Oops, sorry! I paid half that from here: http://www.pixmania.co.uk/uk/uk/search/ ... play-list/ though their stock level was a lot better with all colours when I bought mine. Shop around -- anything more than £40 /Off-topic but wow, "cheap" definitely subjective with £75 for a tiny speaker set.
Though, since the 0 - 3v3 swing of the (PWM) audio is devided down by the potential devider to only 1v p-p, and therefore only go ±0.5v, those diodes won't have much effect.karlkiste wrote:The protective diodes on the Pis analog audio out are unwisely connected AFTER the dc-blocking capacitors, therefore the outputs can not swing more than ~0.6V to the negative side. External bias to +1V or so could improve the sound when connecting to an amplifier with high input impedance.
This explanation had made more sense to me, if both the anodes and the cathodes had been connected to GND. Then the swing would be limited to ±0.6v. Now it is limited to -0.6/+4.1v. Looks a bit like not much thought of to me.Though, since the 0 - 3v3 swing of the (PWM) audio is devided down by the potential devider to only 1v p-p, and therefore only go ±0.5v, those diodes won't have much effect.
Agreed - I'd have put it before the cap, where it would protect the GPIO. But it hasn't changed since the first version, so maybe the designer knows more than me?karlkiste wrote:This explanation had made more sense to me, if both the anodes and the cathodes had been connected to GND. Then the swing would be limited to ±0.6v. Now it is limited to -0.6/+4.1v. Looks a bit like not much thought of to me.
I presume, the problem is - that it worksBut it hasn't changed since the first version, so maybe the designer knows more than me?
