Catch cam stream fails
Posted: Fri May 24, 2013 5:11 pm
by HashberryPee
trying to catch the camera stream of my PiCam over Ubuntu 12.04 but receiving machine totally fails:
nc -l -p 5001 | mplayer -fps 31 -cache 1024 -
results in:
This is nc from the netcat-openbsd package. An alternative nc is available
in the netcat-traditional package.
usage: nc [-46DdhklnrStUuvzC] [-i interval] [-P proxy_username] [-p source_port]
[-s source_ip_address] [-T ToS] [-w timeout] [-X proxy_protocol]
[-x proxy_address[:port]] [hostname] [port]
MPlayer svn r34540 (Ubuntu), built with gcc-4.6 (C) 2000-2012 MPlayer Team
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing -.
Reading from stdin...
Cache fill: 0.00% (0 bytes)
libavformat version 53.21.1 (external)
Mismatching header version 53.19.0
Exiting... (End of file)
What's going wrong? What can I do?
BR
Michael
Re: Catch cam stream fails
Posted: Sat May 25, 2013 1:08 pm
by tvjon
Try
nc -l -p 5001
& see if it writes lots of chars to the screen.
What's your Picamera statement to send video?
Posted: Sat May 25, 2013 5:13 pm
by HashberryPee
Solved it!
Turned out that there are different 'nc' on my system! The only 'nc' belongs to openbsd package or so.
nc.traditional -l -p 5001 | etc...
did the trick.
Thanks anyway for your support. Appreciated!
Posted: Sat May 25, 2013 6:32 pm
by EnzioBrK
I have the same problem. How did you manage to solve it?
Posted: Sun May 26, 2013 1:05 pm
by HashberryPee
Are you using Ubuntu as well?
If so you have to install a package called 'netcat-traditional' and you also have to use the command 'nc.traditional' instead of 'nc' otherwise it takes the wrong netcat command, the one that belongs to the package 'netcat-openbsd'.
Posted: Wed Dec 04, 2013 1:47 am
by pipiloz
Hi there.
I have the same problem. tried nc.traditional -l -p 5001 | etc…
but it complains : -bash: etc...: command not found
have any suggestions?
p-
Posted: Wed Dec 04, 2013 6:34 am
by HashberryPee
Are you using Ubuntu too?
Have you installed the 'netcat-traditional' Package?
What does it suggest when you write 'nc' into the bash and press tab?
