lithium630
adding a speaker
Sun Sep 01, 2013 12:05 am
I'm trying to stuff a Pi into an original Nintendo Gameboy case to make a portable Mame device. Most of the parts are on order. I would like to add a speaker to give the option of headphones or external sound. I found several similar projects but none that use a speaker. This is all new to me and I'm using this project to learn (and teach my kids). I would appreciate any links to similar setups.
Hove
Re: adding a speaker
Sun Sep 01, 2013 7:10 am
The only real difference between headphones and speakers is the current they draw and hence how loud they are; headphones only need small current since they are so close to your ears; speakers need much higher current to produce what seems like a similar volume because they are so much further from your ears. It's the current that's the problem to solve: the Raspberry Pi cannot supply the current required by a passive speaker, so you'll either need to buy a set of powered speakers you can plug into the RPi headphoe jack (I use these http://www.amazon.co.uk/Edifier-Aurora- ... B003TWN684 as they are cheap and sound great, or you'll need to build an audio power amplifier to do the same things. That's not as bad as it sounds - I've just dug this up http://uk.farnell.com/stmicroelectronic ... dp/1842519 from farnell / element 14 / Newark that should so the job nicely - there's many others available, this was just a 30s scan. You'll need a power supply more powerful than a mobile charger for driving the amp / speakers too.
www.pistuffing.co.uk - Raspberry Pi and other stuffing!
Hove
Sun Sep 01, 2013 10:18 am
Off-topic but wow, "cheap" definitely subjective with £75 for a tiny speaker set.
Oops, sorry! I paid half that from here: http://www.pixmania.co.uk/uk/uk/search/ ... play-list/ though their stock level was a lot better with all colours when I bought mine. Shop around -- anything more than £40 /
is a rip off.
Having said that, size isn't everything! Despite being small, these have an astonishing audio quality full-stop / period; they've won awards as a result. In a previous life, I was a HiFi geek, both buying and building speakers and amplifiers. The quality of these Edifiers isn't so far off a £1000 pair of speakers I built which in turn would have cost twice the price to buy the equivalent in a shop.
redhawk
Sun Sep 01, 2013 11:15 am
If you're looking for some cheap speakers then perhaps - http://www.raspberrypi.org/phpBB3/viewt ... 69#p375869
Richard S.
karlkiste
Sun Sep 01, 2013 12:15 pm
The output impedance of the Pi's analog audio out is more than 100 Ohm. Connected to a 8 Ohm speaker, you might get something like 0,5 milliwatts. I dare say, this is barely audible.
But, suggesting a 25 watts amplifier to have a beeping hand-held device is a bit too much, I think. Looking at the power ratings of one to two inch speakers, 1 watt per channel should be way enough.
A cheap high-power op-amp like a L2722 could do the job (in stereo!). You could even think of a one-transistor class-a amplifier.
Greets,
Kiste
P.S.: The protective diodes on the Pis analog audio out are unwisely connected AFTER the dc-blocking capacitors, therefore the outputs can not swing more than ~0.6V to the negative side. External bias to +1V or so could improve the sound when connecting to an amplifier with high input impedance.
Burngate
Sun Sep 01, 2013 3:23 pm
karlkiste wrote:The protective diodes on the Pis analog audio out are unwisely connected AFTER the dc-blocking capacitors, therefore the outputs can not swing more than ~0.6V to the negative side. External bias to +1V or so could improve the sound when connecting to an amplifier with high input impedance.
Though, since the 0 - 3v3 swing of the (PWM) audio is devided down by the potential devider to only 1v p-p, and therefore only go ±0.5v, those diodes won't have much effect.
karlkiste
Sun Sep 01, 2013 5:08 pm
This explanation had made more sense to me, if both the anodes and the cathodes had been connected to GND. Then the swing would be limited to ±0.6v. Now it is limited to -0.6/+4.1v. Looks a bit like not much thought of to me.
lithium630
Sun Sep 01, 2013 11:22 pm
I appreciate all the replies. I wouldn't want this to be too easy. :) It seems like the PI can power the amplifier on the Sony speakers suggested. I'll give it a try. I sense a lot of trial and error coming.
Burngate
Mon Sep 02, 2013 10:01 am
karlkiste wrote:This explanation had made more sense to me, if both the anodes and the cathodes had been connected to GND. Then the swing would be limited to ±0.6v. Now it is limited to -0.6/+4.1v. Looks a bit like not much thought of to me.
Agreed - I'd have put it before the cap, where it would protect the GPIO. But it hasn't changed since the first version, so maybe the designer knows more than me?
I once came across a very expensive HI-Fi amp - so expensive it had no tone controls, and was DC-coupled throughout - the owner was complaining that the volume control was crackling.
Turned out his (very expensive) pre-amp was putting DC on its output. So I stuck a couple of caps on the volume control input. The guy was ecstatic. I never let on I'd removed the DC coupling - one of the 'features' he'd wanted when he bought it.
PiGraham
Mon Sep 02, 2013 11:11 am
If you want a small, cheap amplified speaker you could do worse than one of these 'hamburger speakers' for under a fiver.
The sound quality and volume is similar to my Samsung Galaxy SII tat full blast and should be appropriate for a portable console project. You could probably extract the speaker and amp to fit them into your own case if the pop-up design doesn't suit you.
A switched 3.5mm jack socket will allow you to use the speaker of headphones.
karlkiste
Mon Sep 02, 2013 12:26 pm
I presume, the problem is - that it works :-) It was never meant to be approved by hifi-freaks who claim to hear a difference between speaker cables made from copper and those made from silver. I think it is a quickly designed part which does produce sound. The worst shortcomings are now worked around in firmware, and here we are ;-)
Metatronin
Mon Sep 09, 2013 5:26 am
You can run several LM386's off of the 5v GPIO. However you can just tie the left and right channels together and do a mono set-up with one chip and just a few capacitors. Less than 5$ in parts. Or spend 10-20$ for a mini 1-5W amplifier chip. Adafruit makes one(class D amp). If you can solder into the jack from the backside you could keep the headphones ability, and add a speaker with lm386 and a tiny audio pot/wheel. Just use a low power flat speaker that's rated at no more than 3W.
redhawk
Sat Sep 21, 2013 12:31 pm
While continuing the "speaker" discussion my local Poundland have been selling battery powered speaker amplifiers today.
The speakers have a nasty tinny audio response, however you could wire something much bigger and better for improved fidelity.
The amplifier IC itself an LM4871 has a mono output in BTL mode and operates from a wide power supply 2.0v to 5.5v.
If you're thinking of building an amplifier but don't want the hassle then this £1 kit is perfect for hacking and running off the Pi’s power supply (or 2 x for stereo output).
Richard S.
