PI is not very powerful.
And ffmpeg/aconv dont use the GPU to help with decoding/encoding.
You can reduce video resolution and/or quality.
MacFizz
Thu Nov 14, 2013 9:58 am
Well, while I do get the fact that the RPI is a single core arm CPU running at 700MHz, I still don't understand how and why it can't decode and encode faster than 1fp/s.
Also, the video sources are 1280*720 and the output files are 720*384.
Now, it's my understanding that decoding a video is going well with a RPI because it uses the GPU hardware decoding capabilities, is there a way to use that to decode and encode ?
redhawk
Thu Nov 14, 2013 10:00 am
There is a GPU accelerated enabled tool called omxtx for video encoding, I've never used this myself so I cannot comment on it's effectiveness. - https://github.com/dickontoo/omxtx
Why are you transcoding these files anyway the Pi's GPU has hardware decoding for DivX, xVid and FLV (with h.264)??
If you want to change the container but retain the codec data you can use ffmpeg's codec copy option i.e.
ffmpeg -i in_file.flv -acodec copy -vcodec copy out_file.mp4
Richard S.
MacFizz
Thu Nov 14, 2013 12:32 pm
Well, I've heard of omxtx but I've been unable to compile it.
The rpi can read those video just fine and I would need any conversion if those videos didn't need to be read on other devices.
Would there be anyway to use something like mplayer to decode the video using the GPU and pipe it through avconv or the GPU. There's a camera existing for the rpi, I doubt it record and encode video at 1fp/s.
Would it speed the process using something like mplayer myvideo.mp4 | avconv myvideo.avi ?
thx
