droidus
motion images coming out blue/dark
Sun Aug 18, 2013 11:53 pm
I am using motion, and the images it is taking with my HP webcam are turning up blue. why is this happening?
droidus
Re: motion images coming out blue/dark
Thu Aug 22, 2013 1:57 am
anybody have any ideas as to why my images are coming out differently? i tried the webcam on another computer, and it worked fine.
4thdwarflord
Sat Aug 24, 2013 1:35 pm
Perhaps the drivers on the pi aren't working properly. I'd try a different camera (perhaps the pi camera)
droidus
Sat Aug 24, 2013 4:38 pm
So maybe I need to install/re-install a driver for it?
I was looking at http://www.ideasonboard.org/uvc/ to see if my HP webcam is compatible with the Pi. I found this one: HP KQ246AA 8.0MP Deluxe Webcam. Mine is a KQ245AA. I wonder if it is still supported?
redhawk
Sat Aug 24, 2013 5:34 pm
Could you post a screen shot to illustrate the problem and find out which chipset is inside i.e. lsusb
Webcam support under Linux is pretty poor I have several webcams most are too dark or don't white balance correctly which I suspect is the issue with your HP.
As far as I can it's not possible to tweaking the webcam's hardware settings either they manage to auto control exposure and white balance or not at all.
Richard S.
droidus
Sun Aug 25, 2013 1:58 am
not sure if this is the chipset, but it has an id of 04f2:a13d.
ramstrong
Sun Aug 25, 2013 5:49 am
I have that cheap HP cam on sale (can't remember the model) and my blacks comes out blue/green. This is because the software driver does auto color-correction, and is obviously out-of-standard-range adjustment. The problem goes away when I open the curtain and let sunlight in. So, if you're working in a dark place, devoid of sunlight, you may want to try that.
Another problem that I see is that when I point the webcam to the TV, it came out "dotty", not at all right. I don't know how to solve that yet. I will see if the sunlight factor will solve that.
There's nothing to do but see if you can try some manual adjustments and see if it helps. Otherwise, try doing it under extremely bright lights! :)
Raspberry Pi Journal: http://simpletongeek.blogspot.com/p/raspberry-pi-journal-directory_4.html
droidus
Sun Aug 25, 2013 1:59 pm
it is not in direct sunlight. where do i change the settings for it?
ramstrong
Sun Aug 25, 2013 8:28 pm
droidus wrote:it is not in direct sunlight. where do i change the settings for it?
Hardware-wise, Driver-wise: I don't know.
Software-wise: whatever the man pages tell you. I tried everything software-wise, and nothing works. YMMV.
droidus
Sun Aug 25, 2013 10:58 pm
so i may just need to buy a new webcam?
pcmanbob
Wed Aug 28, 2013 9:48 am
just a thought ( probably wrong but hay ) your image looks a lot like the ghost image motion produces when you set it to show only the moving pixels, might be worth a quick check that you have not turned that on.
if I remember correctly ( not used motion for a while ) the 2 options are
# Output pictures with only the pixels moving object (ghost images) (default: off)
output_motion off
# Use ffmpeg to make movies with only the pixels moving
# object (ghost images) (default: off)
ffmpeg_cap_motion off
droidus
Fri Aug 30, 2013 4:17 pm
the first config line seems to have fixed it. not sure why that was on. thank you.
F1pak
Mon Sep 30, 2013 7:41 pm
I try MJPG-streamer and it works very good. Maybe i must change sth in motion.conf.
