jakesaunders27
RaspberryPi Drum Machine/Sequencer
Tue Apr 09, 2013 5:33 pm
Im looking to make a raspberry pi drum machine and synthesizer, i know that someone has made a synthesizer already and was wondering if a drum machine is also possible. i want it to be controlled by TouchOSC on my iPad. Is this possible
Please help me out this is for a school project
Cheers
Jake
AutoStatic
Re: RaspberryPi Drum Machine/Sequencer
Tue Apr 09, 2013 5:50 pm
Should be possible. I'm using drumkv1 as a drum sampler with an USB MIDI drumpad and that works like a charm. When it comes to synths you could take a look at Yoshimi or amSynth.
Not sure how to hook up TouchOSC but that should be possible too with the help of something like QmidiNet.
RPi and real-time, low-latency audio: http://wiki.linuxaudio.org/wiki/raspberrypi
RPi audio repository: http://rpi.autostatic.com/
RPi and audio blog: https://autostatic.com/tag/raspberrypi/
jakesaunders27
Tue Apr 09, 2013 9:31 pm
Hi thanks so much for your replies will look into the links you gave!
Cheers!
AutoStatic
Wed Apr 10, 2013 7:17 am
You're welcome. Latest versions of drumkv1, amSynth and Yoshimi are in my repository.
Uberbuhrman
Sat Apr 13, 2013 5:58 pm
Hi AutoStatic,
Can you give me a hint on how to get sound out of drumkv1 ?
I have it connected in qjackctl :
in->midi keyboard ( oxygen) and
out->sytem
set a sample on one item and i can't seem to get even a beep.
Do i need some synth plugin or smth. else as a plugin for drumkv1 ?
I actually thought it would do synthesis and not even need a sample to start.
It's rather new and documentation is not yet available it seems...
thanks,
Ed.
AutoStatic
Sat Apr 13, 2013 7:00 pm
Uberbuhrman wrote:Do i need some synth plugin or smth. else as a plugin for drumkv1 ?
No, just some samples.
Uberbuhrman wrote:I actually thought it would do synthesis and not even need a sample to start.
drumkv1 is not a synth, it's a sampler. So load in a sample, check what MIDI note it is (drumkv1 adheres to the General MIDI standard), press the respective key on your MIDI keyboard and the sample should be played.
Uberbuhrman
Sun Apr 14, 2013 6:34 pm
Thanks, i got it.
Seem to have missed the right key i guess, no probs now.
hardwired2001
Fri Oct 11, 2013 10:38 pm
Yep, its possible. Below is mine (beta). Written in python with pygame.mixer.
http://youtu.be/BYyV2BqbGAQ
Jepeto
Sun Mar 15, 2015 5:21 pm
Hello all,
I am new to RPi. I must have missed something as I can any sound out of drumkv1. I have loaded samples and I have connected a Korg keyboard which seems to be supported by the OS. There is noise souding out when I launch drumkv1 so I assume it may be able to play samples but I can't hear anything when playing the keyboard. What's wrong here?
Thanks!
Jepeto
Sun Mar 15, 2015 5:48 pm
To add to my last comment. The noise I am getting is actually the sample sound which seems to be corrupted in drumkv1. If I use command aplay, the sound is OK. What's wrong with my setup?
yerzmyey
Sun Mar 15, 2015 8:15 pm
I tried to install this "amSynth" thing.
I made everything exactly like the TXT file suggested. On a standard R_Pi2, nothing strange there.
It has shown so many errors and expressed such a vast inability to do _anything_ that I deleted it instantly.
http://yerzmyey.i-demo.pl/ ZX/AMIGA/ATARI music
http://ay-riders.speccy.cz/ ZX Spectrum music-band
https://soundcloud.com/yerzmyey ZX/AMIGA/ATARI music
http://ym-digital.i-demo.pl/ ATARI 520ST music-band
http://z80.i-demo.pl/ MP3 archive of Z80 chip music
