RaspberryPi Drum Machine/Sequencer
Posted: Tue Apr 09, 2013 5:33 pm
by jakesaunders27
Im looking to make a raspberry pi drum machine and synthesizer, i know that someone has made a synthesizer already and was wondering if a drum machine is also possible. i want it to be controlled by TouchOSC on my iPad. Is this possible
Please help me out this is for a school project
Cheers
Jake
Re: RaspberryPi Drum Machine/Sequencer
Posted: Tue Apr 09, 2013 5:50 pm
by AutoStatic
Should be possible. I'm using drumkv1 as a drum sampler with an USB MIDI drumpad and that works like a charm. When it comes to synths you could take a look at Yoshimi or amSynth.
Not sure how to hook up TouchOSC but that should be possible too with the help of something like QmidiNet.
Posted: Tue Apr 09, 2013 9:31 pm
by jakesaunders27
Hi thanks so much for your replies will look into the links you gave!
Cheers!
Posted: Wed Apr 10, 2013 7:17 am
by AutoStatic
You're welcome. Latest versions of drumkv1, amSynth and Yoshimi are in my repository.
Posted: Sat Apr 13, 2013 5:58 pm
by Uberbuhrman
Hi AutoStatic,
Can you give me a hint on how to get sound out of drumkv1 ?
I have it connected in qjackctl :
in->midi keyboard ( oxygen) and
out->sytem
set a sample on one item and i can't seem to get even a beep.
Do i need some synth plugin or smth. else as a plugin for drumkv1 ?
I actually thought it would do synthesis and not even need a sample to start.
It's rather new and documentation is not yet available it seems...
thanks,
Ed.
Posted: Sat Apr 13, 2013 7:00 pm
by AutoStatic
Uberbuhrman wrote:Do i need some synth plugin or smth. else as a plugin for drumkv1 ?
No, just some samples.
Uberbuhrman wrote:I actually thought it would do synthesis and not even need a sample to start.
drumkv1 is not a synth, it's a sampler. So load in a sample, check what MIDI note it is (drumkv1 adheres to the General MIDI standard), press the respective key on your MIDI keyboard and the sample should be played.
Posted: Sun Apr 14, 2013 6:34 pm
by Uberbuhrman
Thanks, i got it.
Seem to have missed the right key i guess, no probs now.
Posted: Fri Oct 11, 2013 10:38 pm
by hardwired2001
Yep, its possible. Below is mine (beta). Written in python with pygame.mixer.
http://youtu.be/BYyV2BqbGAQ
Posted: Sun Mar 15, 2015 5:21 pm
by Jepeto
Hello all,
I am new to RPi. I must have missed something as I can any sound out of drumkv1. I have loaded samples and I have connected a Korg keyboard which seems to be supported by the OS. There is noise souding out when I launch drumkv1 so I assume it may be able to play samples but I can't hear anything when playing the keyboard. What's wrong here?
Thanks!
Posted: Sun Mar 15, 2015 5:48 pm
by Jepeto
To add to my last comment. The noise I am getting is actually the sample sound which seems to be corrupted in drumkv1. If I use command aplay, the sound is OK. What's wrong with my setup?
Posted: Sun Mar 15, 2015 8:15 pm
by yerzmyey
I tried to install this "amSynth" thing.
I made everything exactly like the TXT file suggested. On a standard R_Pi2, nothing strange there.
It has shown so many errors and expressed such a vast inability to do _anything_ that I deleted it instantly.
